Uncaught CacheException: Cache engine "_cake_core_" is not properly configured
username@Passbolt:/var/www/passbolt$ sudo -u www-data app/Console/cake install --no-admin
PHP Warning: cake_core cache was unable to write ‘cake_dev_eng’ to File cache in /var/www/passbolt/lib/Cake/Cache/Cache.php on line 327
PHP Warning: /var/www/passbolt/app/tmp/cache/persistent/ is not writable in /var/www/passbolt/lib/Cake/Cache/Engine/FileEngine.php on line 385
PHP Fatal error: Uncaught CacheException: Cache engine “cake_core” is not properly configured. Ensure required extensions are installed, and credentials/permissions are correct in /var/www/passbolt/lib/Cake/Cache/Cache.php:186
Stack trace:
#0 /var/www/passbolt/lib/Cake/Cache/Cache.php(151): Cache::_buildEngine(‘cake_core’)
#1 /var/www/passbolt/app/Config/core.php(400): Cache::config(‘cake_core’, Array)
#2 /var/www/passbolt/lib/Cake/Core/Configure.php(72): include(’/var/www/passbo…’)
#3 /var/www/passbolt/lib/Cake/bootstrap.php(432): Configure::bootstrap(true)
#4 /var/www/passbolt/lib/Cake/Console/ShellDispatcher.php(145): require(’/var/www/passbo…’)
#5 /var/www/passbolt/lib/Cake/Console/ShellDispatcher.php(100): ShellDispatcher->_bootstrap()
#6 /var/www/passbolt/lib/Cake/Console/ShellDispatcher.php(54): ShellDispatcher->_initEnvironment()
#7 /var/www/passbolt/lib/Cake/Console/ShellDispatcher.php(65): ShellDispatcher->__construct(Array)
#8 /var/www/passbolt/app/Console/cake.php(52): ShellDispatcher::run(Array)
#9 {mai in /var/www/passbolt/lib/Cake/Cache/Cache.php on line 186
@Coolfeather2 Please try to provide more information about what you did and what you tried from the checklist. While you seems to have an issue with the cache, a little hello and some introduction can go a long way if you want to get help.
Hi
I tried setting up passbolt on Ubuntu LEMP stack
PHP 7.0
MySQL 5.7
Nginx
I don’t really know how to troubleshoot this - could be a issue with permissions?
Check that your app/tmp/ directory is writable. You can run the healtcheck to get some help on how to solve similar configuration issues:
sudo su -s /bin/bash -c "./app/Console/cake passbolt healthcheck" nginx
username@Passbolt:/var/www/passbolt$ sudo su -s /bin/bash -c "./app/Conso        le/cake passbolt healthcheck" www-data
PHP Warning:  _cake_core_ cache was unable to write 'cake_dev_eng' to File cache        in /var/www/passbolt/lib/Cake/Cache/Cache.php on line 327
PHP Warning:  /var/www/passbolt/app/tmp/cache/persistent/ is not writable in /va        r/www/passbolt/lib/Cake/Cache/Engine/FileEngine.php on line 385
PHP Fatal error:  Uncaught CacheException: Cache engine "_cake_core_" is not pro        perly configured. Ensure required extensions are installed, and credentials/perm        issions are correct in /var/www/passbolt/lib/Cake/Cache/Cache.php:186
Stack trace:
#0 /var/www/passbolt/lib/Cake/Cache/Cache.php(151): Cache::_buildEngine('_cake_c        ore_')
#1 /var/www/passbolt/app/Config/core.php(400): Cache::config('_cake_core_', Arra        y)
#2 /var/www/passbolt/lib/Cake/Core/Configure.php(72): include('/var/www/passbo..        .')
#4 /var/www/passbolt/lib/Cake/Console/ShellDispatcher.php(145): require('/var/ww        w/passbo...')
#5 /var/www/passbolt/lib/Cake/Console/ShellDispatcher.php(100): ShellDispatcher-        >_bootstrap()
#6 /var/www/passbolt/lib/Cake/Console/ShellDispatcher.php(54): ShellDispatcher->        _initEnvironment()
#7 /var/www/passbolt/lib/Cake/Console/ShellDispatcher.php(65): ShellDispatcher->        __construct(Array)
Decided to chown -R www-data:www-data ./passbolt/
 [PASS] PHP version 7.0.22-0ubuntu0.16.04.1
 [PASS] PCRE compiled with unicode support
 [PASS] The temporary directory and its content are writable
 [PASS] The public image directory and its content are writable
 [PASS] The core config file is present
 [PASS] The database config file is present
 [PASS] The email config file is present
 [FAIL] Default value found for security.salt
  [HELP] Edit the security.salt in app/Config/core.php
 [FAIL] Default value found for security.cipherSeed
  [HELP] Edit the security.cipherSeed in app/Config/core.php
 [PASS] Full base url is set to http://<redacted machine ip>/
  [HELP] Check that the domain name is correct in app/Config/core.php
 [PASS] Configured to use a supported database backend
 [PASS] Not using a prefix for database tables
 [FAIL] No table found
  [HELP] sudo su -s /bin/bash -c "/var/www/passbolt/app/Console/cake install" www-data
  [HELP] sudo su -s /bin/bash -c "/var/www/passbolt/app/Console/cake Migrations.migration run all" www-data
 [PASS] PHP GPG Module is installed and loaded
 [PASS] The environment variable GNUPGHOME is set to /home/www-data/.gnupg
 [PASS] The directory /home/www-data/.gnupg containing the keyring is writable by the user the webserver is running as.
 [PASS] The public key file is defined in app/config.php and readable.
 [PASS] The private key file is defined in app/config.php and readable.
 [PASS] The server key fingerprint matches the one defined in app/config.php.
 [WARN] The server key defined in the app/Config.php is not in the keyring
  [HELP] Import the private server key in the keyring of the user the webserver is running as.
  [HELP] you can try:
  [HELP] sudo su -s /bin/bash -c "gpg --home /home/www-data/.gnupg --import /var/www/passbolt/app/Config/gpg/server_private_key.key" www-data
 [FAIL] This installation is not up to date. Currently using 1.6.9 and it should be v2.0.0-rc1.
 [PASS] Passbolt is configured to force SSL use
 [FAIL] App.fullBaseUrl is not set to HTTPS
  [HELP] Check App.fullBaseUrl url scheme in app/Config/core.php
 Development Tools (optional)
 [PASS] Phpunit is installed
 [PASS] Phpunit version is 3.7.38
  10 error(s) found. Hang in there!
How would one generate a salt/cipherseed to replace default?
You can place any random values. This values are not in used at the moment.
the passbolt php test page shows up but going to the account setup page doesn’t work (404)
I guess your original issue is solved. Please create a new issue with more information about the next problem you are facing so that other people can also benefits from the solution.
