I have Passbolt (4.10.1) installed on a Debian 12 VM with PHP-FPM 8.2.26. I followed the tutorial available for the installation.
Since upgrading to version 4.10.1, there has been a strange slowdown in the application when I go to the Administration tab after first navigating to the Users tab.
I checked the error logs, and this message appears each time:
[error] 2048317#2048317: *18358 upstream timed out (110: Connection timed out) while reading response header from upstream, client: xx.xxx.xxx.xxx, server: _, request: "GET /app/administration/mfa HTTP/2.0", upstream:
I have reviewed the Nginx configuration, but it seems unlikely that it’s the cause since everything was working fine before this update.
This issue slows down the entire VM. If I perform this action and it causes a slowdown, it also impacts all other users at the same time.
I’m out of ideas on how to resolve this. HEALTHCHECK is all green
Thank you.
