Could not verify server key. There was an error during authentication
Hi. I’ve a Passbolt container running in GKE, using the latest passbolt image, and done with the setup. Everything is good but there is this error sign in the home (login by the extension is looks to be correct). There’s nothing on passbolt home logs, I’ve changed the PASSBOLT_KEY_NAME, and PASSBOLT_KEY_EMAIL but it didn’t worked.
Can someone help me?
Hi @Negreiros,
What does the healtcheck say?
./bin/cake passbolt healthcheck (from the passbolt directory)
Hi @kevin. Sorry, i’ve forgotted.
  [HELP] sudo su -s /bin/bash -c "gpg --list-keys --fingerprint --home /home/www-data/.gnupg" www-data | grep -i -B 2 'SERVER_KEY_EMAIL'
  [HELP] you can try:
  [HELP] sudo su -s /bin/bash -c "gpg --home /home/www-data/.gnupg --import /var/www/passbolt/config/gpg/serverkey_private.asc" www-data
 [FAIL] This installation is not up to date. Currently using 2.12.0 and it should be v2.12.1.
  6 error(s) found. Hang in there!
@kevin, maybe I have generated the Server Key with Name/Email defaults (Passbolt and passbolt@yourdomain). Is there a process to generate new ones and do the change without having to clean up my database?
Indeed, it looks like your key is not valid, probably due to the email your provided.
If it is a fresh installation, then you should be able to change your key without cleaning your db.
Thank you, @kevin! Is there any documentation on how to change it? I couldn’t find it
@Negreiros, I would need to have more details on your installation.
I suspect that you are using the official passbolt CE docker container (since you are on GKE) ? If that’s the case, then you will just need to generate a new key, change the fingerprint in the config and run your container again.
If you are not using the docker container, then you will need to generate a new key and put it where passbolt can access it (usually in config/gpg), then modify the config file to edit the gpg section with the correct file name and fingerpint. Then run the healthcheck again to see if everything is fine.
Let me know if any of this works.
