Hello, we are having a problem with our passbolt, it is in a linux virtual machine, this machine was closed and would not start, after getting into recovery mode I saw that the disk was full, I did a cleaning and I could access, but to access the server does not start, it tells me that it can not verify the key, if I put to update the server I get the following error
Hello @quetebe and welcome to the forum!
Have you checked the database credentials?
Maybe they were pasted incorrectly or the machine running the Passbolt instance doesn’t have access to the database server.
Hi, I have given permission to all users in all passbolt folders in case that was the problem, and the credentials have not been changed, also I am not clear which ones they have to match with I suppose, if I go into the passbolt.php file it has the keys well I put in.
