All I get after I successfully login is an empty page.
This is happening after I upgraded from 2.9.0 to 3.1.0 or 3.0.2
Reverting to 2.9.0 brings everything back.
I run the migrations / cleanup / etc. and everything runs without any issues, but page is empty
<!doctype html>
<html class="passbolt no-js version launching no-passboltplugin" lang="en">
<head>
<meta charset="utf-8"/>
<title>Passbolt | Open source password manager for teams</title>
/ ____/ /_/ (__ )__ ) /_/ / /_/ / / /_
Copyright (c) Passbolt SA ()
This program is free software: you can redistribute it and/or modify
it under the terms of the GNU Affero General Public License as
published by the Free Software Foundation, either version 3 of the
License, or (at your option) any later version.
This program is distributed in the hope that it will be useful,
but WITHOUT ANY WARRANTY; without even the implied warranty of
MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
GNU Affero General Public License for more details.
You should have received a copy of the GNU Affero General Public License
along with this program. If not, see
<meta name="description" content="Open source password manager for teams">
<meta name="keywords" content="Passbolt, password manager, online password manager, open source password manager">
<meta name="robots" content="noindex, nofollow">
<meta name="viewport" content="width=device-width, initial-scale=1">
<link rel="shortcut icon" type="image/x-icon" href="./favicon.ico" />
<link rel="icon" href="./favicon_32.png" sizes="32x32" />
<link rel="icon" href="./favicon_57.png" sizes="57x57" />
<link rel="icon" href="./favicon_76.png" sizes="76x76" />
<link rel="icon" href="./favicon_96.png" sizes="96x96" />
<link rel="icon" href="./favicon_128.png" sizes="128x128" />
<link rel="icon" href="./favicon_192.png" sizes="192x192" />
<link rel="icon" href="./favicon_228.png" sizes="228x228" />
<base href="./">
<link rel="stylesheet" href="./css/themes/default/api_main.min.css?v=3.1.0" id="js_css_theme"/></head>
<body>
<!-- main -->
<div id="container" class="page ">
<div class="temporary skeleton">
<div id="container" class="page password">
<div class="header first">
<nav><div class="primary navigation top"></div></nav>
</div>
<div class="header second"></div>
<div class="header third"></div>
<div class="panel main"></div>
</div>
<footer>
<div class="footer"></div>
</footer>
</div>
</div>
</body>
</html>
No errors in logs
docker logs 8217c4fe5463
gpg: key 5B5EB23D812422EA: public key "Passbolt default user <emanuel@mytime.com>" imported
gpg: imported: 1
gpg: key 5B5EB23D812422EA: "Passbolt default user <emanuel@mytime.com>" not changed
gpg: key 5B5EB23D812422EA: secret key imported
gpg: unchanged: 1
gpg: secret keys read: 1
gpg: secret keys imported: 1
Generating a RSA private key
writing new private key to '/etc/ssl/certs/certificate.key'
Some tables are already present in the database. A new installation would override existing data.
Please use --force to proceed anyway.
Running migration scripts.
using migration paths
- /etc/passbolt/Migrations
using seed paths
- /etc/passbolt/Seeds
using environment default
using adapter mysql
using database passbolt
ordering by creation time
All Done. Took 0.0059s
Cleared default cache
Cleared _cake_core_ cache
Cleared _cake_model_ cache
Enjoy! ☮
/usr/lib/python2.7/dist-packages/supervisor/options.py:461: UserWarning: Supervisord is running as root and it is searching for its configuration file in default locations (including its current working directory); you probably want to specify a "-c" argument specifying an absolute path to a configuration file for improved security.
'Supervisord is running as root and it is searching '
2021-05-14 19:18:10,811 CRIT Supervisor is running as root. Privileges were not dropped because no user is specified in the config file. If you intend to run as root, you can set user=root in the config file to avoid this message.
2021-05-14 19:18:10,811 INFO Included extra file "/etc/supervisor/conf.d/cron.conf" during parsing
2021-05-14 19:18:10,811 INFO Included extra file "/etc/supervisor/conf.d/nginx.conf" during parsing
2021-05-14 19:18:10,811 INFO Included extra file "/etc/supervisor/conf.d/php.conf" during parsing
2021-05-14 19:18:10,817 INFO RPC interface 'supervisor' initialized
2021-05-14 19:18:10,817 CRIT Server 'unix_http_server' running without any HTTP authentication checking
2021-05-14 19:18:10,817 INFO supervisord started with pid 48
2021-05-14 19:18:11,819 INFO spawned: 'php-fpm' with pid 192
2021-05-14 19:18:11,820 INFO spawned: 'nginx' with pid 193
2021-05-14 19:18:11,822 INFO spawned: 'cron' with pid 194
[14-May-2021 19:18:11] NOTICE: fpm is running, pid 192
[14-May-2021 19:18:11] NOTICE: ready to handle connections
[14-May-2021 19:18:11] NOTICE: systemd monitor interval set to 10000ms
2021-05-14 19:18:12,866 INFO success: php-fpm entered RUNNING state, process has stayed up for > than 1 seconds (startsecs)
2021-05-14 19:18:12,866 INFO success: nginx entered RUNNING state, process has stayed up for > than 1 seconds (startsecs)
2021-05-14 19:18:12,866 INFO success: cron entered RUNNING state, process has stayed up for > than 1 seconds (startsecs)
Healthcheck is ok
[PASS] PHP version 7.3.27-1~deb10u1.
[PASS] Full base url is set to https://passbolt.mytime.com
[PASS] 25 tables found
[HELP] See. help/tech/install#toc_gpg
[HELP] you can try:
[PASS] Using latest passbolt version (3.1.0).
4 error(s) found. Hang in there!
