I provide relevant information about my server (component names and vrsions, etc.)
I have setup the passbolt app on a few iPhone and all has gone well.
When I tried to set up the app on an android tablet, I follow the same steps, but when i scan the QR code i get the message:
Error during scanning.(First page has already been scanned.
A bit stuck.
I tried again on a new iPhone and it installs ok, so the server is all working properly.
22:53:12 File logging tree planted
11:11:52 File logging tree planted
11:15:21 Error during qr code scan
11:15:25 javax.net.ssl.SSLHandshakeException: java.security.cert.CertPathValidatorException: Trust anchor for certification path not found.
at com.android.org.conscrypt.SSLUtils.toSSLHandshakeException(SSLUtils.java:356)
at com.android.org.conscrypt.ConscryptEngine.convertException(ConscryptEngine.java:1134)
at com.android.org.conscrypt.ConscryptEngine.readPlaintextData(ConscryptEngine.java:1089)
at com.android.org.conscrypt.ConscryptEngine.unwrap(ConscryptEngine.java:876)
at com.android.org.conscrypt.ConscryptEngine.unwrap(ConscryptEngine.java:747)
at com.android.org.conscrypt.ConscryptEngine.unwrap(ConscryptEngine.java:712)
at com.android.org.conscrypt.ConscryptEngineSocket$SSLInputStream.processDataFromSocket(ConscryptEngineSocket.java:896)
at com.android.org.conscrypt.ConscryptEngineSocket$SSLInputStream.-$$Nest$mprocessDataFromSocket(Unknown Source:0)
at com.android.org.conscrypt.ConscryptEngineSocket.doHandshake(ConscryptEngineSocket.java:236)
at com.android.org.conscrypt.ConscryptEngineSocket.startHandshake(ConscryptEngineSocket.java:218)
at okhttp3.internal.connection.RealConnection.connectTls(SourceFile:379)
at okhttp3.internal.connection.RealConnection.establishProtocol(SourceFile:337)
at okhttp3.internal.connection.RealConnection.connect(SourceFile:209)
at okhttp3.internal.connection.ExchangeFinder.findConnection(SourceFile:226)
at okhttp3.internal.connection.ExchangeFinder.findHealthyConnection(SourceFile:106)
at okhttp3.internal.connection.ExchangeFinder.find(SourceFile:74)
at okhttp3.internal.connection.RealCall.initExchange$okhttp(SourceFile:255)
at okhttp3.internal.connection.ConnectInterceptor.intercept(SourceFile:32)
at okhttp3.internal.http.RealInterceptorChain.proceed(SourceFile:109)
at okhttp3.internal.cache.CacheInterceptor.intercept(SourceFile:95)
at okhttp3.internal.http.BridgeInterceptor.intercept(SourceFile:83)
at okhttp3.internal.http.RetryAndFollowUpInterceptor.intercept(SourceFile:76)
at com.passbolt.mobile.android.core.networking.interceptor.CookiesInterceptor$AddCookiesInterceptor.intercept(SourceFile:57)
at com.passbolt.mobile.android.core.networking.interceptor.CookiesInterceptor$ReceivedCookiesInterceptor.intercept(SourceFile:38)
at com.passbolt.mobile.android.core.networking.interceptor.AuthInterceptor.intercept(SourceFile:22)
at com.passbolt.mobile.android.core.networking.interceptor.ChangeableBaseUrlInterceptor.intercept(SourceFile:40)
at okhttp3.internal.connection.RealCall.getResponseWithInterceptorChain$okhttp(SourceFile:201)
at okhttp3.internal.connection.RealCall$AsyncCall.run(SourceFile:517)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1145)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:644)
at java.lang.Thread.run(Thread.java:1012)
Caused by: java.security.cert.CertificateException: java.security.cert.CertPathValidatorException: Trust anchor for certification path not found.
at com.android.org.conscrypt.TrustManagerImpl.checkTrustedRecursive(TrustManagerImpl.java:656)
at com.android.org.conscrypt.TrustManagerImpl.checkTrusted(TrustManagerImpl.java:505)
at com.android.org.conscrypt.TrustManagerImpl.checkTrusted(TrustManagerImpl.java:425)
at com.android.org.conscrypt.TrustManagerImpl.getTrustedChainForServer(TrustManagerImpl.java:353)
at android.security.net.config.NetworkSecurityTrustManager.checkServerTrusted(NetworkSecurityTrustManager.java:94)
at android.security.net.config.RootTrustManager.checkServerTrusted(RootTrustManager.java:90)
at com.android.org.conscrypt.ConscryptEngineSocket$2.checkServerTrusted(ConscryptEngineSocket.java:163)
at com.android.org.conscrypt.Platform.checkServerTrusted(Platform.java:260)
at com.android.org.conscrypt.ConscryptEngine.verifyCertificateChain(ConscryptEngine.java:1638)
at com.android.org.conscrypt.NativeCrypto.ENGINE_SSL_read_direct(Native Method)
at com.android.org.conscrypt.NativeSsl.readDirectByteBuffer(NativeSsl.java:568)
at com.android.org.conscrypt.ConscryptEngine.readPlaintextDataDirect(ConscryptEngine.java:1095)
at com.android.org.conscrypt.ConscryptEngine.readPlaintextData(ConscryptEngine.java:1079)
… 35 more
Caused by: java.security.cert.CertPathValidatorException: Trust anchor for certification path not found.
… 48 more
… 35 more
… 48 more
11:15:25 There was an error during transfer update
… 35 more
… 48 more
… 35 more
… 48 more
And the intermediate certificate was missing. I used https://whatsmychaincert.com/ to get it and gave to @pauly the full cert chain. It solved the issue.
