Blank page after installation on Debian 12
I am running a VM on my ESXi host machine with Debian 12 OS installed on this VM.
On top of it I have installed Docker, compose in order to proceed with the installation of Passbolt.
I have followed the instructions on the docker installation provided by passbolt itself and also read a bunch of installation posts before proceeding with the installation.
Below you may find my Docker compose file just with slight modifications of the original.
  db:
    image: mariadb:10.11
    restart: unless-stopped
      MYSQL_DATABASE: "passbolt"
      MYSQL_USER: "passbolt"
      MYSQL_PASSWORD: "P4ssb0lt"
    depends_on:
      - db
      APP_FULL_BASE_URL: https://localhost
      - /opt/docker/passbolt/passbolt-selfsigned.crt:/etc/ssl/certs/certificate.crt:ro
      - /opt/docker/passbolt/passbolt-selfsigned.key:/etc/ssl/certs/certificate.key:ro
    command:
        "/usr/bin/wait-for.sh",
        "-t",
        "0",
        "db:3306",
        "/docker-entrypoint.sh",
      - 10080:80
      - 10443:443
    # - 80:8080
    # - 443:4433
  database_volume:
  gpg_volume:
  jwt_volume:
All and all the installation process went well and smoothly, added the SSL certificate manually and it seems to be loading fine.
Issues started when I tried to access the page. It remains blank.
I have tried solutions provided in this two topics but to no avail.
On the console tab of Chrome I get policy issues:
Refused to load the script ‘https://localhost/js/app/api-triage.js?v=4.9.1’ because it violates the following Content Security Policy directive: “script-src ‘self’”. Note that ‘script-src-elem’ was not explicitly set, so ‘script-src’ is used as a fallback.
After checking this out I searched and added this line on the server block of nginx cfg but still the same issue.
    add_header Content-Security-Policy "default-src 'self'; script-src 'self' https://localhost; img-src 'self'; style-src 'self' https://localhost;" always;
I have re-done installation quite a few times by now and tried different solutions provided on the internet, none of them worked.
When running healthcheck command I get this output:
 Healthcheck shell.....
 [PASS] PHP version 8.2.20.
 [PASS] Full base url is set to https://localhost
 [FAIL] App.fullBaseUrl does not validate. https://localhost.
 [HELP] Edit App.fullBaseUrl in /etc/passbolt/passbolt.php
 [HELP] Select a valid domain name as defined by section 2.3.1 of http://www.ietf.org/rfc/rfc1035.txt
 SMTP settings
 [HELP] You can try:
 [HELP] you can try:
 [PASS] 31 tables found.
 [FAIL] 10 error(s) found. Hang in there!
I do not know what to do next and I need some help.
Hello @eddie1337 , have you tried to use the fullBaseUrl https://localhost:10443 and then restart the container?
I have already done that, sorry that I did not mention it before.
I still have the same result where the page is blank.
I have not been able to resolve this yet.
Any help is kindly appreciated.
I am trying on Docker desktop and everything is going smooth.
Now I have created another env on my host machine running Ubuntu 24.04 and then installed Docker engine on top of it, still having the same issue where the page remains blank.
I am open to any suggestion to check.
Generally a blank page is a sign of an issue with the full base URL you have set in the config. Can you double check that what you have set there is exactly what you are using in the URL to access the instance?
Hi Clayton,
I did fix it with a help of my colleague.
I had mapped my local forward port different from the one in yaml and for some reason that did the trick.
Still sounds weird to me as I think it should not affect it.
Detailed explanation:
I access ESXi host remotely using SSH tunnel.
Therefore I have to Local Forward configurations in order to access remote VM’s.
On the SSH config file I had previously mapped different local port with remote port.
Example I had local 10010 and remote (docker) 10443.
Once I changed my local port the same as docker it worked.
(I also changed docker compose file full base url from localhost to a domain and also map that domain to my windows host file).
Hope this solution helps anyone out there.
