Migration error on upgrade from 1.6.10 to 2.0.7
System:
Debian 4.9.65-3+deb9u2 (2018-01-04) x86_64 GNU/Linux
passbolt 1.6.10 with database schema 1.6.1 (./app/Console/cake Migrations.migration status)
www-data@passbolt:~/passbolt$ ./app/Console/cake Migrations.migration status
Cake Migration Shell
Application
Current version:
  #1498311597 1498311597_Migration_1.6.1
Latest version:
Migrations Plugin
Current version:
  #003 003_increase_class_name_length
Latest version:
and
$ cat app/Config/version.php  | grep number
'number' => '1.6.10'
After upgrade following this directions (https://help.passbolt.com/hosting/upgrade/ce/upgrade-ce.html)
I got stuck in the migrate step with this error:
www-data@passbolt:~/passbolt$ ./bin/cake passbolt migrate
 Running migration scripts.
using migration paths
 - /var/www/passbolt/config/Migrations
using seed paths
 - /var/www/passbolt/config/Seeds
using environment default
using adapter mysql
using database passbolt
 == 20180413171600 V202ForceColumnsCharset: migrating
Exception: SQLSTATE[42S22]: Column not found: 1054 Unknown column 'foreign_key' in 'comments' in [/var/www/passbolt/vendor/robmorgan/phinx/src/Phinx/Db/Adapter/PdoAdapter.php, line 338]
2018-06-11 15:32:30 Warning: The connection is going to be closed but there is an active transaction.
Looks like some migration steps are missing. Is it okay that the database version of the tag1.6.10 is 1.6.1 in the first place?
This is the healthcheck of my 1.6.10 installation:
www-data@passbolt:~/passbolt$ ./app/Console/cake passbolt healthcheck
 [PASS] PHP version 7.0.27-0+deb9u1
 [PASS] PCRE compiled with unicode support
 [PASS] The temporary directory and its content are writable
 [PASS] The public image directory and its content are writable
 [PASS] The core config file is present
 [PASS] The database config file is present
 [PASS] The email config file is present
 [PASS] Unique value set for security.cipherSeed
 [PASS] Full base url is set to https://passbolt.dienesgroup.local
  [HELP] stream_socket_client(): SSL operation failed with code 1. OpenSSL Error messages:
stream_socket_client(): Failed to enable crypto
stream_socket_client(): unable to connect to ssl://passbolt.dienesgroup.local:443 (Unknown error)
 [PASS] Configured to use a supported database backend
 [PASS] Not using a prefix for database tables
 [PASS] 23 tables found
 [PASS] PHP GPG Module is installed and loaded
 [PASS] The environment variable GNUPGHOME is set to /var/www/.gnupg
 [PASS] The directory /var/www/.gnupg containing the keyring is writable by the user the webserver is running as.
 [PASS] The public key file is defined in app/config.php and readable.
 [PASS] The private key file is defined in app/config.php and readable.
 [PASS] The server key fingerprint matches the one defined in app/config.php.
 [PASS] The server key defined in the app/Config.php is in the keyring.
 [FAIL] This installation is not up to date. Currently using 1.6.10 and it should be v2.0.7.
 [PASS] Passbolt is configured to force SSL use
 [PASS] App.fullBaseUrl is set to HTTPS
 Development Tools (optional)
 [PASS] Phpunit is installed
 [PASS] Phpunit version is 3.7.38
hello @saschaludwigdienes,
There is an issue indeed, as the migration process should not to start with the task
It should start with task 20170830064410_V162InitialMigration.php
So either the files in config/migrations are missing, or they cannot be run (or maybe you already ran them before with errors?). Check if the files are present, check the permissions, make sure there is nobody else connected to the db, try to revert to your original 1.6.10 database backup and run the migration scripts again.
