I am at a sort of lost for words what the issue is here.
Story: I just purchased a new phone, the fairphone 4 with e/OS. I want to have it obtain access to my self hosted passbolt server. The server lives in a “cloud of my choosing”.
I install the passbolt application via app lounge, and proceed to do the very basic mobile setup: log into the server via another machine, navigate to mobile setup, scan the QR code, import successfull.
When I get to the point where it asks of my passphrase - I enter my passphrase, and then passbolt returns an error saying passphrase incorrect. Ok. I triple check make sure I am entering my passphrase correctly, and indeed it’s still erroring with thesame output.
I enable debugging on the application, and see the following error of notice:
“There was an error during unlockKeygo.Universe$proxyerror: gopenpgp: error in unlocking key: openpgp: Invalid Data: private key checksum failure”
Ok strange. I uninstall app, reinstall. Same issue. I install from play store (rather than app lounge). Same Issue. I try to manually import my account (through the manual import with uuid url and private key). Same issue. I tried recovering the account in question on another web browser / extentsion (albeit desktop) and import was successfull. I ensured the passbolt has Full permission in android.
I have another work account under my self hosted instance. I figured I’d give that a try and see if I can import it on the phone. Well, this actually worked with the QR code as-you-would expect! My passphrase gets me past the next step - which makes me really susceptible to the particular account I am trying to diagnose.
Here is output of healthcheck:
[PASS] PHP version 8.1.2-1ubuntu2.14.
[FAIL] The temporary directory and its content are not writable, or are executable.
[HELP] you can try:
[HELP] sudo chown -R www-data:www-data /var/lib/passbolt/tmp/
[HELP] sudo chmod -R 775 $(find /var/lib/passbolt/tmp/ -type d)
[HELP] sudo chmod -R 664 $(find /var/lib/passbolt/tmp/ -type f)
[PASS] Full base url is set to https://passbolt.XXXXXXXXXX.life
[PASS] 31 tables found
[PASS] Using latest passbolt version (4.4.2).
[WARN] The deprecated self registration public setting was found in /etc/passbolt/passbolt.php.
[HELP] You may remove the "passbolt.registration.public" setting.
SMTP Settings
By all means, the service seems to be working just fine. Something to do with this particular account, and the phone. I will eventually want to see if I can do it on another phone. But I am tired for the time being.
