[] I have read intro post: https://community.passbolt.com/t/about-the-installation-issues-category/12
[] I have read the tutorials, help and searched for similar issues
[] I provide relevant information about my server (component names and versions, etc.)
[] I provide a copy of my logs and healthcheck
Hi All,
Complete rookie for Ubuntu & LAMP here,
I have been following this tutorial on the passbolt setup:
.linuxhowto.net/how-to-install-passbolt-password-manager-on-ubuntu-20-04-server/
And have reached Step 5: Run the install script,
When I try running sudo su -s /bin/bash -c “./bin/cake passbolt install --force” www-data
I get the following errors:
isdadmin@sukpeprdpass01:/var/www/passbolt$ sudo su -s /bin/bash -c “./bin/cake passbolt ins tall --force” www-data
Warning Error: /var/www/passbolt/tmp/cache/persistent/ is not writable in [/var/www/passbol t/vendor/cakephp/cakephp/src/Cache/Engine/FileEngine.php, line 446]
PHP Warning: file_put_contents(/var/www/passbolt/logs/cli-error.log): failed to open strea m: Permission denied in /var/www/passbolt/vendor/cakephp/cakephp/src/Log/Engine/FileLog.php on line 133
Warning Error: /var/www/passbolt/tmp/cache/models/ is not writable in [/var/www/passbolt/ve ndor/cakephp/cakephp/src/Cache/Engine/FileEngine.php, line 446]
Warning Error: cake_model cache was unable to write ‘default_organization_settings’ to Ca ke\Cache\SimpleCacheEngine cache in [/var/www/passbolt/vendor/cakephp/cakephp/src/Cache/Cac he.php, line 306]
// _,///./_//__/
Running baseline checks, please wait…
The GPG keyring location is not set.
Please run ./bin/cake passbolt healthcheck for more information and help.
I then did a health check and this is the result:
isdadmin@sukpeprdpass01:/var/www/passbolt$ ./bin/cake passbolt healthcheck
// _,///./_//__/
[PASS] PHP version 7.4.3.
[PASS] Full base url is set to .https://passbolt.isd-nr.idealshoppingdirect.co.uk
[HELP] cURL Error (7) Failed to connect to .passbolt.isd-nr.idealshoppingdirect.co.uk port 443: Connection refused
[PASS] 25 tables found
[PASS] The environment variable GNUPGHOME is set to /home/isdadmin/.gnupg.
[PASS] The directory /home/isdadmin/.gnupg containing the keyring is writable by the webserver user.
[PASS] Using latest passbolt version (3.1.0).
Is this an issue with www-data permissions to those php directories?
I’m completely new to this and would appreciate any guidance at all,
Kind regards,
Jack.
