Email not arrived for users
[ x ] I have read intro post: https://community.passbolt.com/t/about-the-installation-issues-category/12
[ x ] I have read the tutorials, help and searched for similar issues
[ x ] I provide relevant information about my server (component names and versions, etc.)
[ x ] I provide a copy of my logs and healthcheck
[ x ] I describe the steps I have taken to trouble shoot the problem
[ x ] I describe the steps on how to reproduce the issue
[PASS] PHP version 8.2.20.
[FAIL] Debug mode is on.
[HELP] Set debug to false in /etc/passbolt/passbolt.php
[PASS] Full base url is set to https://vault.quero.com
SMTP settings
[HELP] You can try:
[PASS] 31 tables found.
When I try loggin in UI Web, return “check your email box”, but the messagem didn’t arrive.
Can you help?
The test using this command, it works!
bin/cake passbolt send_test_email --recipient=youremail@domain.com"
Hey @nicholasrab, can you look at this troubleshooting guide? It lists down common issues for email delivery.
https://www.passbolt.com/docs/hosting/troubleshooting/email/
Hey , @ishan ! Tks for response!
I’m try this steps… In column “sent” is blank.
Yeah so looks like the cron job is not setup. Which linux distribution are you using? Also, which guide/process you followed to install passbolt? Generally if you follow our official installation guide then the cronjob is already configured without you needing do anything.
Exactly! I’m using a base-app (custom chart) for deployment without configmap.
If mount the volumes that are in template and create the cronjobs, does it work?
My pod of cronjob email is up, loggin: “sending emails”
But when runs bin/cron in app container, return blank.
The cron.service until off. How to start this service?
@ishan Can you give me a hint?
I don’t know what to do…
Tks…
Hey @nicholasrab, I don’t have much idea about k8s/helm thing. But did you checked error logs? Is there anything in there?
@ishan log of cron:
2024-11-27 11:52:00 error: [InvalidArgumentException] The “Smtp” transport configuration does not exist in /usr/share/php/passbolt/vendor/cakephp/cakephp/src/Mailer/TransportFactory.php on line 85
Stack Trace:
  • /usr/share/php/passbolt/vendor/cakephp/cakephp/src/Mailer/TransportFactory.php:114
  • /usr/share/php/passbolt/vendor/cakephp/cakephp/src/Mailer/Mailer.php:494
  • /usr/share/php/passbolt/vendor/cakephp/cakephp/src/Mailer/Mailer.php:436
  • /usr/share/php/passbolt/vendor/cakephp/cakephp/src/Mailer/Mailer.php:221
  • /usr/share/php/passbolt/plugins/PassboltCe/EmailDigest/src/Service/SendEmailBatchService.php:74
  • /usr/share/php/passbolt/plugins/PassboltCe/EmailDigest/src/Service/SendEmailBatchService.php:64
  • /usr/share/php/passbolt/plugins/PassboltCe/EmailDigest/src/Command/SenderCommand.php:63
  • /usr/share/php/passbolt/vendor/cakephp/cakephp/src/Console/BaseCommand.php:190
  • /usr/share/php/passbolt/vendor/cakephp/cakephp/src/Console/CommandRunner.php:334
  • /usr/share/php/passbolt/vendor/cakephp/cakephp/src/Console/CommandRunner.php:172
  • /usr/share/php/passbolt/bin/cake.php:13
  • [main]:
www-data@passbolt-prod-5fcd8b9f5d-4bfm5:/usr/share/php/passbolt$ cat /var/log/passbolt/cron.log
Passbolt | Error
An Internal Error Has Occurred
The "Smtp" transport configuration does not exist
Could this be caused by using Auto-Tables?
Some of the Table objects in your application were created by instantiating "Cake\ORM\Table" instead of any other specific subclass.
This could be the cause for this exception. Auto-Tables are created for you under the following circumstances:
  • The class for the specified table does not exist.
  • The Table was created with a typo: $this->getTableLocator()->get('Articles');
  • The class file has a typo in the name or incorrect namespace: class Articles extends Table
  • The file containing the class has a typo or incorrect casing: Articles.php
  • The Table was used using associations but the association has a typo: $this->belongsTo('Articles')
  • The table class resides in a Plugin but no plugin notation was used in the association definition.
Please try correcting the issue for the following table aliases:
  • Actions
Hey @nicholasrab, this is unusual. The “Smtp” transport is already defined in the config/bootstrap.php file (see here), can you check this file and see if it contains this code?
Also, have you set EMAIL_DEFAULT_TRANSPORT env variable? If yes, can you try removing this env var and try without it? It’s used in the config/app.php so you might want to check it as well.
Hey @ishan , tks for response.
The file bootstrap.php contain the code.
I’m using theese env’s:
EMAIL_DEFAULT_TRANSPORT = Smtp
EMAIL_TRANSPORT_DEFAULT_CLASS_NAME = Smtp
EMAIL_TRANSPORT_DEFAULT_TLS = true
EMAIL_TRANSPORT_DEFAULT_HOST = 587
EMAIL_DEFAULT_FROM_NAME = passbolt
EMAIL_TRANSPORT_DEFAULT_TIMEOUT = 30
EMAIL_DEFAULT_FROM= x@domain.com
EMAIL_TRANSPORT_DEFAULT_PASSWORD = x@domain.com
EMAIL_TRANSPORT_DEFAULT_USERNAME = xpto@domain.com
This env(EMAIL_DEFAULT_TRANSPORT) was a key!! After remove, the emails started arrive
I’m glad that the issue got resolved. Enjoy passbolt :heart:
