[ * ] I have read intro post: About the Installation Issues category
[ * ] I have read the tutorials, help and searched for similar issues
[ * ] I provide relevant information about my server (component names and versions, etc.)
[ * ] I provide a copy of my logs and healthcheck
[ * ] I describe the steps I have taken to trouble shoot the problem
[ * ] I describe the steps on how to reproduce the issue
I am unable to modify or delete passwords after adding them to Passbolt. Here is the following image I get when trying to modify a password:
Whenever I try to delete a password it just states that the password was successfully deleted, but it still remains.
I am running passbolt in a Ubuntu 20.04 container installed using the method described here. The host is an Ubuntu 20.04 ppc64el server running mysql 8.0. The container is accessing the DB over the local container network. Also, there is another container running Apache that is in acting as a forwarding proxy for passbolt, as I have other web apps and services routed through.
Here is my Healthcheck:
Healthcheck shell........
[PASS] PHP version 7.4.3.
[PASS] Full base url is set to https://passbolt.host.com
[PASS] 26 tables found
[PASS] Using latest passbolt version (3.3.0).
[WARN] The JWT Authentication plugin is disabled
[HELP] Set the environment variable PASSBOLT_PLUGINS_JWT_AUTHENTICATION_ENABLED to true
