Passbolt v2.0.0-rc hangs at "decrypting..."
I’m currently evaluating Passbolt for our IT Team, and I have an issue when trying to edit an existing entry.
I want to update the password, so I click the “click here to unlock” field, under “Password”, then the field status changes for “decrypting…”, a little wheel is turning next to it, and I also noticed a kind of progress bar (thin red bar at the bottom of the browser window) that loads up to half of the screen and stays there. The window then seems to be frozen, nothing happens, the “decrypting…” message and the turning wheel stay forever but nothing happens. No elements of the window are selectable nor clickable, all I can do then is close the browser window or tab from the browser commands. This is a little bit annoying as I’m not able to change existing passwords because of that. For now, my only solution is to delete the entry and create a new one.
Everything else seems to work just fine with my Passbolt installation.
Using Passbolt 2.0.0-rc2 on CentOS 7 (centos-release-7-4.1708.el7.centos.x86_64). Components are nginx, php7, mariaDB.
Healthcheck is clean (except the certificate warning, which is weird because I use a GoDaddy certificate - wildcard):
[root@passbolt2 ~]# su -c “/var/www/passbolt_v2/bin/cake passbolt healthcheck” -s /bin/bash nginx
/ _
//.__/__//_/
[PASS] PHP version 7.0.27.
[PASS] Full base url is set to xhttps://xxxx.xxxxxxxxx.com
error:14090086:SSL routines:ssl3_get_server_certificate:certificate verify failed
fopen(xhttps://xxxx.xxxxxxxxx.com/healthcheck/status.json): failed to open stream: operation failed
[PASS] 18 tables found
[PASS] Using latest passbolt version (2.0.0-rc2).
I didn’t find any relevant errors in /var/www/passbolt_v2/logs/error.log.
I tried with different computers (VM) and browsers (Firefox and Chrome), and always end up with the frozen window saying “decrypting…”.
Any idea about what is wrong? Other log files I should check for clues? Anybody else having the same issue with the v2.0.0-rc2?
Thanks.
Hi @LudovicG, this looks like an issue with the decryption in extension.
Could you open the web extension browser console to check for error there?
Firefox: https://developer.mozilla.org/en-US/docs/Tools/Browser_Console
Chrome: https://stackoverflow.com/a/10258029/4063145
Thanks,
Hi Remy,
In Chrome, using the console, I only get 2 warnings while being on the main Passbolt page ([Deprecation] Synchronous XMLHttpRequest on the main thread is deprecated because of its detrimental effects to the end user’s experience. For more help, check https://xhr.spec.whatwg.org/. - and - Controller id is defined by options and by template, the template id will be overriden by the option id.), but I get the following error as soon as I click an entry in the password list (to view or edit it):
Uncaught TypeError: Cannot read property ‘Profile’ of undefined
at func (passbolt.js:2)
at u.mapObject (passbolt.js:2)
at u.insertItem (passbolt.js:2)
at u.load (passbolt.js:2)
at Object.eval (passbolt.js:2)
at u (passbolt.js:2)
at Object.fireWith [as resolveWith] (passbolt.js:2)
Is this error giving you a clue?
I’m a sysadmin, not a programmer nor a web developer, so this kind of message doesn’t tell me anything…
If I then select the “edit” button, once in the entry, and try to change the password, the Chrome browser console clears and I don’t see any error anymore, it just stays empty, even if I click in the password field.
Thanks.
Thanks for the report Ludovic, it’s helpful indeed. This is the first time we’re seeing this issue.
Just to clarify, did you check the background page console on chrome? It is different from the regular console as it includes errors from the extension. You need to go to chrome://extensions/ and click on inspect view.
48
Hi Remy, I can confirm I used the method you describe to access the console, from “Chrome://extensions” and then “Inspect views”, as I did follow the instructions you sent in the previous post.
By testing a little bit more, I also have the same kind of problem when trying to share a password, the window freezes and becomes unresponsive as soon as I click “save”, and I can see the same “Uncaught TypeError” error in the console, so I guess this issue is related to the original problem as well.
I just upgraded our version 2.0.0-rc2 to latest version 2.0.1 and the issue with editing the password is now fixed.
I guess you changed something in the new version about that…
Thanks for the update, we’ll continue to test the features, and will probably stick with Passbolt, if it fits our needs.
