Self-Host Installation Error (Docker/Firefox Container)
[:heavy_check_mark:] I have read intro post: About the Installation Issues category
[:heavy_check_mark:] I have read the tutorials, help and searched for similar issues
[:heavy_check_mark:] I provide relevant information about my server (component names and versions, etc.)
[:heavy_check_mark:] I provide a copy of my logs and healthcheck
[:heavy_check_mark:] I describe the steps I have taken to trouble shoot the problem
[:heavy_check_mark:] I describe the steps on how to reproduce the issue
Problem
So, I installed Passbolt Docker “successfully”, all my healthchecks are now green! But one problem remains: I cannot access the web-portal from my main machine with my main browser, Firefox.
The issue that I encounter is that upon attempting a web login, I get the following message:
Something went wrong!
The operation failed with the following error:
Could not verify the server key. x-gpgauth-authenticated should be set to false during the verify stage
Here are the details of my installation:
  • Host: Debian Bookworkm (Latest build) with Docker.
  • Client: Debian Bookworkm. Firefox 121 Flatpak (Latest). Several settings from about:config have been modified.
Now, the strange thing is that if I create a new (empty) firefox profile. I can login to the web portal. But I get the above error from my main profile, which is where I will use the password manager.
I have been trying to add my settings to this new profile but cannot reproduce the problem. Any hints or help on why this problem appears or any of the inner workings of passbolt’t browswer-extension integrations would be appreciated.
Healthcheck
 [PASS] PHP version 8.2.7.
 [PASS] Full base url is set to https://passbolt.calli
 [PASS] 31 tables found
 [PASS] Using latest passbolt version (4.4.2).
 [INFO] The self registration provider is: Email domain safe list.
 SMTP Settings
Dockerfile
version: "3.9"
  db:
    image: mariadb:10.11
    container_name: passbolt_database
    restart: unless-stopped
      MYSQL_DATABASE: "ddd"
      MYSQL_USER: "uuu"
      MYSQL_PASSWORD: "xxx"
      PUID: "1005"
      PGID: "1005"
      - db:/var/lib/mysql
    networks:
      default:
    hostname: 'passbolt.calli'
    depends_on:
      - db
      # Hostname
      APP_FULL_BASE_URL: https://passbolt.ccc
      # Database
      DATASOURCES_DEFAULT_DATABASE: "ddd"
      DATASOURCES_DEFAULT_USERNAME: "uuu"
      DATASOURCES_DEFAULT_PASSWORD: "xxx"
      # Mail
      EMAIL_DEFAULT_FROM_NAME: "passbolt"
      EMAIL_DEFAULT_FROM: "passbolt@passbolt.ccc"
      EMAIL_TRANSPORT_DEFAULT_HOST: "smtp.email.ccc"
      EMAIL_TRANSPORT_DEFAULT_USERNAME: "passbolt@passbolt.ccc"
      EMAIL_TRANSPORT_DEFAULT_PASSWORD: "xxx"
      EMAIL_TRANSPORT_DEFAULT_TLS: "false"
      PASSBOLT_SECURITY_SMTP_SETTINGS_ENDPOINTS_DISABLED: "true"
      PASSBOLT_EMAIL_VALIDATE_MX: "true"
      # Key
      PASSBOLT_SSL_FORCE: "true"
      PASSBOLT_GPG_SERVER_KEY_FINGERPRINT_FORCE: "true"
      # IDs
      PUID: "1005"
      PGID: "1005"
      - gpg:/etc/passbolt/gpg
      - jwt:/etc/passbolt/jwt
      # SSL
      - /home/docker/passbolt/certs/passbolt-fullchain.pem:/etc/ssl/certs/certificate.crt:ro
      - /home/docker/passbolt/certs/passbolt-cert-key.pem:/etc/ssl/certs/certificate.key:ro
     # SSL Certificate Healthcheck
      - /home/docker/passbolt/certs/ca.pem:/usr/share/php/passbolt/vendor/composer/ca-bundle/res/cacert.pem:ro
    command:
        "/usr/bin/wait-for.sh",
        "-t",
        "0",
        "db:3306",
        "/docker-entrypoint.sh",
    networks:
      default:
      aztlan:
        ipv4_address: 10.0.20.35
networks:
  default:
    ipam:
      driver: default
      config:
        - subnet: 10.0.35.0/28
  aztlan:
    external: true
  db:
  gpg:
  jwt:
Browser settings.json Network Inspection
GET
scheme
	https
host
	passbolt.ccc
filename
	/settings.json
api-version
	v2
Address
	10.0.20.35:443
Status
200
VersionHTTP/2
Transferred2.50 kB (1.31 kB size)
Referrer Policysame-origin
DNS ResolutionSystem
Response Headers
access-control-expose-headers
	X-GPGAuth-Verify-Response
	X-GPGAuth-Progress
	X-GPGAuth-User-Auth-Token
	X-GPGAuth-Authenticated
	X-GPGAuth-Refer
	X-GPGAuth-Debug
	X-GPGAuth-Error
	X-GPGAuth-Pubkey
	X-GPGAuth-Logout-Url
	X-GPGAuth-Version
cache-control
	no-store, no-cache, must-revalidate
content-security-policy
	default-src 'self'; script-src 'self'; style-src 'self' 'unsafe-inline'; img-src 'self';frame-src 'self' https://*.duosecurity.com;
content-type
	application/json
date
	Mon, 05 Feb 2024 04:56:51 GMT
expires
	Thu, 19 Nov 1981 08:52:00 GMT
pragma
	no-cache
referrer-policy
	same-origin
server
	nginx
strict-transport-security
	max-age=31536000; includeSubDomains
x-content-type-options
	nosniff
x-download-options
	noopen
X-Firefox-Spdy
	h2
x-frame-options
	sameorigin
	false
x-gpgauth-debug
	There is no user associated with this key. No key id set.
x-gpgauth-error
	true
x-gpgauth-login-url
	/auth/login
x-gpgauth-logout-url
	/auth/logout
x-gpgauth-progress
	stage0
x-gpgauth-pubkey-url
	/auth/verify.json
x-gpgauth-verify-url
	/auth/verify
x-gpgauth-version
	1.3.0
x-permitted-cross-domain-policies
	all
Request Headers
Accept
	application/json
Accept-Encoding
	gzip, deflate, br
Accept-Language
	en-US,en;q=0.5
Connection
	keep-alive
content-type
	application/json
Cookie
	passbolt_session=2n5jj8ukk4ove29q2g855at9lq; csrfToken=3986cf75eb5ecb0a0598125b0925657572930fa700ce7d34846f626aea3f22658277aa932a83030dc8bed798fea8f4c51a23988488648920c4c30ac508246ed7
DNT
	1
Host
	passbolt.ccc
Referer
	https://passbolt.ccc/auth/login?redirect=%2F&locale=en-UK
Sec-Fetch-Dest
	empty
Sec-Fetch-Mode
	cors
Sec-Fetch-Site
	same-origin
Sec-GPC
	1
TE
	trailers
User-Agent
	Mozilla/5.0 (X11; Linux x86_64; rv:121.0) Gecko/20100101 Firefox/121.0
X-CSRF-Token
Hello @ocelotl,
It looks like you are having an issue that is the same as navigating in private mode. Since you said that a lot of settings have been modified for your main profile and that on a new profile it works as expected. Could you verify your cookies policy and ensure that nothing is blocking the x-gpgauth token to be set?
Hi @antony
I’d love to do that. But unfortunately I do not know what would be the cookie policy. I can go to about:settings (There is not much) or about:config (There is heaps!), but I’m not sure what are you specifically asking for.
So, this is a few hours later. I have now done the following:
  • Reproduce the problem in a private window using the working firefox profile
  • Compared every setting between the two profiles from about:settings related to cookies. They are all the same.
  • Compared every setting between the two profiles from about:config that includes the keyword “cookie” or “cookies”. Almost everything is the same. There were two booleans that did not exist in the working profile. Turn them on/off tired again. Still not working.
Hi @antony, I tried searching (and switching on/off) for a setting in about:config yesterday that could be the culprit of my problem. Unfortunately, I could not find anything.
Is there a place in Firefox where can I find the cookie policies that could be potentially blocking the x-gpgauth token?
Thanks for your help!
Ok, here I am again. Little is the progress…
I created two new firefox profiles.
  • One only has all my arkenfox settings. This one works well.
  • The other one has all my “personal mozilla account” synced settings. This one has the x-gpgauth problem.
So, yes… I am (sort of) able to reproduce the problem. But still have no idea what to do to fix it.
Hello @ocelotl , I have investigated the issue.
I wanted to know, are you using firefox containers?
Hi @antony, yes I am using Firefox Containers.
So that is what is causing the issues there, unfortunately we are not supporting firefox containers and that’s why you are getting this error
I see! I’m actually relieved knowing what is the issue now! Thanks.
I can confirm that it all works well outside of the containers.
So just to conclude, are there any plans for supporting containers? I’m happy to cast votes, or support that feature request.
Personally, I only need to be able to open the web portal in a specific container where I open all my locally hosted services.
I quickly searched for more about this and found this github issue. It seems that allowing the background webpage of the extension to be within a container, would solve my problem. But idk how to do that or if other functionalities (such as filling forms within other containers) would break. But I’m happy to test too if needed.
