HTTP to HTTP configuration problem
[ x ] I have read intro post: About the Installation Issues category
[ x ] I have read the tutorials, help and searched for similar issues
[ x ] I provide relevant information about my server (component names and versions, etc.)
[ x ] I provide a copy of my logs and healthcheck
[ x ] I describe the steps I have taken to trouble shoot the problem
[ x ] I describe the steps on how to reproduce the issue
Description:
I have a question about redirecting from HTTP to HTTPS.
If I’m using https://passbolt.domain.com it works correctly but if I type in browser “passbolt.domain.fun”
it does not redirect to HTTPS.
Domain and certificate:
  • I have my own certificate and domain.
Passbolt version and environment:
  • Docker container
  • Version: 3.2.1-2-ce-non-root
What I’ve done:
  • Installed Passbolt docker image
  • In the folder /etc/ssl/certs I’ve copied my certificate and key
  • Restart the docker container
Probably this is a configuration issue (from my side) but I cannot found any answers on how to configure it properly.
So, my questions are:
  1. Where passbolt stores configuration for nginx inside the docker container?
  2. Do I have to change ngxinx configuration to be able to redirect from HTTP to HTTPS?
Also, I’ve tried to use this: Passbolt Help | Manual HTTPS configuration on Debian and Ubuntu with user provided certificates
but it does not help me.
Hi @solaire,
You’re right, I got the same issue, and only with docker. If you have a look at the browser debug console, it seems related to some CORS issue:
While waiting this to be fixed, you can edit and bind mount a modified version of /etc/nginx/snippets/passbolt-ssl.conf file by adding this somewhere in the file content:
  if ($scheme = http) {
Thus, if http scheme is detected, your request will be redirected to its https version :slight_smile:
@AnatomicJC Fantastic!
This is what I’ve needed :slight_smile:
Thank you :slight_smile:
