1. Provide your system information:
Kubernetes (Minikube)
Passbolt Container (https://hub.docker.com/r/passbolt/passbolt/) without any volume mounts and an adjusted app.php for allowing self signed certificates.
āurlā => env(āEMAIL_TRANSPORT_DEFAULT_URLā, null),
ācontextā => [
āsslā => [
āverify_peerā => env(āEMAIL_TRANSPORT_VERIFY_PEERā, true),
āverify_peer_nameā => env(āEMAIL_TRANSPORT_VERIFY_NAMEā, true),
āallow_self_signedā => env(āEMAIL_TRANSPORT_ALLOW_SELF_SIGNEDā, false),
Version 2.12.0
2. Provide a copy of your healthcheck running as the web server user
./bin/cake passbolt healthcheck
root@passbolt:/var/www/passbolt# su -s /bin/bash -c ā./bin/cake passbolt healthcheckā www-data
Warning Error: SplFileInfo::openFile(/var/www/passbolt/tmp/cache/persistent/myapp_cake_core_translations_cake_console_en__u_s): failed to open stream: Permission denied in [/var/www/passbolt/vendor/cakephp/cakephp/src/Cache/Engine/FileEngine.php, line 405]
// _,///./_//__/
[PASS] PHP version 7.3.14.
[FAIL] The temporary directory and its content are not writable.
[HELP] you can try:
[HELP] sudo chown -R www-data:www-data /var/www/passbolt/tmp/
[HELP] sudo chmod 775 $(find /var/www/passbolt/tmp/ -type d)
[HELP] sudo chmod 664 $(find /var/www/passbolt/tmp/ -type f)
[PASS] Full base url is set to http://{passbolt.domain}
[PASS] 23 tables found
[HELP] See. {link removed}
[FAIL] The server key fingerprint doesnāt match the one defined in config/passbolt.php.
[HELP] sudo su -s /bin/bash -c āgpg --list-keys --fingerprint --home /home/www-data/.gnupgā www-data | grep -i -B 2 āSERVER_KEY_EMAILā
[HELP] you can try:
[HELP] sudo su -s /bin/bash -c āgpg --home /home/www-data/.gnupg --import /var/www/passbolt/config/gpg/serverkey_private.ascā www-data
[FAIL] Could not connect to passbolt repository to check versions. It is not possible check if your version is up to date.
7 error(s) found. Hang in there!
./bin/cake passbolt send_test_email
root@passbolt:/var/www/passbolt# ./bin/cake passbolt send_test_email -r {user email}
// _,///./_//__/
Debug email shell
Email configuration
Host: {host}
Port: 25
Username: {username}
Password: *********
TLS: true
Sending email from: {from email}
Sending email to: {user email}
Trace
[220] Default Frontend {host}
EHLO localhost
[250] {host} Hello [{ip}]
[250] SIZE 37748736
[250] PIPELINING
[250] DSN
[250] ENHANCEDSTATUSCODES
[250] STARTTLS
[250] 8BITMIME
[250] BINARYMIME
[250] CHUNKING
STARTTLS
[220] 2.0.0 SMTP server ready
EHLO localhost
[250] SIZE 37748736
[250] PIPELINING
[250] DSN
[250] AUTH LOGIN
[250] 8BITMIME
[250] BINARYMIME
[250] CHUNKING
AUTH LOGIN
[334] VXNlcm5hbWU6
[334] UGFzc3dvcmQ6
[235] 2.7.0 Authentication successful
MAIL FROM:{email}
[250] 2.1.0 Sender OK
RCPT TO:{user email}
[250] 2.1.5 Recipient OK
DATA
[354] Start mail input; end with .
To: {user email}
Date: Wed, 29 Jan 2020 16:34:10 +0000
Message-ID: <271d289d27b24a678671671fdef10543 @ passbolt>
Subject: Passbolt test email
MIME-Version: 1.0
Congratulations!
[250] 2.6.0 <271d289d27b24a678671671fdef10543 @ passbolt> [InternalId=109190953567210, Hostname={host}] 1522 bytes in 0.129, 11,508 KB/sec Queued mail for delivery
QUIT
Environment variables
APP_FULL_BASE_URL: http://{passbolt.domain}
DATASOURCES_DEFAULT_HOST: {db ip}
DATASOURCES_DEFAULT_PASSWORD: {db password}
DATASOURCES_DEFAULT_USERNAME: {db user}
DATASOURCES_DEFAULT_DATABASE: {db}
EMAIL_TRANSPORT_DEFAULT_CLASS_NAME: Smtp
EMAIL_DEFAULT_FROM: {from email}
EMAIL_TRANSPORT_DEFAULT_HOST: {smtp host}
EMAIL_TRANSPORT_DEFAULT_PORT: ā25ā
EMAIL_TRANSPORT_DEFAULT_USERNAME: ā{email user}ā
EMAIL_TRANSPORT_DEFAULT_PASSWORD: ā{email password}ā
EMAIL_TRANSPORT_DEFAULT_TLS: ā1ā
EMAIL_TRANSPORT_VERIFY_PEER: ā0ā
EMAIL_TRANSPORT_VERIFY_PEER_NAME: ā0ā
EMAIL_TRANSPORT_ALLOW_SELF_SIGNED: ā1ā
3. Describe the problem thoroughly with as much details as possible so that people can reproduce the issues.
ā What steps did you take?
- I already fixed the permission issues in the container for the temp folder, but no luck
- The cli email check is working (the test email is also received)
ā What happened?
- The email message will not be sent to the users
- No logs are written by passbolt to /var/www/passbolt/logs
ā What did you expect instead?
- Emails will be sent or an error should be shown
