SQL Errors right after install via docker
Hello folks,
first up some information about my setup:
Server running on Debian 9.4. On there I use Docker with one container for mysql 8 and one container with the :latest passbolt. I did install passbolt now several times and figured some important stuff out but now I’m stuck on one error I can’t get rid of. On the main server I’ve a self-signed Certificate and https:// is so far working fine. I wired port 443 -> 5081 and call on my browser passbolt with the base url: https://passbolt.company.local:5081
Here is my healthcheck:
 [PASS] PHP version 7.2.6.
 [FAIL] Debug mode is on.
 [PASS] Full base url is set to https://passbolt.ilgenfritz.local:5081
  [HELP] fopen(): Peer certificate CN=`www.passbolt.local' did not match expected CN=`passbolt.ilgenfritz.local'
fopen(https://passbolt.ilgenfritz.local:5081/healthcheck/status.json): failed to open stream: operation failed
 [PASS] 18 tables found
 [FAIL] Could not connect to passbolt repository to check versions. It is not possible check if your version is up to date.
  4 error(s) found. Hang in there!
I’m not really sure why SSL is failing, I had no time yet to look into that. First I wanted to get rid of the other problem. But if someone has an idea where to look at :slight_smile: that would be nice as well.
Now the main issue I have:
I did the install, set up the gpg key and email. I was able to create the admin user and setup the account. Right after login I got every time I clicked somewhere 2 internal server errors. With “docker attach passbolt” I also saw only the 500 error but no description. After turning debug mode on I got this: Error SQLSTATE[42000]: Syntax error or access violation: 1064 You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near ‘groups Groups LEFT JOIN groups_users GroupsUsers ON Groups.id = (GroupsUsers.gro’ at line 1
Also I’m getting this in the webbrowser console:
Failed to load resource: the server responded with a status of 500 (Internal Server Error)
steal.production.js?v=2.1.0:11 Potentially unhandled rejection [3] {"code":500} (WARNING: non-Error used)
undefined.c @ steal.production.js?v=2.1.0:11
:5081/resources.json?api-version=v2?silentLoading=false&contain%5Bcreator%5D=1&contain%5Bfavorite%5D=1&contain%5Bmodifier%5D=1&contain%5Bsecret%5D=1&contain%5Bpermission%5D=1&contain%5Btag%5D=1&order%5B%5D=Resource.modified+DESC:1 Failed to load resource: the server responded with a status of 500 (Internal Server Error)
:5081/groups.json?contain%5Bmy_group_user%5D=1&order%5B%5D=Group.name+ASC&filter%5Bhas-users%5D=03334d9d-460f-4a3f-946f-ad3713979455&api-version=v2:1 Failed to load resource: the server responded with a status of 500 (Internal Server Error)
steal.production.js?v=2.1.0:11 Potentially unhandled rejection [8] {"code":500} (WARNING: non-Error used)
I’m really not sure what I’ve done. It is a clean install with the latest passbolt. Any help would be much appriciated :slight_smile:
Thank you for your help already :slight_smile:
kind regards
Florian
[? ] I describe the steps on how to reproduce the issue
@flogalen it’s possible there are some issues with SQL on Mysql8, can you try to use mariadb or mysql5 instead?
I did a complete new install with mysql 5.7 and now I don’t have any Internal Server Errors :smile:
only thing left now is that my healthcheck is acting up, but still everything works just fine. I could not figure out the SSL issue or the repository connection.
Thank you for your quick response. Guess I’ll stick to mysql 5.7 :slight_smile:
