Hello. I installed Passbolt using helm charts, but I’m struggling with this key not found problem, similar with this problem.
The problem happens with some users. Running the healthcheck, I realized we had 2 users with the same e-mail, and it was the default_user:
gpg --list-keys --fingerprint
pub rsa3072 2024-08-27 [SC]
XXXX YYYY ZZZZ ASDQ 1234 1234 1234 1234 1234 1234
uid [ unknown] Passbolt default user ambient@foo.bar
pub rsa3072 2024-09-05 [SC]
122C 4567 F396 DFQ4 AA20 4321 4321 4321 1234 1234
uid [ unknown] Group ambient@foo.bar
Then i deleted the user with duplicated e-mail, ran the cleanup command and restarted my pod. Now the healthcheck pass without problems in my gpg.
www-data@passbolt-depl-srv-64d857f454-dhh97:/usr/share/php/passbolt$ ./bin/cake passbolt healthcheck
healthcheck
Healthcheck shell -------------------------------------------------------------------------------Environment
[PASS] PHP version 8.2.20.
[PASS] Full base url is set to https://passbolt.foo.bar
SMTP settings
[INFO] The self registration provider is: Email domain safe list.
[PASS] 31 tables found.
datacheck
Data check shell
[PASS] Can validate: 1087/1087
[PASS] Can validate: 0/0
[PASS] Can validate: 20/20
[PASS] Can encrypt: 141/141
[PASS] Pass validation service checks: 141/141
[PASS] Entity data and armored key data matches: 141/141
[PASS] Is not expired: 141/141
[PASS] Is armored key format valid: 141/141
[PASS] Can validate: 33/33
[PASS] Can validate: 173/173
[PASS] Can validate: 974/974
[PASS] Can validate: 1779/1779
[PASS] Can validate: 171/171
In some situations users cant can’t add some others users to groups, but i added the same user in the same group with my account. Trying in another browser, sometimes it works, sometimes it doesn’t . I can’t find a pattern to the problem.
When i try to view the user public key in his profile, my extension thrown the exception “User Key not found”
But accessing directly the URL profile via /users/USER_ID.json i can get the public key:
just realized the timezone from application and database are different. There is not any option to change the MariaDB timezone in helm charts. For the application i added the extraEnv: TZ=…
My application version:
Server: 4.9.1 / Client: 4.10.0
My browser version:
Version 130.0.6723.58 (Official Build) (64-bit)
Let me know if more information are needed.
Thanks in advance!
