I just went through the install tutorial for my platform (ubuntu 20.04).
I used the automatic install (sudo apt-get install passbolt-ce-server)
Everything worked as expected, but now I need to change the url.
From myserver.domain.net to myserver.domain.net/passbolt. This is the only change I need to do from the standard config.
From several forum post, I understand that you have to change the fullBaseUrl variable in passbolt.php.
I did but it did’nt help.
Is there any other parameters to change for this kind of setup ?
Here’s the healthcheck (PASS removed)
[PASS] Using latest passbolt version (3.1.0).
