Debian packet not working after upgrade PHP and PB 4.0
[v ] I have read intro post: About the Installation Issues category
[v ] I have read the tutorials, help and searched for similar issues
[v ] I provide relevant information about my server (component names and versions, etc.)
[v ] I provide a copy of my logs and healthcheck
[v ] I describe the steps I have taken to trouble shoot the problem
[v ] I describe the steps on how to reproduce the issue
I have a Debian server, and installed passbolt a year ago via the package, and it has been working fine.
for every update published i follow the page: Passbolt Help | Update passbolt on Debian
for some reason the procedure stopped working for me? after I do “sudo apt update” I see the package when I run “apt list --upgradable” :
Listing… Done
passbolt-ce-server/buster 4.0.2-1 all [upgradable from: 3.12.2-1]
N: There are 34 additional versions. Please use the ‘-a’ switch to see them.
root@pb:~#
but it doesn’t install the new version when I run “sudo apt upgrade” can anyone help me?
is it because of the PHP version? Can I just install the new version?
root@pb:~# sudo -H -u www-data bash -c “/usr/share/php/passbolt/bin/cake passbolt healthcheck”
 [FAIL] PHP version is too low, passbolt need PHP 7.4 or higher.
 [PASS] Full base url is set to https://pb.mcs-nl.com
 [PASS] 30 tables found
 [FAIL] This installation is not up to date. Currently using 3.12.2 and it should be v4.0.0.
 [WARN] The deprecated self registration public setting was found in /etc/passbolt/passbolt.php.
 [HELP] You may remove the "passbolt.registration.public" setting.
 SMTP Settings
Hello @pimzwagerMCS,
I noticed that you are encountering an issue with Passbolt. The error message states that your PHP version is too low and Passbolt requires PHP 7.4 or higher to function properly. To resolve this, you need to update your PHP version. Based on the release v4.00 announcement, you need to update your PHP installation to meet this requirement.
After successfully updating your PHP version to 7.4 or higher, you should be able to use Passbolt version 4.0.0 without any issues. If you have any further questions or encounter any difficulties during the process, feel free to ask for assistance.
If your OS only has php7.4 you should install the ondrej ppa
check your default php version by running:
php -version
set default php by running
sudo update-alternatives --config php
Select the version you want as default.
PHP is now apdated, i updated passbolt but now it’s not working anymore:
/ _
//./_//__/
[PASS] PHP version 8.2.6.
[FAIL] Could not reach the /healthcheck/status with the url specified in App.fu llBaseUrl
[PASS] The directory /var/lib/passbolt/.gnupg containing the keyring is writabl e by the webserver user.
[PASS] The public key file is defined in /etc/passbolt/passbolt.php and readabl e.
[PASS] The private key file is defined in /etc/passbolt/passbolt.php and readab le.
[PASS] The server key fingerprint matches the one defined in /etc/passbolt/pass bolt.php.
[PASS] The server public key defined in the /etc/passbolt/passbolt.php (or envi ronment variables) is in the keyring.
[PASS] Using latest passbolt version (4.0.2).
[WARN] The deprecated self registration public setting was found in /etc/passbo lt/passbolt.php.
[HELP] You may remove the “passbolt.registration.public” setting.
SMTP Settings
[HELP] Set the PASSBOLT_SECURITY_SMTP_SETTINGS_ENDPOINTS_DISABLED environment v ariable to true.
[HELP] Or set passbolt.security.smtpSettings.endpointsDisabled to true in /etc/ passbolt/passbolt.php.
if you updated php you’ll also want to make a change in the nginx config /etc/nginx/sites-enabled/nginx-passbolt.conf
There is a line
fastcgi_pass unix:/run/php/php7.3-fpm.sock;
you’ll want to change that 7.3 to 8.2 and then restart nginx
thank you, but it didn’t solve the issue, healtcheck still gives the same output.
Did you restart nginx?
sudo systemctl restart nginx
yes i did restart ngix
it seems to be still wanting to run on 7.3:
2023/05/31 11:33:38 [crit] 1473#1473: *12 connect() to unix:/run/php/php7.3-fpm.sock failed (2: No such file or directory) while connecting to upstream, client: 127.0.0.1, server: pb.mcs-nl.com, request: “GET /healthcheck/status.json HTTP/1.1”, upstream: “fastcgi://unix:/run/php/php7.3-fpm.sock:”, host: “pb.mcs-nl.com”
2023/05/31 11:33:38 [crit] 1473#1473: *3 connect() to unix:/run/php/php7.3-fpm.sock failed (2: No such file or directory) while connecting to upstream, client: 37.251.31.101, server: pb.mcs-nl.com, request: “GET /auth/is-authenticated.json HTTP/1.1”, upstream: “fastcgi://unix:/run/php/php7.3-fpm.sock:”, host: “pb.mcs-nl.com”
2023/05/31 11:34:23 [info] 1473#1473: *15 client 64.62.197.90 closed keepalive connection
ok , we fixed it, we were working in the wrong config file: etcnginx, sites availible in stread of sites-enabled.
thank you for solving my issue!
