GPG problem after upgrading from 3.9.0 (Docker version)
Server: Synology NAS DS916+
OS: DSM 7.2.1-69057 Update 4
Passbolt edition: Docker CE
Currently running 3.9.0. If I try to update to any higher version, the new version will stop immediately after start.
Here is the log:
date stream content
2024/04/02 02:18:22 stdout gpg: secret keys read: 1
2024/04/02 02:18:22 stdout gpg: unchanged: 1
2024/04/02 02:18:22 stdout gpg: Total number processed: 0
2024/04/02 02:18:22 stdout gpg: import from ‘/etc/passbolt/gpg/serverkey_private.asc’ failed: End of file
2024/04/02 02:18:22 stdout gpg: error reading ‘/etc/passbolt/gpg/serverkey_private.asc’: End of file
2024/04/02 02:18:22 stdout gpg: error getting the KEK: End of file
2024/04/02 02:18:22 stdout gpg: key XXXXXXXXXXXX: Dxxxxx Pxxxxxx dxxxxx@pxxxxxx.com not changed
2024/04/02 02:18:22 stdout gpg: imported: 1
2024/04/02 02:18:22 stdout gpg: Total number processed: 1
2024/04/02 02:18:22 stdout gpg: key XXXXXXXXXXXX: public key Dxxxxx Pxxxxxx dxxxxxx@pxxxxxxx.com imported
2024/04/02 02:18:22 stdout gpg: /var/lib/passbolt/.gnupg/trustdb.gpg: trustdb created
2024/04/02 02:18:22 stdout gpg: keybox ‘/var/lib/passbolt/.gnupg/pubring.kbx’ created
Since it the higher versions stop running immediately, I cannot provide a healthcheck for them, however here is the healthcheck for 3.9.0 which I’m trying to update from:
/ _
//./_//__/
[PASS] PHP version 7.4.33.
[PASS] Full base url is set to https://pws.mydomain.com
[PASS] 30 tables found
[FAIL] This installation is not up to date. Currently using 3.9.0 and it should be v4.6.1.
SMTP Settings
[PASS] The SMTP Settings plugin endpoints are disabled.
The steps I have taken to trouble shoot the problem:
  • Updated to different higher versions and reverted to 3.9.0 countless times. At higher versions I experienced the issue every single time, at 3.9.0 version I never experienced it.
  • Read all the related forum topics
  • Checked the permissions of the mounted gpg folder and the files in it (serverkey.asc and serverkey_private.asc)
  • I moved the mounted files to another folder and mount them there
  • I have another Synology NAS, different model but same OS and same docker version. I have Passbolt installed on that, too, and I have no problem running the latest version on that machine. So I compared all the settings, env. variables, custom configs, etc. All are the same, no difference at all (except URL, etc.) However I still cannot update from 3.9.0 on one of the machinces and have no problem on the other machine.
Any help would be greatly appreciated!
I think you have the same issue than this user: Docker hub latest-debian out of date
TL;DR: since the docker image is based on Debian 12, there is a GPG issue for some Synology NAS. There is no solution for now except rebuild a docker image based on Debian 11.
Or maybe update the docker entryfile to skip the gpg generation and provide gpg keys.
Well, it seems to be the reason indeed, thank you so much for the information!
I wish there would be a docker version with Debian 11 available…
