Passbolt won't send mails but send_test_email does
I recently upgraded from version 1.6.5 to 1.6.10 to 2.0.7. This was quite a painless process. However now Passbolt won’t send emails anymore. Any action that generates an mail won’t any more. However the test email does work!
www-data@passbolt:/data/www/passbolt$ ./bin/cake passbolt register_user \
>                                 -u eddie@domain.nl \
>                                 -f my_name \
>                                 -l my_surname \
>                                 -r admin
User saved successfully.
To start registration follow the link in provided in your mailbox or here:
https://passbolt.domain.nl/setup/install/79f9d35f-db68-4def-a102-da7c877d912d/96baaca0-1fa4-42f7-b77d-daf04e94979e
www-data@passbolt:/data/www/passbolt$ ./bin/cake passbolt send_test_email --recipient=eddie@domain.nl
 Debug email shell
Email configuration
Host: smtp.domain.nl
Port: 25
Username:
Password: *********
TLS: false
Sending email from: Passbolt <passbolt@domain.nl>
Sending email to: eddie@domain.nl
Trace
[220] dmzsha2060.domain.nl - Abuse (attempts) will be logged and reported!
> EHLO localhost
[250] dmzsha2060.domain.nl
[250] PIPELINING
[250] SIZE 26214400
[250] ETRN
[250] ENHANCEDSTATUSCODES
[250] 8BITMIME
[250] DSN
> MAIL FROM:<passbolt@domain.nl>
[250] 2.1.0 Ok
> RCPT TO:<eddie@domain.nl>
[250] 2.1.5 Ok
> DATA
[354] End data with <CR><LF>.<CR><LF>
> From: Passbolt <passbolt@domain.nl>
To: eddie@domain.nl
Date: Wed, 16 May 2018 11:34:55 +0000
Message-ID: <09a6bf3c5f414be886aa40d2858a6d63@passbolt>
Subject: Passbolt test email
MIME-Version: 1.0
Congratulations!
[250] 2.0.0 Ok: queued as 3A8E617F714
> QUIT
However there is a lead in the /var/mail/root:
From root@passbolt.domain.nl  Wed May 16 13:41:01 2018
Return-Path: <root@passbolt.domain.nl>
X-Original-To: root
Delivered-To: root@passbolt.domain.nl
Received: by passbolt.domain.nl (Postfix, from userid 0)
        id D99C3C09B0; Wed, 16 May 2018 13:41:01 +0200 (CEST)
Subject: Cron <root@passbolt> /data/www/passbolt/app/Console/cake EmailQueue.sender > /data/www/passbolt/app/tmp/email.log
MIME-Version: 1.0
X-Cron-Env: <SHELL=/bin/sh>
X-Cron-Env: <HOME=/root>
X-Cron-Env: <PATH=/usr/bin:/bin>
X-Cron-Env: <LOGNAME=root>
Message-Id: <20180516114101.D99C3C09B0@passbolt.domain.nl>
Date: Wed, 16 May 2018 13:41:01 +0200 (CEST)
/bin/sh: 1: /data/www/passbolt/app/Console/cake: not found
Now i believe that /data/www/passbolt/app/Console/cake & /data/www/passbolt/app/tmp/email.log are files from version 1.6.X and it didn’t migrate properly. I did run the migration script again without any success. Would appreciate the help
[ X ] I have read intro post: About the Installation Issues category
[ X ] I have read the tutorials, help and searched for similar issues
[ X ] I provide relevant information about my server (component names and versions, etc.)
[ X ] I provide a copy of my logs and healthcheck
[ X ] I describe the steps I have taken to trouble shoot the problem
[ X ] I describe the steps on how to reproduce the issue
Hi @eddie4
Could it be that you didn’t upgrade the cron job?
/DOH
indeed that is still to the old path. I Installed passbolt 8 months ago and totally forgot about it. There is however no mention of this in:
https://help.passbolt.com/hosting/update
Yeah, sorry about that, we will upgrade the docs making a mention to upgrade the cron jobs.
Also if you could describe the pain points for you when upgrading passbolt it would be nice feedback for us to improve the process!
Well this mail issue was one.
Also I had to manually set this:
chown www-data:www-data -R /data/www/passbolt/vendor/ezyang/htmlpurifier/library/HTMLPurifier/DefinitionCache/Serializer/
And I initially skipped adding these two to the system. But that was my mistake.
apt install composer php7.0-intl
Okay @eddie4 thanks for the feedback much appreciated!
