GPG key problems
  1. Provide your system information:
    – Server operating system name and version: Ubuntu 22.04
    – Web server name and version: Apache 2.4.52
    – Database server name and version: MariaDB 10.6.7-MariaDB-2ubuntu1
    – Php version: 8.1.8
    – Passbolt version: 3.6.0
  2. Provide a copy of your healthcheck running as the web server user
    / / __ `/ / / __ / __ / / _/
    / _
    //./_//__/
Healthcheck shell…Deprecated Error: Return type of OpenPGP_Message::getIterator() should either be compatible with IteratorAggregate::getIterator(): Traversable, or the #[\ReturnTypeWillChange] attribute should be used to temporarily suppress the notice
In [/var/www/passbolt/vendor/singpolyma/openpgp-php/lib/openpgp.php, line 382]
2022-07-20 19:15:36 notice: Deprecated (8192): Return type of OpenPGP_Message::getIterator() should either be compatible with IteratorAggregate::getIterator(): Traversable, or the #[\ReturnTypeWillChange] attribute should be used to temporarily suppress the notice in [/var/www/passbolt/vendor/singpolyma/openpgp-php/lib/openpgp.php, line 382]
Deprecated Error: Return type of OpenPGP_Message::offsetExists($offset) should either be compatible with ArrayAccess::offsetExists(mixed $offset): bool, or the #[\ReturnTypeWillChange] attribute should be used to temporarily suppress the notice
In [/var/www/passbolt/vendor/singpolyma/openpgp-php/lib/openpgp.php, line 388]
2022-07-20 19:15:36 notice: Deprecated (8192): Return type of OpenPGP_Message::offsetExists($offset) should either be compatible with ArrayAccess::offsetExists(mixed $offset): bool, or the #[\ReturnTypeWillChange] attribute should be used to temporarily suppress the notice in [/var/www/passbolt/vendor/singpolyma/openpgp-php/lib/openpgp.php, line 388]
Deprecated Error: Return type of OpenPGP_Message::offsetGet($offset) should either be compatible with ArrayAccess::offsetGet(mixed $offset): mixed, or the #[\ReturnTypeWillChange] attribute should be used to temporarily suppress the notice
In [/var/www/passbolt/vendor/singpolyma/openpgp-php/lib/openpgp.php, line 392]
2022-07-20 19:15:36 notice: Deprecated (8192): Return type of OpenPGP_Message::offsetGet($offset) should either be compatible with ArrayAccess::offsetGet(mixed $offset): mixed, or the #[\ReturnTypeWillChange] attribute should be used to temporarily suppress the notice in [/var/www/passbolt/vendor/singpolyma/openpgp-php/lib/openpgp.php, line 392]
Deprecated Error: Return type of OpenPGP_Message::offsetSet($offset, $value) should either be compatible with ArrayAccess::offsetSet(mixed $offset, mixed $value): void, or the #[\ReturnTypeWillChange] attribute should be used to temporarily suppress the notice
In [/var/www/passbolt/vendor/singpolyma/openpgp-php/lib/openpgp.php, line 396]
2022-07-20 19:15:36 notice: Deprecated (8192): Return type of OpenPGP_Message::offsetSet($offset, $value) should either be compatible with ArrayAccess::offsetSet(mixed $offset, mixed $value): void, or the #[\ReturnTypeWillChange] attribute should be used to temporarily suppress the notice in [/var/www/passbolt/vendor/singpolyma/openpgp-php/lib/openpgp.php, line 396]
Deprecated Error: Return type of OpenPGP_Message::offsetUnset($offset) should either be compatible with ArrayAccess::offsetUnset(mixed $offset): void, or the #[\ReturnTypeWillChange] attribute should be used to temporarily suppress the notice
In [/var/www/passbolt/vendor/singpolyma/openpgp-php/lib/openpgp.php, line 400]
2022-07-20 19:15:36 notice: Deprecated (8192): Return type of OpenPGP_Message::offsetUnset($offset) should either be compatible with ArrayAccess::offsetUnset(mixed $offset): void, or the #[\ReturnTypeWillChange] attribute should be used to temporarily suppress the notice in [/var/www/passbolt/vendor/singpolyma/openpgp-php/lib/openpgp.php, line 400]
Deprecated Error: Return type of OpenPGP_CompressedDataPacket::getIterator() should either be compatible with IteratorAggregate::getIterator(): Traversable, or the #[\ReturnTypeWillChange] attribute should be used to temporarily suppress the notice
In [/var/www/passbolt/vendor/singpolyma/openpgp-php/lib/openpgp.php, line 1681]
2022-07-20 19:15:36 notice: Deprecated (8192): Return type of OpenPGP_CompressedDataPacket::getIterator() should either be compatible with IteratorAggregate::getIterator(): Traversable, or the #[\ReturnTypeWillChange] attribute should be used to temporarily suppress the notice in [/var/www/passbolt/vendor/singpolyma/openpgp-php/lib/openpgp.php, line 1681]
Deprecated Error: Return type of OpenPGP_CompressedDataPacket::offsetExists($offset) should either be compatible with ArrayAccess::offsetExists(mixed $offset): bool, or the #[\ReturnTypeWillChange] attribute should be used to temporarily suppress the notice
In [/var/www/passbolt/vendor/singpolyma/openpgp-php/lib/openpgp.php, line 1687]
2022-07-20 19:15:36 notice: Deprecated (8192): Return type of OpenPGP_CompressedDataPacket::offsetExists($offset) should either be compatible with ArrayAccess::offsetExists(mixed $offset): bool, or the #[\ReturnTypeWillChange] attribute should be used to temporarily suppress the notice in [/var/www/passbolt/vendor/singpolyma/openpgp-php/lib/openpgp.php, line 1687]
Deprecated Error: Return type of OpenPGP_CompressedDataPacket::offsetGet($offset) should either be compatible with ArrayAccess::offsetGet(mixed $offset): mixed, or the #[\ReturnTypeWillChange] attribute should be used to temporarily suppress the notice
In [/var/www/passbolt/vendor/singpolyma/openpgp-php/lib/openpgp.php, line 1691]
2022-07-20 19:15:36 notice: Deprecated (8192): Return type of OpenPGP_CompressedDataPacket::offsetGet($offset) should either be compatible with ArrayAccess::offsetGet(mixed $offset): mixed, or the #[\ReturnTypeWillChange] attribute should be used to temporarily suppress the notice in [/var/www/passbolt/vendor/singpolyma/openpgp-php/lib/openpgp.php, line 1691]
Deprecated Error: Return type of OpenPGP_CompressedDataPacket::offsetSet($offset, $value) should either be compatible with ArrayAccess::offsetSet(mixed $offset, mixed $value): void, or the #[\ReturnTypeWillChange] attribute should be used to temporarily suppress the notice
In [/var/www/passbolt/vendor/singpolyma/openpgp-php/lib/openpgp.php, line 1695]
2022-07-20 19:15:36 notice: Deprecated (8192): Return type of OpenPGP_CompressedDataPacket::offsetSet($offset, $value) should either be compatible with ArrayAccess::offsetSet(mixed $offset, mixed $value): void, or the #[\ReturnTypeWillChange] attribute should be used to temporarily suppress the notice in [/var/www/passbolt/vendor/singpolyma/openpgp-php/lib/openpgp.php, line 1695]
Deprecated Error: Return type of OpenPGP_CompressedDataPacket::offsetUnset($offset) should either be compatible with ArrayAccess::offsetUnset(mixed $offset): void, or the #[\ReturnTypeWillChange] attribute should be used to temporarily suppress the notice
In [/var/www/passbolt/vendor/singpolyma/openpgp-php/lib/openpgp.php, line 1699]
2022-07-20 19:15:36 notice: Deprecated (8192): Return type of OpenPGP_CompressedDataPacket::offsetUnset($offset) should either be compatible with ArrayAccess::offsetUnset(mixed $offset): void, or the #[\ReturnTypeWillChange] attribute should be used to temporarily suppress the notice in [/var/www/passbolt/vendor/singpolyma/openpgp-php/lib/openpgp.php, line 1699]
[PASS] PHP version 8.1.8.
[PASS] Full base url is set to <>
[PASS] 26 tables found
[FAIL] The private key cannot be used to sign a message
[HELP] Make sure that the server private key is valid and that there is no passphrase.
[HELP] Make sure you imported the private server key in the keyring of the webserver user.
[HELP] you can try:
[HELP] sudo su -s /bin/bash -c “gpg --home /var/www/.gnupg --import /var/www/passbolt/config/gpg/serverkey_private.asc” www-data
[FAIL] The public and private keys cannot be used to encrypt and sign a message
[PASS] Using latest passbolt version (3.6.0).
[PASS] The /var/www/passbolt/config/jwt/ directory is not writable.
[FAIL] 5 error(s) found. Hang in there!
3. Describe the problem thoroughly with as much details as possible so that people can reproduce the issues.
– I’ve followed the tutorial found on this link: https://www.howtoforge.com/install-and-configure-passbolt-password-manager-on-ubuntu-2004/
I’ve searched the community forum for answers and while I’ve found a couple of similar topics, none of the mentioned fixes worked for me so I decided to post.
I’ve tried generating new keys, I’ve checked the ownership of all the files and folders, I’ve tried removing the keys from the keyring and re-importing them. I’ve tried deleting the keyring and recreating it, nothing has helped so far.
Everything else gets a pass but the keys and I’m going crazy trying to figure out what’s wrong.
Thanks in advance!
Hi @Vination Welcome to the forum!
The official guide is here Passbolt Help | Install Passbolt CE on Ubuntu 20.04
I think you will see some differences in the versions, but the official guide is tested and will work.
