And i also have this problem too. it’s strange because my ntp is good i compare with time.is
For this one, as it is said there is a check to ensure the public key can be use for decryption and the private key can be used for decryption.
To make sure, it’s actually the case when validating the form there is an attempt for encryption and decryption done with the given key. I mean by that, that the server does not only check for the keys flags but is using the key to check if it’s truly usable.
It could come from the NTP yes, but apparently you’ve check that already.
Are you using the installer to generate the key pairs or did you import a custom one? If you imported your own, you might check if the key has been generated for decryption/encryption purpose.
Well, I guess this command is for your HTTP server to have SSL key and certificate.
For the step with OpenPGP, if you did it manually, you probably have executed gpg commands like this one here
I guess, you could have use the generated key for SSL as your openPGP key which could explain the error. If so, I think you should try the command found in the help documentation or you can use the UI of the webinstaller to generate it automatically (notice that you won’t have the choice on the key size and if you want to go with RSA 4096bits you will have to do it manually with the command line).
