How to enable MFA on OnPremise Passbolt
[ X] I have read intro post: About the Installation Issues category
[ X] I have read the tutorials, help and searched for similar issues
[ X] I provide relevant information about my server (component names and versions, etc.)
[ X] I provide a copy of my logs and healthcheck
[ X] I describe the steps I have taken to trouble shoot the problem
[ X] I describe the steps on how to reproduce the issue
We have Communitiy, OnPremise 3.5.0. How can I enable MFA? When I get to the Administration area (since I am an admin) I dont see any security-related options. Can you please help?
thank you.
Hi @mlakatamitis ,
If you are on 3.5 (version from January 2022) you should consider update your instance to benefit from security updates and as well to get access to MFA (since 3.9.0) and folders (since 3.12)
follow the guide corresponding to your installation: Passbolt Help | Update
Also, have a look at the release not of the 3.5 since the keys of package expired last year and we updated them. The procedure to follow is here: Passbolt Help | Wide Open
Max
Thanks Max,
Updating our Passbolt worked fine. However, I cannot find how to enforce the MFA policy for all my users. In addition to this, is there any way to enforce the sessions to expire, let’s say, every 5 minutes of idle time? I only want my users to login with MFA, get their password, and if they forget logging out, they should be forced-logging out.
thank you again
For MFA
For session expiration
