Clean installation and I was trying to add a group to a resource when it failed.
It doesn’t appear the searched group or user.
This is the healthcheck. It thorws an error becauseof the debug mode.
// _,///./_//__/
[PASS] PHP version 7.2.32-1+ubuntu18.04.1+deb.sury.org+1.
[FAIL] Debug mode is on.
[PASS] Full base url is set to https://vault.sieterecursos.com
[PASS] 23 tables found
[PASS] The environment variable GNUPGHOME is set to /home/admin/.gnupg.
[PASS] The directory /home/admin/.gnupg containing the keyring is writable by the webserver user.
[PASS] Using latest passbolt version (2.13.5).
