Recently I needed to do a restore for the first time, I also took the time to upgrade to newer docker image versions. My Passbolt instance is started with docker compose, so 1 file for both the DB and Passbolt.
To perform the restore I followed the guide mentioned here: Passbolt Help | Migrate an existing Passbolt CE to a new Docker
Everything went ok . But I today I needed to reboot the server… and now I think the restore description is not ok or not complete? Because the DB container won’t start!
My docker compose file still contains the added entry for the SQL file injection, in the volumes part.
- /home/depechie/passbolt/backup/20231029/backup.sql:/docker-entrypoint-initdb.d/dump.sql
And when I try to manually start the passbolt-db container with docker start I now get following exception:
Error response from daemon: failed to create task for container: failed to create shim task: OCI runtime create failed: runc create failed: unable to start container process: error during container init: error mounting "/home/depechie/passbolt/backup/20231029/backup.sql" to rootfs at "/docker-entrypoint-initdb.d/dump.sql": mount /home/depechie/passbolt/backup/20231029/backup.sql:/docker-entrypoint-initdb.d/dump.sql (via /proc/self/fd/6), flags: 0x5000: not a directory: unknown: Are you trying to mount a directory onto a file (or vice-versa)? Check if the specified host path exists and is the expected type
Does this mean I needed first to alter the compose file and remove the restore actions before I can start the container again?
Also in the passbolt section the restore procedure talks about adding the gpg server key fingerprint, but I guess that can stay even after the restore?
Anyone has a better detail on how to actually finish a restore correctly?
And what are my options now to get things working again? Again do a full reinstall and restore?
Or can I fix the current issue somehow and still have access to my instance?
Some details of my compose file
image: mariadb:10.11
image: passbolt/passbolt:4.4.2-1-ce
