We are using Passbolt CE on Digital Ocean since 1 year and it’s great.
We configured the email with Google SMTP relay and it worked since 3.8.1 update I did on 18th of Nov. Since now, I can only send test mails (successfully, by using the CLI cake script), but every mail triggered by the queue goes in SMTP timeout or SSL SMTP failure.
The system healthcheck script gives all OK: su -s /bin/bash -c "/usr/share/php/passbolt/bin/cake passbolt healthcheck --application --configFiles --core --database --environment --ssl" www-data
[PASS] PHP version 8.1.12.
[PASS] Full base url is set to https://passbolt.gigadesignstudio.com
[PASS] 26 tables found
[PASS] Using latest passbolt version (3.8.1).
This command works: su -s /bin/bash -c "/usr/share/php/passbolt/bin/cake passbolt send_test_email --recipient=stefano@gigadesignstudio.com" www-data
Email configuration
Host: smtp-relay.gmail.com
Port: 587
Username:
Password: *********
TLS: true
Sending email from: Giga password service <info@gigadesignstudio.com>
Sending email to: stefano@gigadesignstudio.com
Trace
[220] smtp-relay.gmail.com ESMTP b15-20020a50cccf000000b00469701c73c7sm337560edj.47 - gsmtp
EHLO 161.35.206.138
[250] smtp-relay.gmail.com at your service, [161.35.206.138]
[250] SIZE 157286400
[250] 8BITMIME
[250] STARTTLS
[250] ENHANCEDSTATUSCODES
[250] PIPELINING
[250] CHUNKING
[250] SMTPUTF8
STARTTLS
EHLO 161.35.206.138
[250] 8BITMIME
[250] AUTH LOGIN PLAIN XOAUTH2 PLAIN-CLIENTTOKEN OAUTHBEARER XOAUTH
[250] PIPELINING
[250] CHUNKING
[250] SMTPUTF8
MAIL FROM:<info@gigadesignstudio.com>
[250] 2.1.0 OK b15-20020a50cccf000000b00469701c73c7sm337560edj.47 - gsmtp
RCPT TO:<stefano@gigadesignstudio.com>
[250] 2.1.5 OK b15-20020a50cccf000000b00469701c73c7sm337560edj.47 - gsmtp
DATA
[354] Go ahead b15-20020a50cccf000000b00469701c73c7sm337560edj.47 - gsmtp
From: Giga password service <info@gigadesignstudio.com>
To: stefano@gigadesignstudio.com
Date: Tue, 22 Nov 2022 20:37:01 +0000
Message-ID: <9a861794c73f4a068c6e25546fb07f42@passbolt-ubuntu-s-1vcpu-1gb-intel-fra1-01>
Subject: Passbolt test email
MIME-Version: 1.0
Congratulations!
[250] 2.0.0 OK 1669149421 b15-20020a50cccf000000b00469701c73c7sm337560edj.47 - gsmtp
QUIT
This command fails: su -s /bin/bash -c "/usr/share/php/passbolt/bin/cake EmailQueue.sender" www-data
SMTP server did not accept the connection or trying to connect to non TLS SMTP server using TLS.
Email 1910 was not sent
I’m attaching the screenshot of a query on the passbolt DB, you can see that after the update every email in the “email_queue” table fails after 4 retries (5th column); error is in the 6th column.
Thank you, have a nice day
Stefano
