After upgrading to 2.11.0 CE on Raspberry Pie, completing healthcheck with flying colours, I cannot edit or add groups anymore. The GUI is more or less "empty as the screendumps suggest
** removed as i am a new user only one picture is allowed **
The log tells about a missing method:
// _,///./_//__/
Healthcheck shell…
e[32m[PASS]e[0m PHP version 7.0.33-0+deb9u6.
e[32m[PASS]e[0m PCRE compiled with unicode support.
e[32m[PASS]e[0m The temporary directory and its content are writable.
e[32m[PASS]e[0m The public image directory and its content are writable.
e[32m[PASS]e[0m The logs directory and its content are writable.
e[32m[PASS]e[0m GD or Imagick extension is installed.
e[32m[PASS]e[0m Intl extension is installed.
e[32m[PASS]e[0m Mbstring extension is installed.
e[32m[PASS]e[0m The application config file is present
e[32m[PASS]e[0m The passbolt config file is present
e[32m[PASS]e[0m Debug mode is off.
e[32m[PASS]e[0m Cache is working.
e[32m[PASS]e[0m Unique value set for security.salt
e[32m[PASS]e[0m Full base url is set to https://wapassbolt.webapoteket.dk
e[32m[PASS]e[0m App.fullBaseUrl validation OK.
e[32m[PASS]e[0m /healthcheck/status is reachable.
e[32m[PASS]e[0m SSL peer certificate validates
e[32m[PASS]e[0m Hostname is matching in SSL certificate.
e[32m[PASS]e[0m Not using a self-signed certificate
e[32m[PASS]e[0m The application is able to connect to the database
e[32m[PASS]e[0m 23 tables found
e[32m[PASS]e[0m Some default content is present
e[32m[PASS]e[0m The database schema up to date.
e[32m[PASS]e[0m PHP GPG Module is installed and loaded.
e[32m[PASS]e[0m The environment variable GNUPGHOME is set to /home/www-data/.gnupg.
e[32m[PASS]e[0m The directory /home/www-data/.gnupg containing the keyring is writable by the webserver user.
e[32m[PASS]e[0m The server gpg key is not the default one
e[32m[PASS]e[0m The public key file is defined in config/passbolt.php and readable.
e[32m[PASS]e[0m The private key file is defined in config/passbolt.php and readable.
e[32m[PASS]e[0m The server key fingerprint matches the one defined in config/passbolt.php.
e[32m[PASS]e[0m The server public key defined in the config/passbolt.php (or environment variables) is in the keyring.
e[32m[PASS]e[0m There is a valid email id defined for the server key.
e[32m[PASS]e[0m The public key can be used to encrypt a message.
e[32m[PASS]e[0m The private key can be used to sign a message.
e[32m[PASS]e[0m The public and private keys can be used to encrypt and sign a message.
e[32m[PASS]e[0m The private key can be used to decrypt a message.
e[32m[PASS]e[0m The private key can be used to decrypt and verify a message.
e[32m[PASS]e[0m The public key can be used to verify a signature.
e[32m[PASS]e[0m Using latest passbolt version (2.11.0).
e[32m[PASS]e[0m Passbolt is configured to force SSL use.
e[32m[PASS]e[0m App.fullBaseUrl is set to HTTPS.
e[32m[PASS]e[0m Selenium API endpoints are disabled.
e[32m[PASS]e[0m Search engine robots are told not to index content.
e[32m[PASS]e[0m Registration is closed, only administrators can add users.
e[32m[PASS]e[0m Serving the compiled version of the javascript app
e[32m[PASS]e[0m All email notifications will be sent.
e[32mNo error found. Nice one sparky!e[0m
