Updating Passbolt-Docker from 3.2.1-CE to 4.1.1-CE throws some errors (PHP and GPG)
[X ] I have read the tutorials, help and searched for similar issues
[ X] I provide relevant information about my server (component names and versions, etc.)
[ X] I provide a copy of my logs and healthcheck
[ X] I describe the steps I have taken to trouble shoot the problem
[ X] I describe the steps on how to reproduce the issue
Hello community,
recently i’ve tried to update our Docker-Installtion (Version 3.2.1-CE running on RHEL8 via docker-compose) to 4.4.1-CE via docker-compose, by updating the docker-compose.yml file, where i just have exchanged the image-tag. Downloading and starting up the container works, but then the passbolt-container fails with some error messages regarding PHP and GPG.
it throws:
passbolt_1  | gpg: can't connect to the agent: End of file
passbolt_1  | gpg: error getting the KEK: No agent running
passbolt_1  | gpg: error reading '/etc/passbolt/gpg/serverkey_private.asc': No agent running
passbolt_1  | gpg: import from '/etc/passbolt/gpg/serverkey_private.asc' failed: No agent running
passbolt_1  | gpg: Total number processed: 0
passbolt_1  | gpg:              unchanged: 1
passbolt_1  | gpg:       secret keys read: 1
But when i try to update to a older 3.x version for example 3.3.1-CE this is working with no errors.
When i try to update to 3.4.0-CE it throws this error:
passbolt_1  | PHP Warning:  Use of undefined constant context - assumed 'context' (this will throw an Error in a future version of PHP) in /etc/passbolt/app.php on line 246
passbolt_1  | Exception: Undefined class constant 'FORMAT_MEDIUM'
passbolt_1  | In [/etc/passbolt/file_storage.php, line 18]
but no complaints about the key.
I haven’t found any helpful article on the net except this one:
https://community.passbolt.com/t/docker-not-start-after-upgrade-to-v4-problem-with-key-import/7825
so my questions are:
  1. Why do the PHP-related errors appear when updating 3.3.1 to 3.3.1- is there something missing in my config? (altaugh it’s working when updating from 3.2.1 to 3.3.1 but not when updating to 3.4.0)?
  2. Why is GPG not able to read/imort the serverkey when trying to startup version 4.4.1?
thanks a lot in advance!
I am starting up the containers with
docker-compose up
Output:
Starting passbolt_docker_db_1 ... done
Recreating passbolt_docker_passbolt_1 ... done
Attaching to passbolt_docker_db_1, passbolt_docker_passbolt_1
db_1        | 2023-07-20 11:07:26+00:00 [Note] [Entrypoint]: Entrypoint script for MariaDB Server 1:10.3.29+maria~focal started.
passbolt_1  | wait-for.sh: waiting for db:3306 without a timeout
passbolt_1  | wait-for.sh: db:3306 is available after 0 seconds
db_1        | 2023-07-20 11:07:27+00:00 [Note] [Entrypoint]: Switching to dedicated user 'mysql'
db_1        | 2023-07-20 11:07:27+00:00 [Note] [Entrypoint]: Entrypoint script for MariaDB Server 1:10.3.29+maria~focal started.
db_1        | 2023-07-20 11:07:27 0 [Note] mysqld (mysqld 10.3.29-MariaDB-1:10.3.29+maria~focal) starting as process 1 ...
db_1        | 2023-07-20 11:07:27 0 [Note] InnoDB: Using Linux native AIO
db_1        | 2023-07-20 11:07:27 0 [Note] InnoDB: Mutexes and rw_locks use GCC atomic builtins
db_1        | 2023-07-20 11:07:27 0 [Note] InnoDB: Uses event mutexes
db_1        | 2023-07-20 11:07:27 0 [Note] InnoDB: Compressed tables use zlib 1.2.11
db_1        | 2023-07-20 11:07:27 0 [Note] InnoDB: Number of pools: 1
db_1        | 2023-07-20 11:07:27 0 [Note] InnoDB: Using SSE2 crc32 instructions
db_1        | 2023-07-20 11:07:27 0 [Note] InnoDB: Initializing buffer pool, total size = 256M, instances = 1, chunk size = 128M
db_1        | 2023-07-20 11:07:27 0 [Note] InnoDB: Completed initialization of buffer pool
db_1        | 2023-07-20 11:07:27 0 [Note] InnoDB: If the mysqld execution user is authorized, page cleaner thread priority can be changed. See the man page of setpriority().
db_1        | 2023-07-20 11:07:27 0 [Note] InnoDB: 128 out of 128 rollback segments are active.
db_1        | 2023-07-20 11:07:27 0 [Note] InnoDB: Creating shared tablespace for temporary tables
db_1        | 2023-07-20 11:07:27 0 [Note] InnoDB: Setting file './ibtmp1' size to 12 MB. Physically writing the file full; Please wait ...
db_1        | 2023-07-20 11:07:27 0 [Note] InnoDB: File './ibtmp1' size is now 12 MB.
db_1        | 2023-07-20 11:07:27 0 [Note] InnoDB: 10.3.29 started; log sequence number 719122280; transaction id 915013
db_1        | 2023-07-20 11:07:27 0 [Note] InnoDB: Loading buffer pool(s) from /var/lib/mysql/ib_buffer_pool
db_1        | 2023-07-20 11:07:27 0 [Note] Plugin 'FEEDBACK' is disabled.
db_1        | 2023-07-20 11:07:27 0 [Note] Server socket created on IP: '::'.
db_1        | 2023-07-20 11:07:27 0 [Warning] 'proxies_priv' entry '@% root@c84244d66dc7' ignored in --skip-name-resolve mode.
db_1        | 2023-07-20 11:07:27 0 [Note] Reading of all Master_info entries succeeded
db_1        | 2023-07-20 11:07:27 0 [Note] Added new Master_info '' to hash table
db_1        | 2023-07-20 11:07:27 0 [Note] mysqld: ready for connections.
db_1        | Version: '10.3.29-MariaDB-1:10.3.29+maria~focal'  socket: '/var/run/mysqld/mysqld.sock'  port: 3306  mariadb.org binary distribution
db_1        | 2023-07-20 11:07:28 0 [Note] InnoDB: Buffer pool(s) load completed at 230720 11:07:28
passbolt_1  | gpg: keybox '/var/lib/passbolt/.gnupg/pubring.kbx' created
passbolt_1  | gpg: /var/lib/passbolt/.gnupg/trustdb.gpg: trustdb created
passbolt_1  | gpg: key 0B778AC7518CB0F4: public key "Passbolt default user <passbolt@yourdomain.com>" imported
passbolt_1  | gpg: Total number processed: 1
passbolt_1  | gpg:               imported: 1
passbolt_docker_passbolt_1 exited with code 2
My docker-compose.yml files looks like this:
version: '3.2'
  db:
    image: mariadb:10.3
    env_file:
      - env/mysql.env
      - "127.0.0.1:3306:3306"
    image: passbolt/passbolt:4.1.1-1-ce
        - http_proxy=http://proxy01.company.at:8080
        - https_proxy=http://proxy01.company.at:8080
    tty: true
    depends_on:
      - db
    env_file:
      - env/passbolt.env
      - images_volume:/usr/share/php/passbolt/webroot/img/public
      - config_volume:/etc/passbolt
      - 80:80
      - 443:443
  database_volume:
  gpg_volume:
  images_volume:
  config_volume:
Healthcheck - GPG-part (from productive working 3.2.1-CE):
 [HELP] you can try:
can someone help us out? - thanks a lot in advance!
Hello @compass ,
Regarding the issue on the healthcheck have you tried to run source /etc/environment ?
Hello @antony,
did it right now, this solved all the GPG-related errors, but then i stopped that running container and updated it to 4.1.1 it comes again with this error:
db_1        | 2023-07-20 11:38:29 0 [Note] InnoDB: Buffer pool(s) load completed at 230720 11:38:29
Can you make sure to check if the gpg key has no issues such as expiration date, expired and so on?
Hi @antony ,
should be ok i guess?
root@1ccfe6707ef1:/etc/passbolt/gpg# gpg --list-keys
gpg: WARNING: unsafe ownership on homedir '/var/lib/passbolt/.gnupg'
pub   rsa2048 2021-06-22 [SC]
      B524CE7BB3DC46DC5C3C1A150B778AC7518CB0F4
uid           [ unknown] Passbolt default user <passbolt@yourdomain.com>
sub   rsa2048 2021-06-22 [E]
root@1ccfe6707ef1:/var/lib/passbolt/.gnupg# gpg --edit-key passbolt
gpg (GnuPG) 2.2.12; Copyright (C) 2018 Free Software Foundation, Inc.
This is free software: you are free to change and redistribute it.
There is NO WARRANTY, to the extent permitted by law.
Secret key is available.
sec  rsa2048/0B778AC7518CB0F4
     created: 2021-06-22  expires: never       usage: SC
     trust: unknown       validity: unknown
ssb  rsa2048/7194038C17E4C494
     created: 2021-06-22  expires: never       usage: E
[ unknown] (1). Passbolt default user <passbolt@yourdomain.com>
as it doesn’t show expired, right?
gpg: WARNING: unsafe ownership on homedir ‘/var/lib/passbolt/.gnupg’
/var/lib/passbolt/.gnupg/pubring.kbx can prevent the signature to work.
Could you share the rights and permissions on /var/lib/passbolt/.gnupg ?
@antony
root@1ccfe6707ef1:/var/lib/passbolt# ls -lah
total 0
drwxr-xr-x 1 www-data www-data  31 Jun  4  2021 .
drwxr-xr-x 1 root     root      35 Jun  4  2021 ..
drwx------ 1 www-data www-data 202 Jul 20 12:25 .gnupg
drwxr-xr-x 1 www-data www-data  34 Jul 20 12:25 tmp
root@1ccfe6707ef1:/var/lib/passbolt# ls -lahS .gnupg/
total 16K
-rw-r--r-- 1 www-data www-data 1.5K Jul 20 12:25 pubring.kbx
-rw------- 1 www-data www-data 1.2K Jul 20 12:25 trustdb.gpg
-rw------- 1 www-data www-data  600 Jul 20 12:25 random_seed
drwx------ 2 www-data www-data  110 Jul 20 12:25 private-keys-v1.d
-rw------- 1 www-data www-data   32 Jul 20 12:25 pubring.kbx~
drwxr-xr-x 1 www-data www-data   31 Jun  4  2021 ..
srwx------ 1 www-data www-data    0 Jul 20 12:25 S.gpg-agent
srwx------ 1 www-data www-data    0 Jul 20 12:25 S.gpg-agent.browser
srwx------ 1 www-data www-data    0 Jul 20 12:25 S.gpg-agent.extra
srwx------ 1 www-data www-data    0 Jul 20 12:25 S.gpg-agent.ssh
@antony
looks about right, isn’t it?
We are investing this issue on our side, i’ll let know you once I have more information
okay thank you! still had no luck yet
hi @antony maybe any update on this? thanks!
Hello!
We are unable to reproduce your gpg issue. However, I have noticed you are mounting the /etc/passbolt and /etc/passbolt/gpg this is conflicting and could cause issues, you should remove the volume for /etc/passbolt and keep the gpg one only
If you are mounting custom config files, mount them specifically.
I also noticed that you are mounting the images volume that is not necessary since v3.2.0. I suggest you take a look at the most recent docker-compose as a reference: https://github.com/passbolt/passbolt_docker/blob/master/docker-compose/docker-compose-ce.yaml
It could be a docker version issues.
Could you share the output of those two commands
cat /etc/os-release
docker --version
hi,
i have similar error, with a Debian 9 (stretch) and docker 19.03.15
@rpo-fr both Debian 9 and docker 19.03 have been end of life for quite some time. I’d recommend getting on to a newer version and seeing if that helps here.
Another user mentioned that on a newer version they resolved a similar issue
