Share with group with web UI
Docker installation with latest-ce ( 4.9.0-1-ce)
So far I have a fully functionnal Passbolt. I have an admin user and some standard users. I did create some groups too, with users in it.
I can create secrets.
When I try to share secrets using the web UI, I can search and select users, but I can’t find any group.
So my question is : is this a normal limitation or a bug ? How can I share a password with a group ?
Regards
Hello @pguinet , welcome to our community :slight_smile:
You should be able to share secrets to users or groups as you can see below.
share-to-groups
Are you using PostgreSQL or MariaDB as the db container?
Also, could you share the dataCheck of the server?
docker exec -it <passbolt_container_id> su -s /bin/bash -c "/usr/share/php/passbolt/bin/cake passbolt datacheck --hide-success-details" www-data
Hi Antony,
I have a group named Infra, and when I try to search it, I receive this :
This group has been created by a user with admin rights. I’m myself only user.
Even the group creator cannot share with this group.
I did create another group while replying to you and I can see and share with this group.
Database is Postgresql.
Here the result of check :
Data check shell
  [PASS] Can validate: 29/29
  [PASS] Can validate: 0/0
  [PASS] Can encrypt: 4/4
  [PASS] Pass validation service checks: 4/4
  [PASS] Entity data and armored key data matches: 4/4
  [PASS] Is not expired: 4/4
  [PASS] Is armored key format valid: 4/4
  [PASS] Can validate: 2/2
  [PASS] Can validate: 4/4
  [PASS] Can validate: 3/3
  [PASS] Can validate: 5/5
Regards,
Hi @pguinet ,
thanks for the hint, we have spotted this issue which has been introduced with the v4.9.0, impairing Postgres users. The search is case sensitive on Postgres, so if you search for “nfra”, you should find your group.
We have a fix for that, that we are willing to ship in a 4.9.1 in the coming days. Keep being posted, it is coming soon.
Sorry for the inconvenience!
Juan
Thanks @pabloelcolombiano ,
Effectively, it works with ‘nfr’, but not with ‘Infr’ that I tried with no luck.
So I’ll wait for the 4.9.1.
Have a nice day.
For your information the v4.9.1 has been released today. This should fix your issue.
Thank you for reporting the issue, and for your patience!
Hi Pablo,
I confirm it works now.
Thanks for your help.
