Unknown column 'EmailQueue.to' in 'field list'
When performing a clean install of v2.0.1 without errors
EmailQueue.preview and EmailQueue.sender operations fail with the following error:
ansible@cri-global-pb-01:/var/www/passbolt$ sudo -u www-data bin/cake EmailQueue.preview
Exception: SQLSTATE[42S22]: Column not found: 1054 Unknown column ‘EmailQueue.to’ in ‘field list’ in [/var/www/passbolt/vendor/cakephp/cakephp/src/Database/Statement/MysqlStatement.php, line 39]
ansible@cri-global-pb-01:/var/www/passbolt$ sudo -u www-data bin/cake EmailQueue.sender
I’m attaching the schema for the email_queue table in case it’s of any use in troubleshooting:
describe passbolt.email_queue;
| Field | Type | Null | Key | Default | Extra |
| id | int(11) | NO | PRI | NULL | auto_increment |
| email | varchar(129) | NO | | NULL | |
| from_name | varchar(255) | YES | | NULL | |
| from_email | varchar(255) | YES | | NULL | |
| subject | varchar(255) | NO | | NULL | |
| config | varchar(30) | NO | | NULL | |
| template | varchar(50) | NO | | NULL | |
| layout | varchar(50) | NO | | NULL | |
| theme | varchar(50) | NO | | NULL | |
| format | varchar(5) | NO | | NULL | |
| template_vars | text | NO | | NULL | |
| headers | text | YES | | NULL | |
| sent | tinyint(1) | NO | | 0 | |
| locked | tinyint(1) | NO | | 0 | |
| send_tries | int(2) | NO | | 0 | |
| send_at | datetime | YES | | NULL | |
| created | datetime | NO | | NULL | |
| modified | datetime | YES | | NULL | |
| attachments | text | YES | | NULL | |
19 rows in set (0.00 sec)
Thank you,
Ted
Healthcheck reports no relevant issues:
ansible@cri-global-pb-01:/var/www/passbolt$ sudo -u www-data bin/cake passbolt healthcheck
[PASS] PHP version 7.0.28-0ubuntu0.16.04.1.
[PASS] Full base url is set to https://passwd.wpnops.net
error:14090086:SSL routines:ssl3_get_server_certificate:certificate verify failed
fopen(https://passwd.wpnops.net/healthcheck/status.json): failed to open stream: operation failed
[PASS] 18 tables found
[PASS] Using latest passbolt version (2.0.1).
This is the installation log in case it’s of any use
ansible@cri-global-pb-01:/var/www/passbolt$ sudo -u www-data bin/cake passbolt install --no-admin --force
Running baseline checks, please wait…
Critical healthchecks are OK
Cleaning up existing tables if any.
Dropping table phinxlog
1 tables dropped
Install the schema and default data.
using migration paths
  • /var/www/passbolt/config/Migrations
    using seed paths
  • /var/www/passbolt/config/Seeds
    using environment default
    using adapter mysql
    using database passbolt
== 20170830064410 V162InitialMigration: migrating
== 20170830064410 V162InitialMigration: migrated 2.5799s
== 20170830065037 V200ActiveMustBeBoolean: migrating
== 20170830065037 V200ActiveMustBeBoolean: migrated 0.6337s
== 20170830065038 V200DropUnusedProfileFields: migrating
== 20170830065038 V200DropUnusedProfileFields: migrated 0.9735s
== 20170830065039 V200IncreaseEmailSize: migrating
== 20170830065039 V200IncreaseEmailSize: migrated 5.0426s
== 20170830065040 V200DropUnusedCreatedBy: migrating
== 20170830065040 V200DropUnusedCreatedBy: migrated 2.8298s
== 20170830065041 V200MigrateUUID: migrating
== 20170830065041 V200MigrateUUID: migrated 10.6618s
== 20170830065042 V200MigrateKeyField: migrating
== 20170830065042 V200MigrateKeyField: migrated 0.0404s
== 20171002061834 V200DropUnusedResourceFields: migrating
== 20171002061834 V200DropUnusedResourceFields: migrated 0.2420s
== 20171006141922 V200AddFavoriteModifiedField: migrating
== 20171006141922 V200AddFavoriteModifiedField: migrated 0.2175s
== 20171009093000 V200DropUnusedPermissionTypesTable: migrating
== 20171009093000 V200DropUnusedPermissionTypesTable: migrated 0.0808s
== 20171009093001 V200MigrateEmailsTable: migrating
== 20171009093001 V200MigrateEmailsTable: migrated 0.5847s
== 20171009093002 V200MigrateFileStorageTable: migrating
== 20171009093002 V200MigrateFileStorageTable: migrated 0.5329s
== 20171025154754 V200AddCommentsUserIdField: migrating
== 20171025154754 V200AddCommentsUserIdField: migrated 0.3256s
== 20180102065042 V200MigrateForeignIdField: migrating
== 20180102065042 V200MigrateForeignIdField: migrated 0.1068s
== 20180102180000 V200DropUnusedTables: migrating
== 20180102180000 V200DropUnusedTables: migrated 0.1806s
== 20180102221500 V200AddMissingTablesIndexes: migrating
== 20180102221500 V200AddMissingTablesIndexes: migrated 0.0196s
All Done. Took 25.0642s
    using seed paths
    Writing dump file /var/www/passbolt/config/Migrations/schema-dump-default.lock…
    Dump file /var/www/passbolt/config/Migrations/schema-dump-default.lock was successfully written
Import the server private key in the keyring
Importing /var/www/gpg/public.key
Keyring init OK
Passbolt installation success! Enjoy!
@teddyphreak
Can you please provide more information regarding your evnironment php, mysql, os versions.
If you could copy/paste here the cakephp cli logs (logs/cli-error.log) it could help to understand what’s going on.
Sure, the server is a fresh install of Ubuntu 16.04, here’s the os package list for mysql and php
ansible@cri-global-pb-01:~ dpkg -l | grep php | tr -s ' ' | cut -d ' ' -f 2-3 dh-php 0.10 php-apcu 5.1.3+4.0.10-1build1 php-common 1:35ubuntu6.1 php-fpm 1:7.0+35ubuntu6.1 php-intl 1:7.0+35ubuntu6.1 php-mysql 1:7.0+35ubuntu6.1 php-pear 1:1.10.1+submodules+notgz-6 php-sqlite3 1:7.0+35ubuntu6.1 php-zip 1:7.0+35ubuntu6.1 php7.0-cli 7.0.28-0ubuntu0.16.04.1 php7.0-common 7.0.28-0ubuntu0.16.04.1 php7.0-curl 7.0.28-0ubuntu0.16.04.1 php7.0-dev 7.0.28-0ubuntu0.16.04.1 php7.0-fpm 7.0.28-0ubuntu0.16.04.1 php7.0-gd 7.0.28-0ubuntu0.16.04.1 php7.0-imap 7.0.28-0ubuntu0.16.04.1 php7.0-intl 7.0.28-0ubuntu0.16.04.1 php7.0-json 7.0.28-0ubuntu0.16.04.1 php7.0-mbstring 7.0.28-0ubuntu0.16.04.1 php7.0-mysql 7.0.28-0ubuntu0.16.04.1 php7.0-opcache 7.0.28-0ubuntu0.16.04.1 php7.0-readline 7.0.28-0ubuntu0.16.04.1 php7.0-sqlite3 7.0.28-0ubuntu0.16.04.1 php7.0-xml 7.0.28-0ubuntu0.16.04.1 php7.0-zip 7.0.28-0ubuntu0.16.04.1 pkg-php-tools 1.32ubuntu2 ansible@cri-global-pb-01:~ dpkg -l | grep maria | tr -s ’ ’ | cut -d ’ ’ -f 2-3
mariadb-client 10.0.34-0ubuntu0.16.04.1
mariadb-client-10.0 10.0.34-0ubuntu0.16.04.1
mariadb-client-core-10.0 10.0.34-0ubuntu0.16.04.1
mariadb-common 10.0.34-0ubuntu0.16.04.1
mariadb-server 10.0.34-0ubuntu0.16.04.1
mariadb-server-10.0 10.0.34-0ubuntu0.16.04.1
mariadb-server-core-10.0 10.0.34-0ubuntu0.16.04.1
Here are the contents of the cli log file:
ansible@cri-global-pb-01:/var/www/passbolt$ cat logs/cli-error.log
2018-04-16 21:37:15 Warning: Warning (2): var_dump() expects at least 1 parameter, 0 given in [/var/www/passbolt/vendor/cakephp/cakephp/src/Database/Statement/MysqlStatement.php, line 39]
2018-04-16 21:38:01 Warning: The connection is going to be closed but there is an active transaction.
2018-04-16 21:38:01 Warning: Warning (2): fwrite(): supplied resource is not a valid stream resource in [/var/www/passbolt/vendor/cakephp/cakephp/src/Console/ConsoleOutput.php, line 253]
2018-04-16 21:39:01 Warning: The connection is going to be closed but there is an active transaction.
2018-04-16 21:39:01 Warning: Warning (2): fwrite(): supplied resource is not a valid stream resource in [/var/www/passbolt/vendor/cakephp/cakephp/src/Console/ConsoleOutput.php, line 253]
If it’s of any interest to you I performed a run modifying the php code to perform a stack trace (truncated to meet foum message size limits) . If you check the top of the stack below you’ll see the SQL statement referencing the EmailQueue.to field that is missing from the database table metadata presented earlier as created by the installer.
ansible@cri-global-pb-01:/var/www/passbolt$ sudo -u www-data bin/cake email_queue.preview
array(11) {
[0]=>
array(7) {
[“file”]=>
string(58) “/var/www/passbolt/vendor/cakephp/cakephp/src/ORM/Query.php”
[“line”]=>
int(1039)
[“function”]=>
string(7) “execute”
[“class”]=>
string(19) “Cake\Database\Query”
[“object”]=>
object(Cake\ORM\Query)#65 (14) {
["(help)"]=>
string(65) “This is a Query object, to get the results execute or iterate it.”
[“sql”]=>
string(796) “SELECT EmailQueue.id AS EmailQueue__id, EmailQueue.to AS EmailQueue__to, EmailQueue.from_name AS EmailQueue__from_name, EmailQueue.from_email AS EmailQueue__from_email, EmailQueue.subject AS EmailQueue__subject, EmailQueue.config AS EmailQueue__config, EmailQueue.template AS EmailQueue__template, EmailQueue.layout AS EmailQueue__layout, EmailQueue.format AS EmailQueue__format, EmailQueue.template_vars AS EmailQueue__template_vars, EmailQueue.headers AS EmailQueue__headers, EmailQueue.sent AS EmailQueue__sent, EmailQueue.locked AS EmailQueue__locked, EmailQueue.send_tries AS EmailQueue__send_tries, EmailQueue.send_at AS EmailQueue__send_at, EmailQueue.created AS EmailQueue__created, EmailQueue.modified AS EmailQueue__modified FROM email_queue EmailQueue”
[“params”]=>
array(0) {
[“defaultTypes”]=>
array(51) {
[“EmailQueue__id”]=>
string(6) “string”
[“EmailQueue.id”]=>
string(6) “string”
[“id”]=>
string(6) “string”
[“EmailQueue__to”]=>
string(6) “string”
[“EmailQueue.to”]=>
string(6) “string”
[“to”]=>
string(6) “string”
[“EmailQueue__from_name”]=>
string(6) “string”
[“EmailQueue.from_name”]=>
string(6) “string”
[“from_name”]=>
string(6) “string”
[“EmailQueue__from_email”]=>
string(6) “string”
[“EmailQueue.from_email”]=>
string(6) “string”
[“from_email”]=>
string(6) “string”
[“EmailQueue__subject”]=>
string(6) “string”
[“EmailQueue.subject”]=>
string(6) “string”
[“subject”]=>
string(6) “string”
[“EmailQueue__config”]=>
string(6) “string”
[“EmailQueue.config”]=>
string(6) “string”
[“config”]=>
string(6) “string”
[“EmailQueue__template”]=>
string(6) “string”
[“EmailQueue.template”]=>
string(6) “string”
[“template”]=>
string(6) “string”
[“EmailQueue__layout”]=>
string(6) “string”
[“EmailQueue.layout”]=>
string(6) “string”
[“layout”]=>
string(6) “string”
[“EmailQueue__format”]=>
string(6) “string”
[“EmailQueue.format”]=>
string(6) “string”
[“format”]=>
string(6) “string”
[“EmailQueue__template_vars”]=>
string(21) “email_queue.serialize”
[“EmailQueue.template_vars”]=>
[“template_vars”]=>
[“EmailQueue__headers”]=>
[“EmailQueue.headers”]=>
[“headers”]=>
[“EmailQueue__sent”]=>
string(7) “boolean”
[“EmailQueue.sent”]=>
string(7) “boolean”
[“sent”]=>
string(7) “boolean”
[“EmailQueue__locked”]=>
string(7) “boolean”
[“EmailQueue.locked”]=>
string(7) “boolean”
[“locked”]=>
string(7) “boolean”
[“EmailQueue__send_tries”]=>
string(7) “integer”
[“EmailQueue.send_tries”]=>
string(7) “integer”
[“send_tries”]=>
string(7) “integer”
[“EmailQueue__send_at”]=>
string(8) “datetime”
[“EmailQueue.send_at”]=>
[“send_at”]=>
[“EmailQueue__created”]=>
[“EmailQueue.created”]=>
[“created”]=>
[“EmailQueue__modified”]=>
[“EmailQueue.modified”]=>
[“modified”]=>
[“decorators”]=>
int(0)
[“executed”]=>
bool(false)
[“hydrate”]=>
bool(true)
[“buffered”]=>
bool(true)
[“formatters”]=>
int(0)
[“mapReducers”]=>
int(0)
[“contain”]=>
array(0) {
[“matching”]=>
array(0) {
[“extraOptions”]=>
array(0) {
[“repository”]=>
object(EmailQueue\Model\Table\EmailQueueTable)#60 (8) {
[“registryAlias”]=>
string(10) “EmailQueue”
[“table”]=>
string(11) “email_queue”
[“alias”]=>
[“entityClass”]=>
string(16) “\Cake\ORM\Entity”
[“associations”]=>
array(0) {
[“behaviors”]=>
array(1) {
[0]=>
string(9) “Timestamp”
[“defaultConnection”]=>
string(7) “default”
[“connectionName”]=>
string(7) “default”
[“type”]=>
string(2) “->”
[“args”]=>
array(0) {
[1]=>
array(7) {
[“file”]=>
string(70) “/var/www/passbolt/vendor/cakephp/cakephp/src/Datasource/QueryTrait.php”
[“line”]=>
int(287)
[“function”]=>
string(8) “_execute”
[“class”]=>
string(14) “Cake\ORM\Query”
[“object”]=>
["(help)"]=>
[“sql”]=>
[“params”]=>
array(0) {
[“defaultTypes”]=>
array(51) {
string(6) “string”
[“EmailQueue.id”]=>
string(6) “string”
[“id”]=>
string(6) “string”
string(6) “string”
[“EmailQueue.to”]=>
string(6) “string”
[“to”]=>
string(6) “string”
string(6) “string”
string(6) “string”
[“from_name”]=>
string(6) “string”
string(6) “string”
string(6) “string”
[“from_email”]=>
string(6) “string”
string(6) “string”
string(6) “string”
[“subject”]=>
string(6) “string”
string(6) “string”
string(6) “string”
[“config”]=>
string(6) “string”
string(6) “string”
string(6) “string”
[“template”]=>
string(6) “string”
string(6) “string”
string(6) “string”
[“layout”]=>
string(6) “string”
string(6) “string”
string(6) “string”
[“format”]=>
string(6) “string”
[“template_vars”]=>
[“headers”]=>
string(7) “boolean”
string(7) “boolean”
[“sent”]=>
string(7) “boolean”
string(7) “boolean”
string(7) “boolean”
[“locked”]=>
string(7) “boolean”
string(7) “integer”
string(7) “integer”
[“send_tries”]=>
string(7) “integer”
[“send_at”]=>
[“created”]=>
[“modified”]=>
[“decorators”]=>
int(0)
[“executed”]=>
bool(false)
[“hydrate”]=>
bool(true)
[“buffered”]=>
bool(true)
[“formatters”]=>
int(0)
[“mapReducers”]=>
int(0)
[“contain”]=>
array(0) {
[“matching”]=>
array(0) {
[“extraOptions”]=>
array(0) {
[“repository”]=>
[“registryAlias”]=>
[“table”]=>
[“alias”]=>
[“entityClass”]=>
[“associations”]=>
array(0) {
[“behaviors”]=>
array(1) {
[0]=>
string(7) “default”
string(7) “default”
[“type”]=>
string(2) “->”
[“args”]=>
array(0) {
[2]=>
array(7) {
[“file”]=>
[“line”]=>
int(987)
[“function”]=>
string(4) “_all”
[“class”]=>
[“object”]=>
["(help)"]=>
[“sql”]=>
[“params”]=>
array(0) {
[“defaultTypes”]=>
array(51) {
string(6) “string”
[“EmailQueue.id”]=>
string(6) “string”
[“id”]=>
string(6) “string”
string(6) “string”
[“EmailQueue.to”]=>
string(6) “string”
[“to”]=>
string(6) “string”
string(6) “string”
string(6) “string”
[“from_name”]=>
string(6) “string”
string(6) “string”
string(6) “string”
[“from_email”]=>
string(6) “string”
string(6) “string”
string(6) “string”
[“subject”]=>
string(6) “string”
string(6) “string”
string(6) “string”
[“config”]=>
string(6) “string”
string(6) “string”
string(6) “string”
[“template”]=>
string(6) “string”
string(6) “string”
string(6) “string”
[“layout”]=>
string(6) “string”
string(6) “string”
string(6) “string”
[“format”]=>
string(6) “string”
[“template_vars”]=>
[“headers”]=>
string(7) “boolean”
string(7) “boolean”
[“sent”]=>
string(7) “boolean”
string(7) “boolean”
string(7) “boolean”
[“locked”]=>
string(7) “boolean”
string(7) “integer”
string(7) “integer”
[“send_tries”]=>
string(7) “integer”
[“send_at”]=>
[“created”]=>
[“modified”]=>
[“decorators”]=>
int(0)
[“executed”]=>
bool(false)
[“hydrate”]=>
bool(true)
[“buffered”]=>
bool(true)
[“formatters”]=>
int(0)
[“mapReducers”]=>
int(0)
[“contain”]=>
array(0) {
[“matching”]=>
array(0) {
[“extraOptions”]=>
array(0) {
[“repository”]=>
[“registryAlias”]=>
[“table”]=>
[“alias”]=>
[“entityClass”]=>
[“associations”]=>
array(0) {
[“behaviors”]=>
array(1) {
[0]=>
string(7) “default”
string(7) “default”
[“type”]=>
string(2) “->”
[“args”]=>
array(0) {
[3]=>
array(7) {
[“file”]=>
[“line”]=>
int(469)
[“function”]=>
string(3) “all”
[“class”]=>
[“object”]=>
["(help)"]=>
[“sql”]=>
[“params”]=>
array(0) {
[“defaultTypes”]=>
array(51) {
string(6) “string”
[“EmailQueue.id”]=>
string(6) “string”
[“id”]=>
string(6) “string”
string(6) “string”
[“EmailQueue.to”]=>
string(6) “string”
[“to”]=>
string(6) “string”
string(6) “string”
string(6) “string”
[“from_name”]=>
string(6) “string”
string(6) “string”
string(6) “string”
[“from_email”]=>
string(6) “string”
string(6) “string”
string(6) “string”
[“subject”]=>
string(6) “string”
string(6) “string”
string(6) “string”
[“config”]=>
string(6) “string”
string(6) “string”
string(6) “string”
[“template”]=>
string(6) “string”
string(6) “string”
string(6) “string”
[“layout”]=>
string(6) “string”
string(6) “string”
string(6) “string”
[“format”]=>
string(6) “string”
[“template_vars”]=>
[“headers”]=>
string(7) “boolean”
string(7) “boolean”
[“sent”]=>
string(7) “boolean”
string(7) “boolean”
string(7) “boolean”
[“locked”]=>
string(7) “boolean”
string(7) “integer”
string(7) “integer”
[“send_tries”]=>
string(7) “integer”
[“send_at”]=>
[“created”]=>
[“modified”]=>
[“decorators”]=>
int(0)
[“executed”]=>
bool(false)
[“hydrate”]=>
bool(true)
[“buffered”]=>
bool(true)
[“formatters”]=>
int(0)
[“mapReducers”]=>
int(0)
[“contain”]=>
array(0) {
[“matching”]=>
array(0) {
[“extraOptions”]=>
array(0) {
[“repository”]=>
[“registryAlias”]=>
[“table”]=>
[“alias”]=>
[“entityClass”]=>
[“associations”]=>
array(0) {
[“behaviors”]=>
array(1) {
[0]=>
string(7) “default”
string(7) “default”
[“type”]=>
string(2) “->”
[“args”]=>
array(0) {
[4]=>
array(7) {
[“file”]=>
[“line”]=>
int(1202)
[“function”]=>
string(5) “_call”
[“class”]=>
[“object”]=>
["(help)"]=>
[“sql”]=>
[“params”]=>
array(0) {
[“defaultTypes”]=>
array(51) {
string(6) “string”
[“EmailQueue.id”]=>
string(6) “string”
[“id”]=>
string(6) “string”
string(6) “string”
[“EmailQueue.to”]=>
string(6) “string”
[“to”]=>
string(6) “string”
string(6) “string”
string(6) “string”
[“from_name”]=>
string(6) “string”
string(6) “string”
string(6) “string”
[“from_email”]=>
string(6) “string”
string(6) “string”
string(6) “string”
[“subject”]=>
string(6) “string”
string(6) “string”
string(6) “string”
[“config”]=>
string(6) “string”
string(6) “string”
string(6) “string”
[“template”]=>
string(6) “string”
string(6) “string”
string(6) “string”
[“layout”]=>
string(6) “string”
string(6) “string”
string(6) “string”
[“format”]=>
string(6) “string”
[“template_vars”]=>
[“headers”]=>
string(7) “boolean”
string(7) “boolean”
[“sent”]=>
string(7) “boolean”
string(7) “boolean”
string(7) “boolean”
[“locked”]=>
string(7) “boolean”
string(7) “integer”
string(7) “integer”
[“send_tries”]=>
string(7) “integer”
[“send_at”]=>
[“created”]=>
[“modified”]=>
[“decorators”]=>
int(0)
[“executed”]=>
bool(false)
[“hydrate”]=>
bool(true)
[“buffered”]=>
bool(true)
[“formatters”]=>
int(0)
[“mapReducers”]=>
int(0)
[“contain”]=>
array(0) {
[“matching”]=>
array(0) {
[“extraOptions”]=>
array(0) {
[“repository”]=>
[“registryAlias”]=>
[“table”]=>
[“alias”]=>
[“entityClass”]=>
[“associations”]=>
array(0) {
[“behaviors”]=>
array(1) {
[0]=>
string(7) “default”
string(7) “default”
[“type”]=>
string(2) “->”
[“args”]=>
array(2) {
[0]=>
string(6) “toList”
[1]=>
array(0) {
[5]=>
array(7) {
[“file”]=>
string(79) “/var/www/passbolt/vendor/lorenzo/cakephp-email-queue/src/Shell/PreviewShell.php”
[“line”]=>
int(23)
[“function”]=>
string(6) “__call”
[“class”]=>
[“object”]=>
["(help)"]=>
[“sql”]=>
I’m not sure what is going on there. The “to” collumn was part of the old EmailQueue plugin (e.g. passbolt v1). This collumn is now replaced by the “email” collumn. What is strange is that you have the right schema in database but the application is still trying to use the old schema.
Did you install from scratch or did you update from v1?
You could try:
  • clear your composer cache
  • clear cakephp cache
  • delete the content of /vendor
  • run composer install again
Thank you very much.
The provided instructions did manage to clear up the issue with the original install which was performed using v2.0.1 (no upgrade from v1)
I’ve performed another automated install pulling v2.0.2 and the issue does not appear at all.
