Problem with MFA and connection from a new browser [htaccess Set-Cookie header]
I’m using Passbolt CE for a few weeks now and i have 3 problems :
  • I can’t active MFA (TOTP) for all users except me. All users, when they go in “settings > MFA”, have a blank page.
    For myself, MFA is enabled, but Passbolt never asked for the TOTP when i login.
  • Actually we are changing all of ours computers, and when i go on the BaseURL on the new computer/browser, i have a blank page, so i cannot connect even if i have my private key and pass phrase.
  • It seems the recovery account feature is only accessible in business version, is there a way to enable this feature, or have an equivalent without business version ?
    If not, that’s not a problem, i can pay for that :slight_smile:
Environment:
Server: CentOS 7
Webserver: httpd 2.4
Database server: MySQL 5.7
PHP version: php 8.0
Passbolt version: 3.12.0
Installation is from source code and the health check is below:
[user@hostname:~]$ ./www/bin/cake passbolt healthcheck
Passbolt commands should only be executed as the web server user.
 [PASS] PHP version 8.0.23.
 [PASS] Full base url is set to
 [PASS] 30 tables found
 [PASS] The environment variable GNUPGHOME is set to .gnupg.
 [PASS] The directory .gnupg containing the keyring is writable by the webserver user.
 [PASS] The public key file is defined in www/config/passbolt.php and readable.
 [PASS] The private key file is defined in www/config/passbolt.php and readable.
 [PASS] The server key fingerprint matches the one defined in www/config/passbolt.php.
 [PASS] The server public key defined in the ww/config/passbolt.php (or environment variables) is in the keyring.
 [PASS] Using latest passbolt version (3.12.0).
 [PASS] The deprecated self registration public setting was not found in www/config/passbolt.php.
 [HELP] Or set passbolt.email.validate.mx to true in www/config/passbolt.php.
 [PASS] The www/config/jwt/ directory is not writable.
 SMTP Settings
 [HELP] Or set passbolt.security.smtpSettings.endpointsDisabled to true in www/config/passbolt.php.
Regards,
Lithiumx.
Hi @Lithiumx Welcome to the forum!
Seems your post got missed - sorry for that.
Regarding MFA, What does this return for mysql command line:
select value from organization_settings where property='mfa';
When you say you are changing computers and have a blank page, are your new computers able to access the site via the network? (Can they ping the server ip?) A blank page suggests they are either in a different subnet or there is a firewall blocking those new machine ip addresses.
The account recovery feature, where a group of users are able to recover the account of one user, is a PRO version feature. Trial demos using the cloud service are available here: Try Passbolt Cloud - For Free
You can use the cloud service or install a self-hosted version if you decide PRO is a good fit for your needs.
Thx for replying.
I solved all my problems, it was a problem with my htaccess for both:
Header always edit Set-Cookie (.*) “$1; HTTPOnly”
I disabled it and now everything works well.
I am in the process of seeing with my company to find out if we absolutely need the recovery feature.
If so, we’ll upgrade to the PRO version.
In any case, it is not possible for us to have our passwords hosted on the internet, so I cannot use the cloud version.
Regards,
Lithiumx.
