1 - seems not took the patch version (config/version.php)
2 - issue with email id
=> directly from the ‘build upgrade’ :
[FAIL] This installation is not up to date. Currently using 2.12.0 and it should be v2.12.1.
probably here since the first install (discover with the check):
=> how to do it
< [11:04:33] - root@vault:/var/www/passbolt >
=>su -s /bin/bash -c “./bin/cake passbolt healthcheck” www-data
// _,///./_//__/
[PASS] PHP version 7.3.14-1~deb10u1.
[PASS] Full base url is set to https://vault.pra.rip
[PASS] 23 tables found
< [11:05:27] - root@vault:/var/www/passbolt >
=>git status
On branch tags/v2.12.2
nothing to commit, working tree clean
< [11:05:36] - root@vault:/var/www/passbolt >
thank you for your help
pra
