Running: sudo /usr/share/php/passbolt/bin/status-report I get:
Passbolt CE 4.1.0
Cakephp 4.4.14
Linux virtual-machine2 5.15.0-1038-oracle #44-Ubuntu SMP Thu Jun 22 03:34:10 UTC 2023 aarch64 aarch64 aarch64 GNU/Linux
PHP 8.1.2-1ubuntu2.13 (cli) (built: Jun 28 2023 14:01:49) (NTS)
mysql Ver 8.0.33-0ubuntu0.22.04.2 for Linux on aarch64 ((Ubuntu))
gpg (GnuPG) 2.2.27
libgcrypt 1.9.4
[PASS] PHP version 8.1.2-1ubuntu2.13.
[PASS] Full base url is set to https://141.147.104.169/
[PASS] 32 tables found
[HELP] sudo su -s /bin/bash -c "/usr/share/php/passbolt/bin/cake passbolt install" www-data
[FAIL] This installation is not up to date. Currently using 4.1.0 and it should be v4.1.1.
SMTP Settings
[FAIL] 5 error(s) found. Hang in there!
Cleanup shell (dry-run)
Data check shell
[PASS] Can validate: 24/24
[PASS] Can validate: 0/0
[PASS] Can encrypt: 1/1
[PASS] Pass validation service checks: 1/1
[PASS] Entity data and armored key data matches: 1/1
[PASS] Is not expired: 1/1
[PASS] Is armored key format valid: 1/1
[PASS] Can validate: 1/1
[PASS] Can validate: 124/124
[PASS] Can validate: 118/118
2023-07-14 02:38:30 error: [Cake\Routing\Exception\MissingRouteException] A route matching "/ab2h" could not be found. in /usr/share/php/passbolt/vendor/cakephp/cakephp/src/Routing/RouteCollection.php on line 197
Request URL: /ab2h
Client IP: 46.101.210.113
2023-07-14 04:00:42 error: [Cake\Routing\Exception\MissingRouteException] A route matching "/geoserver/web/" could not be found. in /usr/share/php/passbolt/vendor/cakephp/cakephp/src/Routing/RouteCollection.php on line 197
Request URL: /geoserver/web/
Client IP: 64.62.197.118
2023-07-14 04:03:48 error: [Cake\Routing\Exception\MissingRouteException] A route matching "/.git/config" could not be found. in /usr/share/php/passbolt/vendor/cakephp/cakephp/src/Routing/RouteCollection.php on line 197
Request URL: /.git/config
Client IP: 64.62.197.114
2023-07-14 04:55:42 error: [Cake\Routing\Exception\MissingRouteException] A route matching "/ab2g" could not be found. in /usr/share/php/passbolt/vendor/cakephp/cakephp/src/Routing/RouteCollection.php on line 197
Request URL: /ab2g
Client IP: 134.122.103.1
2023-07-14 04:55:42 error: [Cake\Routing\Exception\MissingRouteException] A route matching "/ab2h" could not be found. in /usr/share/php/passbolt/vendor/cakephp/cakephp/src/Routing/RouteCollection.php on line 197
Request URL: /ab2h
2023-07-14 04:55:43 error: [Cake\Routing\Exception\MissingRouteException] A route matching "/t4" could not be found. in /usr/share/php/passbolt/vendor/cakephp/cakephp/src/Routing/RouteCollection.php on line 197
Request URL: /t4
2023-07-14 07:38:21 error: [Cake\Routing\Exception\MissingRouteException] A route matching "/Public/home/js/check.js" could not be found. in /usr/share/php/passbolt/vendor/cakephp/cakephp/src/Routing/RouteCollection.php on line 197
Request URL: /Public/home/js/check.js
Client IP: 47.251.14.232
2023-07-14 07:38:22 error: [Cake\Routing\Exception\MissingRouteException] A route matching "/static/admin/javascript/hetong.js" could not be found. in /usr/share/php/passbolt/vendor/cakephp/cakephp/src/Routing/RouteCollection.php on line 197
Request URL: /static/admin/javascript/hetong.js
Client IP: 47.88.90.156
Trying to run sudo -H -u www-data bash -c "/usr/share/php/passbolt/bin/cake passbolt send_test_email --verbose --recipient=my_email@gmail.com" returns:
Debug email shell
Email configuration
Host: smtp.gmail.com
Port: 587
Username: my_email@gmail.com
Password: *********
TLS: true
Sending email from: <name> <my_email@gmail.com>
Sending email to: my_email@gmail.com
Trace
[220] smtp.gmail.com ESMTP u11-20020a05600c00cb00b003fbb346279dsm1311619wmm.38 - gsmtp
EHLO localhost
[250] smtp.gmail.com at your service, [<my IP>]
[250] SIZE 35882577
[250] 8BITMIME
[250] STARTTLS
[250] ENHANCEDSTATUSCODES
[250] PIPELINING
[250] CHUNKING
[250] SMTPUTF8
STARTTLS
EHLO localhost
[250] SIZE 35882577
[250] 8BITMIME
[250] AUTH LOGIN PLAIN XOAUTH2 PLAIN-CLIENTTOKEN OAUTHBEARER XOAUTH
[250] PIPELINING
[250] CHUNKING
[250] SMTPUTF8
AUTH PLAIN *****
[535] 5.7.8 Username and Password not accepted. Learn more at
[535] 5.7.8 https://support.google.com/mail/?p=BadCredentials u11-20020a05600c00cb00b003fbb346279dsm1311619wmm.38 - gsmtp
Error: SMTP Error: 530 5.7.0 https://support.google.com/mail/?p=WantAuthError u11-20020a05600c00cb00b003fbb346279dsm1311619wmm.38 - gsmtp
I am using an app password given as such “xxxxxxxxxxxxxxxx” - 16 characters no spaces and yet it still fails. After some googling, the error code 530, 5.7.0 means 530, "5.7.0", Must issue a STARTTLS command first. How would I configure passbolt to do this?
