[ x ] I have read intro post: About the Installation Issues category
[ x ] I have read the tutorials, help and searched for similar issues
[ x ] I provide relevant information about my server (component names and versions, etc.)
[ x ] I provide a copy of my logs and healthcheck
[ x ] I describe the steps I have taken to trouble shoot the problem
[ x ] I describe the steps on how to reproduce the issue
For several weeks now, I’ve been trying in vain to create a high-availability infrastructure to run passbolt.
I would like to implement an infrastructure where the passbolt web frontend and database would be highly available as shown on this diagram.
To do this, I created two “front” servers. These use keepalived, and the switchover takes place from “front1” to “front2” in the event that passbolt’s url address is no longer accessible, or his ip no longer responds.
I’m having trouble getting my front-end servers to work properly. Even after configuring them with SSL certificates, then importing the GPG and JWT keys from the first server to the second, I’m encountering a number of problems, particularly after a keepalived switchover from the first “Front” to the second: unable to reconnect with the error message “unable to verify server keys”, or failure to recover my previously generated user GPG key.
- Generation of an SSL certificate based on the server’s domain name
- Install Passbolt via wget (no local mariadb, install haveged, hostname=domain name, import previously created SSL certificate)
- Modification of the “passbolt.php” file and modification of the “fullbaseurl” line with the IP address of the Keepalived virtual address.
- passbolt web mode settings
- Connection to existing database cluster
- GPG key generation
- email configuration
- creation of first user
- Arrival at Passbolt interface
- Switch off first front-end server
- Switch on second front-end server
- Import SSL certificate from first front-end server
- Install Passbolt via wget (no local mariadb, install haveged,hostname=domain name, import SSL certificate from first front server)
- Web-mode passbolt setup
- import of GPG key "serverkey_private.asc
- Manual import of “serverkey.asc” GPG key from first front-end server
Faced with the problems described at the beginning of this topic, I tried to import the JWT keys from the first front-end server to the second. The only effect this had was to completely prevent me from accessing the passbolt interface with the following error message:
This is the healck of server front 1:
[PASS] PHP version 8.1.27.
[PASS] Full base url is set to https://passbolt.xxxxx.int
[PASS] 31 tables found
[FAIL] This installation is not up to date. Currently using 4.4.1 and it should be 4.4.2.
SMTP Settings
This is the healck of front server 2:
SMTP Settings
Do you have any ideas to help me? I’ve read in the following topics that this type of operation was possible for Passbolt, and was even used by the development team:
https://www.reddit.com/r/passbolt/comments/12s4xaf/passbolt_ha_cluster/
