Passbolt is not accessible after update to 4.1.2-1
I followed the update instructions in the documentation.
now cannot access passbolt with error
ERR_TOO_MANY_REDIRECTS
I’ve run the healthcheck from CLI and the error is as below
the full base domain is correct in passbolt configuration
php -v output is as below:
PHP 7.4.33 (cli) (built: Jun 9 2023 16:51:37) ( NTS )
Copyright (c) The PHP Group
Zend Engine v3.4.0, Copyright (c) Zend Technologies
with Zend OPcache v7.4.33, Copyright (c), by Zend Technologies
OS details:
Description: Debian GNU/Linux 11 (bullseye)
Release: 11
Codename: bullseye
Hello @mhmdimmo, welcome to our community :slightly_smiling_face:
I have some questions to better understand what is happening:
  • Could you share the entire output of the healthcheck?
  • Could you share the nginx configuration file?
    • Should be located in /etc/nginx/sites-enabled/nginx-passbolt.conf
  • If you are using SSL, are you using a self-signed certificate?
  • When you say the fullBaseUrl is correct, did you also include https:// ?
    • If possible I would like to see what you have inside App.fullBaseUrl in /etc/passbolt/passbolt.php
  • Did you saw any errors after updating?
  • Which version were you using before?
