Using HTTPS my instance on docker is not reachable
Hi all ,
I am running passbolt on my server in a docker container. I followed the documentation, everything is working fine using http.
Now I want to use https in order to connect to my instance using a self signed certificate (generated using openssl req -nodes -x509 -newkey rsa:4096 -keyout key.pem -out cert.pem -sha256 -days 3650).
My docker compose file is so composed:
      - APP_FULL_BASE_URL=https://localhost:8081
      - ./ssl/cert.pem:/etc/ssl/certs/certificate.crt:ro
      - ./ssl/key.pem:/etc/ssl/certs/certificate.key:ro
like indicated in the documentation (Passbolt Help | Manual HTTPS configuration on Docker). But still the instance is accessible only via http. Using https give me this:
What am I doing wrong? I can attach the log during the start-up of the contaienr when needed.
Hello @seamoce, welcome to our community :slight_smile:
I have tried to reproduce the issue, I saw that you were mapping the 8081 port for 443.
Can you confirm that the ports section is looking as below:
      - 8081:443
Indeed, you need to map the 443 → 8081 and not the contrary.
Best regards
Hi Thanks for the answer,
the ports are so configured:
      - 8081:80
      - 4433:443
I do not use the usual one because are already occupied by another container. Might be this the problem?
I think that the issues is that you have set the APP_FULL_BASE_URL to https://localhost:8081 but you’ve mapped that port to use HTTP.
Can you try to:
  • Shutdown the container
    • docker compose -f docker-compose-ce.yaml down
  • Update the docker-compose file
  • Start the container
    • docker compose -f docker-compose-ce.yaml up -d
I followed your suggestion. Now the website is reachable but I get a blank page, looks like there is some problem with the certificate itself. I ran the heathcheck here the output:
Passbolt CE 4.4.2
Cakephp 4.4.17
Linux ad63a53dca8a 5.4.0-163-generic
PHP 8.2.7 (cli) (built: Jun  9 2023 19:37:27) (NTS)
 ERROR: /usr/share/php/passbolt/bin/utils.sh: line 64: mysql: command not found
gpg: WARNING: unsafe ownership on homedir '/var/lib/passbolt/.gnupg'
gpg (GnuPG) 2.2.40
 [PASS] PHP version 8.2.7.
 [PASS] Full base url is set to https://localhost:4433
 [FAIL] App.fullBaseUrl does not validate. https://localhost:4433.
 [HELP] Edit App.fullBaseUrl in /etc/passbolt/passbolt.php
 [HELP] Select a valid domain name as defined by section 2.3.1 of http://www.ietf.org/rfc/rfc1035.txt
 [HELP] cURL Error (7) Failed to connect to localhost port 4433 after 0 ms: Couldn't connect to server
 [PASS] 31 tables found
 [HELP] you can try:
 [PASS] Using latest passbolt version (4.4.2).
 SMTP Settings
 [FAIL] SMTP Setting errors: App\Utility\OpenPGP\Backends\Gnupg::setDecryptKeyFromFingerprint(): Argument #1 ($fingerprint) must be of type string, null given, called in /usr/share/php/passbolt/plugins/PassboltCe/SmtpSettings/src/Service/SmtpSettingsGetSettingsInDbService.php on line 109
 [WARN] The SMTP Settings source is: undefined.
 [FAIL] 8 error(s) found. Hang in there!
 Cleanup shell (dry-run)
Data check shell
  [PASS] Can validate: 41/41
  [PASS] Can validate: 0/0
  [PASS] Can encrypt: 4/4
  [PASS] Pass validation service checks: 4/4
  [PASS] Entity data and armored key data matches: 4/4
  [PASS] Is not expired: 4/4
  [PASS] Is armored key format valid: 4/4
  [PASS] Can validate: 1/1
  [PASS] Can validate: 4/4
  [PASS] Can validate: 45/45
  [PASS] Can validate: 83/83
so the question is now: I am generating the self signed certificate correcly?
Just to confirm, are you navigating to the url and mentioning the port as well? e.g. https://localhost:4433 ? Blank page are usually related to the fullBaseUrl not matching the url you are trying to reach.
yes exactly I try to reach the instance also declaring the port accordingly to the docker compose statement. Infact within the docker when print out the content of the variable seems correct:
root@5860ed96ed77:/usr/share/php/passbolt# echo $APP_FULL_BASE_URL
And this is what I get when I type the URL in the browser
I see you are trying to reach 192.168.134.163:4433 but you’ve mapped localhost:4433 inside the docker compose file, you’ll need to do:
APP_FULL_BASE_URL = https://192.168.134.163:4433
The fullBaseUrl should match the IP you are trying to reach
Oh man! What a noob mistake :nerd_face:
Thank you so much for your help!
EDIT: Is there a way to redicrect the http connection to https directly?
No worries, can happen to anybody! Enjoy passbolt :smiley:
