Has anyone used Cloudflare’s Argo Tunnelling to support a Passbolt server? It works as a hybrid tunnel from a Cloudflare IP address and als a bit lite a reverse proxy. I’m looking for input from people who have tried it. Either successful or failed.
I have passbolt currently running behind my Cloudflare Tunnel and all is well, however, I’m looking to see if I can create a bypass rule for mobile. The way I would do this is if there was a specific path or set of paths that would be static for mobile access, such as https://domain.com/mobile or other similar structure. This would allow me to force my Google Oauth2 login and email match that I have for accessing the front-end web UI, but still allow the mobile app to connect.
While not as secure as having it entirely behind CF, it does significantly reduce the attack surface by only allowing traffic to bypass CF to the mobile auth path and blocking everything else.
