Hi, I’m really sorry I have a question. I want to implement a master-slave switchover. I have now deployed passbolt on both VMS, synchronized the sql files, configuration files, and gpg backups, installed keepalived, and configured a virtual ip (which will be configured with a domain name later). I want to access this domain name to ensure high availability of the passbolt service. Which configuration should I change for each passbolt? Now I modify the/etc/passbolt/passbolt fullbaseurl in PHP for the virtual IP, I need in the/etc/nginx/conf. d/passbolt. conf modify inside?
Hi there,
Here’s what you need to adjust (I am guessing you are on a RPM distro):
- For the Passbolt configuration, the
fullBaseUrlin/etc/passbolt/passbolt.phpto use your domain name. - For the Nginx configuration, you need to update the
server_namedirective in/etc/nginx/conf.d/passbolt_ssl.confto match your domain name. - Configure a simple check script for keepalived to verify Passbolt is working properly (not just that the VM is up) by checking the
/healthcheck/statusendpoint.
Hope it helps.
Hello! Thank you very much for your prompt reply! Now I have completed all these based on your suggestions. Then I want to achieve master-slave synchronization of mariadb. However, I initially installed mariadb through the dependency installation script in the documentation. Do I need to install the database independently without using the script at the beginning? Or how should I configure it? Looking forward to your reply
