Installation assistance
I have a fresh install of Passbolt CE installed under Ubuntu 22.04. I have read blogs etc for help but cannot get access to the install page after the software is installed.
There is no Passbolt.php file created as I can’t get to the install page.
nginx -t reports:
nginx -t
2024/11/01 11:54:36 [warn] 2153#2153: conflicting server name “_” on [::]:80, ignored
nginx: the configuration file /etc/nginx/nginx.conf syntax is ok
nginx: configuration file /etc/nginx/nginx.conf test is successful
Here are my config files:
/etc/passbolt# cat passbolt.default.php
<?php
 * Passbolt ~ Open source password manager for teams
 * Copyright (c) Passbolt SA (https://www.passbolt.com)
 * Licensed under GNU Affero General Public License version 3 of the or any later version.
 * For full copyright and license information, please see the LICENSE.txt
 * Redistributions of files must retain the above copyright notice.
 * @copyright     Copyright (c) Passbolt SA (https://www.passbolt.com)
 * @license       https://opensource.org/licenses/AGPL-3.0 AGPL License
 * @link          https://www.passbolt.com Passbolt(tm)
 * @since         2.0.0
 * PASSBOLT CONFIGURATION FILE TEMPLATE
 * By default passbolt tries to use the environment variables or falls back to the default values as
 * defined in default.php. You can use passbolt.default.php as a basis to set your own configuration
 * without using environment variables.
 * 1. copy/paste passbolt.default.php to passbolt.php
 * 2. set the variables in the App section
 * 3. set the variables in the passbolt section
 * To see all available options, you can refer to the default.php file, and modify passsbolt.php accordingly.
 * Do not modify default.php or you may break your upgrade process.
 * Read more about how to install passbolt: https://www.passbolt.com/help/tech/install
 * Any issue, check out our FAQ: https://www.passbolt.com/faq
 * An installation issue? Ask for help to the community: https://community.passbolt.com/
return [
     * DEFAULT APP CONFIGURATION
     * All the information in this section must be provided in order for passbolt to work
     * This configuration overrides the CakePHP defaults located in app.php
     * Do not edit app.php as it may break your upgrade process
    'App' => [
        // The fully qualified domain name (including protocol) to your application’s root
        // e.g. where the passbolt instance will be reachable to your end users.
        // This information is need to render images in emails for example.
        'fullBaseUrl' => 'https://www.passbolt.test',
        // OPTIONAL
        // You can specify the base directory the app resides in.
        // Useful if you are running passbolt in a subdirectory like example.com/passbolt
        // Ensure your string starts with a / and does NOT end with a /
        // 'base' => '/subdir'
    // Database configuration.
    'Datasources' => [
        'default' => [
            'host' => 'localhost',
            //'port' => 'non_standard_port_number',
            'username' => 'user',
            'password' => 'secret',
            'database' => 'passbolt',
    // Email configuration.
    'EmailTransport' => [
        'default' => [
            'port' => 25,
            'tls' => null,
            //'timeout' => 30,
            //'client' => null,
            //'url' => null,
    'Email' => [
        'default' => [
            'from' => ['passbolt@your_organization.com' => 'Passbolt'],
            //'charset' => 'utf-8',
            //'headerCharset' => 'utf-8',
     * DEFAULT PASSBOLT CONFIGURATION
     * This is the default configuration.
     * It enforces the use of ssl, and does not provide a default OpenPGP key.
     * If your objective is to try passbolt quickly for evaluation purpose, and security is not important
     * you can use the demo config example provided in the next section below.
    'passbolt' => [
        // GPG Configuration.
        'gpg' => [
            // If putenv is set to false, gnupg will use the default path ~/.gnupg.
            // For example :
            // - Apache on Centos it would be in '/usr/share/httpd/.gnupg'
            // - Apache on Debian it would be in '/var/www/.gnupg'
            // - Nginx on Centos it would be in '/var/lib/nginx/.gnupg'
            // - etc.
            //'keyring' => getenv("HOME") . DS . '.gnupg',
            //'putenv' => false,
            // Main server key.
            'serverKey' => [
                'fingerprint' => '',
                //'public' => CONFIG . 'gpg' . DS . 'serverkey.asc',
                //'private' => CONFIG . 'gpg' . DS . 'serverkey_private.asc',
 * DEMO CONFIGURATION EXAMPLE
 * Uncomment the lines below if you want to try passbolt quickly.
 * and if you are not concerned about the security of your installation.
 * (Don't forget to comment the default config above).
//    'debug' => true,
//    'passbolt' => [
//        'registration' => [
//            'public' => true
//        'ssl' => [
//            'force' => false,
//        'gpg' => [
//            'serverKey' => [
//                'fingerprint' => 'Removed',
//                'public' => CONFIG . DS . 'gpg' . DS . 'unsecure.key',
//                'private' => CONFIG . DS . 'gpg' . DS . 'unsecure_private.key',
/etc/nginx/sites-enabled# cat nginx-passbolt.conf
Passbolt.conf - Nginx configuration file to run the Passbolt software.
server {
    listen 443 ssl http2;
    # listen 443 ssl http2;
    listen [::]:80;
Managed by Passbolt
server_name _;
client_body_buffer_size 100K;
client_header_buffer_size 1K;
client_max_body_size 5M;
client_body_timeout 10;
client_header_timeout 10;
keepalive_timeout 5 5;
send_timeout 10;
index index.php;
Managed by Passbolt
include /etc/passbolt/nginx-ssl.conf;
location / {
location ~ .php$ {
try_files $uri =404;
include fastcgi_params;
fastcgi_pass unix:/run/php/php8.3-fpm.sock;
fastcgi_index index.php;
fastcgi_intercept_errors on;
fastcgi_split_path_info ^(.+.php)(.+)$;
fastcgi_param PHP_VALUE “upload_max_filesize=5M \n post_max_size=5M”;
/etc/nginx/sites-enabled# cat default
You should look at the following URL’s in order to grasp a solid understanding
of Nginx configuration files in order to fully unleash the power of Nginx.
https://www.nginx.com/resources/wiki/start/
https://www.nginx.com/resources/wiki/start/topics/tutorials/config_pitfalls/
https://wiki.debian.org/Nginx/DirectoryStructure
In most cases, administrators will remove this file from sites-enabled/ and
leave it as reference inside of sites-available where it will continue to be
updated by the nginx packaging team.
This file will automatically load configuration files provided by other
applications, such as Drupal or Wordpress. These applications will be made
available underneath a path with that package name, such as /drupal8.
Please see /usr/share/doc/nginx-doc/examples/ for more detailed examples.
Default server configuration
server {
listen 80 default_server;
listen [::]:80 default_server;
    # SSL configuration
    # listen 443 ssl default_server;
    # listen [::]:443 ssl default_server;
    # Note: You should disable gzip for SSL traffic.
    # See: https://bugs.debian.org/773332
    # Read up on ssl_ciphers to ensure a secure configuration.
    # See: https://bugs.debian.org/765782
    # Self signed certs generated by the ssl-cert package
    # Don't use them in a production server!
    # include snippets/snakeoil.conf;
    root /var/www/html;
    # Add index.php to the list if you are using PHP
    index index.html index.htm index.nginx-debian.html;
    server_name _;
    location / {
            # First attempt to serve request as file, then
            # as directory, then fall back to displaying a 404.
            try_files $uri $uri/ =404;
    # pass PHP scripts to FastCGI server
    #location ~ \.php$ {
    #       include snippets/fastcgi-php.conf;
    #       # With php-fpm (or other unix sockets):
    #       fastcgi_pass unix:/run/php/php7.4-fpm.sock;
    #       # With php-cgi (or other tcp sockets):
    #       fastcgi_pass 127.0.0.1:9000;
    # deny access to .htaccess files, if Apache's document root
    # concurs with nginx's one
    #location ~ /\.ht {
    #       deny all;
Virtual Host configuration for example.com
You can move that to a different file under sites-available/ and symlink that
to sites-enabled/ to enable it.
#server {
listen 80;
listen [::]:80;
server_name example.com;
root /var/www/example.com;
index index.html;
location / {
/etc/nginx/sites-available# cat nginx-passbolt.conf
server {
listen 80;
listen [::]:80;
Managed by Passbolt
server_name
send_timeout 10;
index index.php;
Managed by Passbolt
include PASSBOLT_SSL
location / {
location ~ .php$ {
fastcgi_pass unix:/run/php/PHP_SOCK;
/etc/nginx/sites-available# cat default
server {
    # SSL configuration
    root /var/www/html;
    server_name _;
    location / {
    #location ~ /\.ht {
    #       deny all;
#server {
listen 80;
listen [::]:80;
index index.html;
location / {
Please let me know what I messed up on :slight_smile: and if there are any other files that are needed.
Thank you
