First mail configuration
I think this problem is recurrent but I did not find a solution to my problem on the forum and google.
When I first set up the mail account on the exchange server, I want to configure it, but it returns that the credentials are not good.
I am annoyed because as this is blocked I can not access the administration interface.
If someone could help me it would be very nice because I spent a lot of time on this installation (I met a lot of problems) and now Iā€™m almost at the end but Iā€™m blocked and have no ideaā€¦
For information I run Debian 11.
Thanks a lot !
Good evening / day to you
Hello @floMAC78 Welcome to the forum!
You will need to provide more details like:
  • who is your mail provider?
  • show mail configuration settings in passbolt, or explain steps you took (remove sensitive info first)
  • what action were you taking before you got a message that credentials were bad?
  • what was the actual message?
And also make sure to review Passbolt Help | Why are my emails not being sent?
Hello, first of all thank you for your answer.
    EXCHANGE SERVER hosted internally
    I have done the configuration steps, but I did not succeed in the email step.
    on the picture above
Also until then you can still connect to your server to generate a link for a new admin.
sudo su -s /bin/bash -c "/usr/share/php/passbolt/bin/cake passbolt register_user -u email@domain.com -f FirstName -l LastName -r admin" www-data
I do not have a local exchange to test but could it be that you have to whitelist your server IP in order that it is accepted by MS exchange?
Thank you very much, indeed I have access to the interface now. I will be able to communicate you my mail settings !
Capture dā€™eĢcran 2022-10-14 aĢ€ 12.07.55
Voila :grinning:
Can you try with an IP for the host?
Can you share as well the result of the command:
sudo -H -u www-data bash -c "/usr/share/php/passbolt/bin/cake passbolt send_test_email --recipient=youremail@domain.com"
Merci :slight_smile:
@floMAC78 Thanks for the additional info!
Have you had a chance to review this? Office365 SMTP: upcoming basic auth changes not affecting SMTP (though MFA + app passwords recommended)
It has a couple links to other threads with the same issue.
In the screenshot you donā€™t show the results after the AUTH LOGIN. Your server doesnā€™t permit PLAIN so itā€™s OK to ignore the first error, thatā€™s normal.
What is the error after AUTH LOGIN?
Hello, sorry for the time of answerā€¦ Here is the result:
Debug email shell
Email configuration
Host: xxxxxxxxx.xxxx
Port: 587
Username: xxxxxxxxxxx
Password: *********
TLS: true
Sending email from: xxxxxx srv xxxxxxxxx@xxxx
Sending email to: xxxxxxxxxx@xxxx
Trace
[220] exchange.xxxxxx Microsoft ESMTP MAIL Service ready at Mon, 17 Oct 2022 17:08:29 +0200
EHLO localhost
[250] exchange.xxxx Hello [xxx.xxx.xxx.xxx]
[250] SIZE 36700160
[250] PIPELINING
[250] DSN
[250] ENHANCEDSTATUSCODES
[250] STARTTLS
[250] AUTH GSSAPI NTLM
[250] 8BITMIME
[250] BINARYMIME
[250] CHUNKING
STARTTLS
[220] 2.0.0 SMTP server ready
EHLO localhost
[250] SIZE 36700160
[250] PIPELINING
[250] DSN
[250] AUTH GSSAPI NTLM LOGIN
[250] 8BITMIME
[250] BINARYMIME
[250] CHUNKING
AUTH PLAIN AHBhc3N3b3JkAFBuamhJdFBNR3NvdVRvMGpaNEZYdGhBag==
[504] 5.7.4 Unrecognized authentication type
AUTH LOGIN
[334] VXNlcm5hbWU6
[334] UGFzc3dvcmQ6
Error: SMTP server did not accept the password.
Thank you for your help !
Merci pour votre aide :grinning:
Normally no problem on this side because I have GLPI and the scanner that communicates by mail.
@floMAC78 Is the recipient of the passbolt email internal or external to your organization?
In the above configuration internal, but I tried external tooā€¦
Hi @floMAC78
Iā€™m not sure if this might be a solution but you can try double checking your Microsoft admin account.
Make sure 2FA is enabled.
Generate an APP Password for the email that you are using for SMTP.
Then try the process again. I had a client with a similar error; although it was not related to passbolt.
The client had created an APP password for the wrong email. This could also be an issue.
Regards
Bond
@floMAC78 Itā€™s a bit hard to verify your config because itā€™s completely obscured. Would you mind replacing xxs with things like ā€œremote.domainā€, ā€œremoteipā€ so itā€™s descriptive? That will help thanks.
Hello everyone, I have managed to use passbolt so far without mail. I made several attempts but all failed.
Now I have a problem and mails become necessary, so Iā€™m again in the need to solve this one, but this time Iā€™m really going to solve it 100%.
If you agree to help me I would be very grateful!
We can definitely try and help out here again.
Could you try the test email again?
Additionally in the database there are some errors logged for emails and you can get those with this query:
select email, subject, created, sent, error from email_queue;
