Hi Experts,
I ran into a problem when installing Passbolt Kubernetes executed via helm. It installs perfectly but I am stuck when trying to access to the Web UI to complete the installation. It writes “You need an account to login”. This is a fresh installation and it is reproducible.
root@passbolt-546496f577-jvmcs:/var/www/passbolt/bin# su -s /bin/bash -c "/var/www/passbolt/bin/cake passbolt healthcheck" www-data
Warning Error: SplFileInfo::openFile(/var/www/passbolt/tmp/cache/persistent/myapp_cake_core_translations_cake_console_en__u_s): failed to open stream: Permission denied in [/var/www/passbolt/vendor/cakephp/cakephp/src/Cache/Engine/FileEngine.php, line 406]
[PASS] PHP version 7.3.24.
[FAIL] The temporary directory and its content are not writable.
[HELP] you can try:
[HELP] sudo chown -R www-data:www-data /var/www/passbolt/tmp/
[HELP] sudo chmod 775 $(find /var/www/passbolt/tmp/ -type d)
[HELP] sudo chmod 664 $(find /var/www/passbolt/tmp/ -type f)
[PASS] Full base url is set to https://central.prestomall.com
[HELP] cURL Error (6) Could not resolve host: central.prestomall.com
[PASS] 23 tables found
[HELP] sudo su -s /bin/bash -c "gpg --list-keys --fingerprint --home /home/www-data/.gnupg" www-data | grep -i -B 2 'SERVER_KEY_EMAIL'
[HELP] you can try:
[HELP] sudo su -s /bin/bash -c "gpg --home /home/www-data/.gnupg --import /var/www/passbolt/config/gpg/serverkey_private.asc" www-data
[FAIL] This installation is not up to date. Currently using 2.13.5 and it should be v3.2.1.
9 error(s) found. Hang in there!
Here Dani from Passbolt. I reproduced it using your helm chart. This is the expected behaviour since you didn’t create any user so far. You can check how to create the first Passbolt user using the docker container in this doc. Since you are running the container in a pod inside a k8s cluster, you could execute that command running the following:
After running it, you can get the url from the command output to finish the user creation.
Apart from that, I encourage you to not using that Passbolt image version by default (2.13.5-debian) since we are currently in v3.2.2. You can check our docker hub page.
I hope that helps you to finally get Passbolt running in kubernetes.
Good day,
Ahh I was under the impression the Kubernetes installation would be similar to a Passbolt server installation. Apologies, I should have checked the docker guide properly.
In any case, the command worked like charm.
There are some config issue but I will sort it on my own.
