Dear Passbolt Team,
I changed the certifiacte (from self-signed to wildcard), modified the config files in /etc/ngnix/conf.d and changed fullBaseURL in /var/www/passbolt/config/passbolt.php.
If I access the new URL i have to recover my account. When Passbolt sends me the recover-email i get the error “500 An Internal Error Has Occured”.
The error seemed strange to me, since i only changed the certificate. so i googled a bit but didnt found anything helpfull.
Healthcheck told me, that the certifactes arent correct (which could be a false positive) and that jwt direcotry is writable and a JWT Key is missing.
since I had created a snapshot, I had reset the VM back to the point where everything worked and can use passbolt again. I tried to recover my account in another browser, get the link from our server and the same error occured.
Healthcheck: the same.
[PASS] PHP version 7.4.24.
[FAIL] The temporary directory and its content are not writable, or are executable.
[HELP] you can try:
[HELP] sudo chown -R www-data:www-data /var/www/passbolt/tmp/
[HELP] sudo chmod -R 775 $(find /var/www/passbolt/tmp/ -type d)
[HELP] sudo chmod -R 664 $(find /var/www/passbolt/tmp/ -type f)
[PASS] Full base url is set to https://SERVERNAME
[PASS] 37 tables found
[PASS] Using latest passbolt version (3.5.0).
[FAIL] The /var/www/passbolt/config/jwt/ directory should not be writable.
[HELP] You can try:
[HELP] sudo chown -R www-data:www-data /var/www/passbolt/config/jwt/
[HELP] sudo chmod 550 /var/www/passbolt/config/jwt/
[HELP] sudo chmod 440 $(find /var/www/passbolt/config/jwt/ -type f)
[FAIL] A valid JWT key pair is missing
[HELP] Run the create JWT keys script to create a valid JWT secret and public key pair:
[HELP] sudo su -s /bin/bash -c "/var/www/passbolt/bin/cake passbolt create_jwt_keys" www-data
[FAIL] 5 error(s) found. Hang in there!
i looked up the error.log and this error keeps repeating:
2022-02-15 12:22:33 Error: Fatal Error (1): Trait 'App\Controller\Setup\SetupControllerTrait' not found in [/var/www/passbolt/src/Controller/Setup/RecoverStartController.php, line 30]
2022-02-15 12:22:33 Error: [Cake\Error\FatalErrorException] Trait 'App\Controller\Setup\SetupControllerTrait' not found in /var/www/passbolt/src/Controller/Setup/RecoverStartController.php on line 30
Request URL: /setup/recover/7ec16c1b-a653-469c-9eac-c6cfc371e27f/57c484f8-d162-4a0e-b914-67742d741e85
And now i have no idea what i could do.
Any Ideas? We updated the server maybe a month ago, could this be a part of the problem? How can I fix this?
Hi @hen Using the healthcheck, the next step is to follow the lines that say HELP after lines that say FAIL. Right at the top of the output is a mention of the temp folder not being configured right, so those following HELP lines can guide you regarding folder permissions.
Try to work through those and resolve the FAILs and that should help with overall functionality and troubleshooting if you still have problems.
It seems you have rights problems with your passbolt temporary folder. You should execute the commands written below the error to fix rights / ownership.
And also with JWT authentication:
You should never run ./bin/cake commands as root user but as the web server user of your server, I guess www-data for you.
Once your files rights fixed, you should execute and send us the output of these commands:
[PASS] The /var/www/passbolt/config/jwt/ directory is not writable.
Data check shell
[PASS] Can validate: 1378/1378
[PASS] Can validate: 0/0
[PASS] Can encrypt: 7/7
[PASS] Can validate: 7/7
[PASS] Can validate: 12/12
[PASS] Can validate: 8/8
[PASS] Can validate: 616/616
[PASS] Can validate: 2864/2864
In the Healthcheck its still the certificate, but it is valid, I can access the URL without a problem. I access the URL and can get a email for revoery. the link in the mail doesnt work and I get the error “An Internal Error has Occurred Error 500”. Its self signed - shouldnt be a problem? I will exchange the self-signed certificate for a wildcard anyway (after the problem is solved).
what does the “cleanup” error mean?
Okay so i migrated from install scripts to ubunti package and the server is back online, but if i try to login i have to verify the server key and can continue to login. but after the password i get the messagen:
Sorry, you have not been signed in.
Something went wrong, the sign in failed with the following error:
The authentication failed.
I run a healtcheck and get an Error in the GPG Config
[HELP] you can try:
[HELP] sudo su -s /bin/bash -c "gpg --home /var/lib/passbolt/.gnupg --import /etc/passbolt//gpg/serverkey_private.asc" www-data
To Fix this i used: sudo su -s /bin/bash -c “gpg --home /var/lib/passbolt/.gnupg --import /etc/passbolt/gpg/serverkey_private.asc” www-data
But still with the authentication error. I cleared the cache. I logged out and tried to recovery my account. When I upload my private key i get the message: “This key does not match any account.”
sudo -H -u www-data bash -c "/usr/share/php/passbolt/bin/cake passbolt datacheck --hide-success-details"
Data check shell
[PASS] Can validate: 1391/1391
[PASS] Is not expired: 7/7
[PASS] Is armored key format valid: 7/7
[PASS] Is email unique: 7/7
i checked the permissions in the key ring with
sudo -H -u www-data bash -c "ls -la /var/lib/passbolt/.gnupg"
total 52
drwx------ 3 www-data www-data 4096 Feb 19 20:20 .
drwxr-xr-x 4 www-data www-data 4096 Feb 19 19:47 ..
drwx------ 2 www-data www-data 4096 Feb 19 20:05 private-keys-v1.d
-rw-rw-r-- 1 www-data www-data 13719 Feb 19 20:10 pubring.kbx
-rw-rw-r-- 1 www-data www-data 12328 Feb 19 20:10 pubring.kbx~
-rw------- 1 www-data www-data 600 Feb 19 20:20 random_seed
srwx------ 1 www-data www-data 0 Feb 19 19:55 S.gpg-agent
srwx------ 1 www-data www-data 0 Feb 19 19:55 S.gpg-agent.browser
srwx------ 1 www-data www-data 0 Feb 19 19:55 S.gpg-agent.extra
srwx------ 1 www-data www-data 0 Feb 19 19:55 S.gpg-agent.ssh
-rw------- 1 www-data www-data 1200 Feb 19 19:55 trustdb.gpg
sudo -H -u www-data bash -c "gpg --list-keys --home=/var/lib/passbolt/.gnupg"
/var/lib/passbolt/.gnupg/pubring.kbx
pub rsa4096 2018-03-26 [SC]
changed
uid [ unknown] Passbolt License (Passbolt License) <license@passbolt.com>
sub rsa4096 2018-03-26 [E]
pub rsa2048 2020-12-22 [SC]
changed
uid [ unknown] changed <passbolt@changed>
sub rsa2048 2020-12-22 [E]
**and all other users are listed**
/etc/passbolt$ sudo su -s /bin/bash -c "gpg --list-secret-keys" www-data
gpg: WARNING: unsafe permissions on homedir '/home/www-data/.gnupg'
/home/www-data/.gnupg/pubring.kbx
sec rsa2048 2020-12-22 [SC]
**changed: is the same as seen on the loginscreen and old server**
uid [ unknown] office-passbolt01 <passbolt@changed>
ssb rsa2048 2020-12-22 [E]
@hen Yes, but on the other homedir like in the previous command you were showing. sudo -H -u www-data bash -c "gpg --list-keys --home=/var/lib/passbolt/.gnupg"
GPG authentication error can occur also if your server is not well synchronized with a time server (NTP).
You can check is systemd-timesyncd is running:
sudo systemctl status systemd-timesyncd.service
● systemd-timesyncd.service - Network Time Synchronization
Loaded: loaded (/lib/systemd/system/systemd-timesyncd.service; enabled; vendor preset: enabled)
Active: active (running) since Mon 2022-02-21 08:10:59 UTC; 4s ago
Docs: man:systemd-timesyncd.service(8)
Main PID: 1483 (systemd-timesyn)
Status: "Initial synchronization to time server 91.189.89.198:123 (ntp.ubuntu.com)."
Tasks: 2 (limit: 1071)
Memory: 1.3M
CGroup: /system.slice/systemd-timesyncd.service
└─1483 /lib/systemd/systemd-timesyncd
Feb 21 08:10:59 ubuntu2004 systemd[1]: Starting Network Time Synchronization...
Feb 21 08:10:59 ubuntu2004 systemd[1]: Started Network Time Synchronization.
Feb 21 08:11:00 ubuntu2004 systemd-timesyncd[1483]: Initial synchronization to time server 91.189.89.198:123 (ntp.ubuntu.com).
If you execute the date command, it must returns the same date and time than the https://time.is website.
Healthcheck seems fine, the SSL Error shouldnt be the problem?:
sudo -H -u www-data bash -c "/usr/share/php/passbolt/bin/cake passbolt healthcheck"
[sudo] password for :
[PASS] Full base url is set to https://server
Wrong timezone was set, changed it and rebootet the server. output from time service now:
Active: active (running) since Mon 2022-02-21 09:51:15 CET; 2min 33s ago
Main PID: 676 (systemd-timesyn)
Status: "Initial synchronization to time server 91.189.94.4:123 (ntp.ubuntu.com)."
Tasks: 2 (limit: 2178)
Memory: 1.8M
└─676 /lib/systemd/systemd-timesyncd
Feb 21 09:51:15 office-passbolt01 systemd[1]: Starting Network Time Synchronization...
Feb 21 09:51:15 office-passbolt01 systemd[1]: Started Network Time Synchronization.
Feb 21 09:51:18 office-passbolt01 systemd-timesyncd[676]: Network configuration changed, trying to establish connection.
Feb 21 09:51:20 office-passbolt01 systemd-timesyncd[676]: Network configuration changed, trying to establish connection.
Feb 21 09:51:50 office-passbolt01 systemd-timesyncd[676]: Initial synchronization to time server 91.189.94.4:123 (ntp.ubuntu.com).
No, the SSL error shouldn’t be the problem. Do you still have this issue while trying to connect ?
If yes, it seems your private key is not the good one. You can check your private key by upload it to your passbolt server, or any Linux / MacOS machine. I assume it is named “passbolt_private.asc”.
$ gpg --show-keys passbolt_private.asc
sec# rsa2048 2021-08-16 [SC]
FD2CBE35090BBE2B5066EEA7ADBE777C62E90E6A
uid John Doe <john@doe.com>
ssb# rsa2048 2021-08-16 [E]
You should see your name and email address. And you should find the displayed fingerprint in the passbolt OpenPGP keyring:
And if you execute this request in mysql, do you get results ?
SELECT * FROM gpgkeys WHERE fingerprint = "your-key-fingerprint" \G
If yes, you should be able to connect.
If you still not able, which error message is displayed ? Do you have any other error message in /var/log/passbolt/error.log ? Maybe should you check if date and time on your workstation are correct too.
You can touch error.log in the /var/log/passbolt directory and make sure it’s owned by webserver user.
FYI this error is common and expected:
Error: [Authentication\Authenticator\UnauthenticatedException] Authentication is required to continue in /usr/share/php/passbolt/vendor/cakephp/authentication/src/Controller/Component/AuthenticationComponent.php on line 177
