Passbolt Dead after Update - Ubuntu 22.04 ERR_TOO_MANY-REDIRECTS
Passbolt is dead after Updating.
Trying to Open up passbolt after the update is giving my ERR_TOO_MANY_REDIRECTS.
 [PASS] PHP version 8.1.2-1ubuntu2.13.
 [PASS] Full base url is set to https://passbolt.censored-domain.de
 [PASS] 32 tables found
 [PASS] Using latest passbolt version (4.1.1).
 SMTP Settings
PHP has not been Upgraded:
The following packages have been kept back:
initramfs-tools initramfs-tools-bin initramfs-tools-core
libnginx-mod-http-geoip2 libnginx-mod-http-image-filter
libnginx-mod-http-xslt-filter libnginx-mod-mail libnginx-mod-stream
libnginx-mod-stream-geoip2 nginx nginx-common nginx-core
The following packages will be upgraded:
passbolt-ce-server ubuntu-server-minimal
php -v
PHP 8.1.2-1ubuntu2.13 (cli) (built: Jun 28 2023 14:01:49) (NTS)
Copyright (c) The PHP Group
Zend Engine v4.1.2, Copyright (c) Zend Technologies
with Zend OPcache v8.1.2-1ubuntu2.13, Copyright (c), by Zend Technologies
php part of nginx config
location ~ .php$ {
try_files $uri =404;
include fastcgi_params;
fastcgi_pass unix:/run/php/php8.1-fpm.sock;
fastcgi_index index.php;
fastcgi_intercept_errors on;
fastcgi_split_path_info ^(.+.php)(.+)$;
fastcgi_param PHP_VALUE “upload_max_filesize=5M \n post_max_size=5M”;
Listing the directory /run/php/ contains
drwxr-xr-x 25 root root 820 Jul 12 08:54 …
lrwxrwxrwx 1 root root 30 Jul 12 08:50 php-fpm.sock → /etc/alternatives/php-fpm.sock
-rw-r–r-- 1 root root 3 Jul 12 08:50 php8.1-fpm.pid
srw-rw---- 1 www-data www-data 0 Jul 12 08:50 php8.1-fpm.sock
No new entrys are being written to /var/log/passbolt/error.log after upgrading.
Passbolt Server is running on Ubuntu 22.04.2 LTS (GNU/Linux 5.15.0-76-generic x86_64)
Hello, please read the following post because maybe you can solve this issue together
I also followed this post and also left several comments.
But there is no solution yet.
Hi @Sk4nkhunt42
Thank you for posting your information.
You can try setting the PASSBOLT_EMAIL_VALIDATE_MX environment variable to true in /etc/passbolt/passbolt.php
I have searched for the answer for [FAIL] Could not reach the /healthcheck/status with the url specified in App.fullBaseUrl
The best I can find is this answer
the following packages are being kept back
Out of curiosity could you check if you have the force ssl set to true? You can change this setting in /etc/passbolt/passbolt.php or /etc/passbolt/default.php I suggest changing it in the former.
In passbolt.php you need to add the following snippet in the passbolt section:
 'ssl' => [
          'force' => true,
or in default.php
'ssl' => [
            'force' => filter_var(env('PASSBOLT_SSL_FORCE', true), FILTER_VALIDATE_BOOLEAN)
Sorry for late reply, forcing ssl was set to true.
Passbolt is running behind a reverse proxy wich is handeling ssl.
Disabling SSL forcing in the passbolt config did work!
Thanks.
