Passbolt Behind Nginx Reverse Proxy
Probably a newb question here and this might not be specific to Passbolt, but I’ve had Passbolt running just fine behind Squid on pfSense for over a year. I just changed over and put Passbolt behind Nginx Reverse Proxy (different server than Passbolt server) and for the life of me can’t figure out what I’m missing.
Locally, everything works great. The problem is specific to the reverse proxy coming from the public side. Other web services are being served up using the same reverse proxy, and these work without issue.
  1. I can navigate to my public url and the passbolt login appears (with SSL) to enter my email address.
  2. I enter my email address, submit, there is a long delay (not normal), and I receive the recovery email and link.
  3. I go through recovery, submit my private key, and I receive the following error: An internal error occurred. The server response could not be parsed. Please contact your administrator.
  4. I then get the confirmation email that my account has been recovered (it hasn’t), and it returns the message "User Agent: " "User IP: " both blank.
  5. Rinse and repeat.
Nginx Reverse Proxy Server Block Below. I have tried multiple iterations of the block with no luck.
Is there a Passbolt/Nginx wiz that can help out?
server {
    listen 80 default_server;
    server_name _;
server {
        listen 443 ssl http2;
        server_name *.passbolt.mydomain.com passbolt.mydomain.com;
        ssl_certificate /etc/ssl/certs/ssl-bundle.crt;
        ssl_certificate_key /etc/ssl/private/key-decrypted.key;
        location / {
               proxy_pass https://172.16.0.24;
– Ubuntu 22.04.1
– nginx/1.18.0
– mysql 8.0.30
– php 8.1.2
– Passbolt 3.7.0
/ _
//./_//__/
[PASS] PHP version 8.1.2.
[PASS] Full base url is set to https://passbolt.mydomain.com
[PASS] 26 tables found
[PASS] Using latest passbolt version (3.7.0).
Hi @pattonjo :wave: and welcome to passbolt community forum :handshake:
Can you check logs on your both nginx servers (in /var/log/nginx)? The server response could not be parsed is usually an error nginx side and the error message will help.
Passbolt Nginx Error Log
2022/08/03 23:44:25 [info] 12404#12404: *64 SSL_read() failed (SSL: error:0A00041A:SSL routines::tlsv1 alert decode error:SSL alert number 50) while sending to client, client: 172.16.0.26, server: passbolt.mydomain.com, request: “POST /auth/verify.json?api-version=v2 HTTP/1.0”, upstream: “fastcgi://unix:/run/php/php8.1-fpm.sock”, host: “172.16.0.24”
2022/08/03 23:48:32 [info] 12404#12404: *80 SSL_read() failed (SSL: error:0A00041A:SSL routines::tlsv1 alert decode error:SSL alert number 50) while sending to client, client: 172.16.0.26, server: passbolt.mydomain.com, request: “POST /auth/login.json?api-version=v2 HTTP/1.0”, upstream: “fastcgi://unix:/run/php/php8.1-fpm.sock”, host: “172.16.0.24”
2022/08/03 23:48:37 [info] 12404#12404: *84 SSL_read() failed (SSL: error:0A00041A:SSL routines::tlsv1 alert decode error:SSL alert number 50) while sending to client, client: 172.16.0.26, server: passbolt.mydomain.com, request: “POST /auth/verify.json?api-version=v2 HTTP/1.0”, upstream: “fastcgi://unix:/run/php/php8.1-fpm.sock”, host: “172.16.0.24”
2022/08/03 23:51:54 [info] 12404#12404: *109 SSL_read() failed (SSL: error:0A00041A:SSL routines::tlsv1 alert decode error:SSL alert number 50) while sending to client, client: 172.16.0.26, server: passbolt.mydomain.com, request: “PUT /mobile/transfers/2cffa969-6ffc-426d-9bd9-c8165c01910f/41152f25-be21-406f-b6ff-fc8d5bdc4712.json HTTP/1.0”, upstream: “fastcgi://unix:/run/php/php8.1-fpm.sock”, host: “172.16.0.24”
2022/08/03 23:51:55 [info] 12404#12404: *113 SSL_read() failed (SSL: error:0A00041A:SSL routines::tlsv1 alert decode error:SSL alert number 50) while sending to client, client: 172.16.0.26, server: passbolt.mydomain.com, request: “PUT /mobile/transfers/2cffa969-6ffc-426d-9bd9-c8165c01910f/41152f25-be21-406f-b6ff-fc8d5bdc4712.json HTTP/1.0”, upstream: “fastcgi://unix:/run/php/php8.1-fpm.sock”, host: “172.16.0.24”
2022/08/03 23:51:55 [info] 12404#12404: *117 SSL_read() failed (SSL: error:0A00041A:SSL routines::tlsv1 alert decode error:SSL alert number 50) while sending to client, client: 172.16.0.26, server: passbolt.mydomain.com, request: “PUT /mobile/transfers/2cffa969-6ffc-426d-9bd9-c8165c01910f/41152f25-be21-406f-b6ff-fc8d5bdc4712.json HTTP/1.0”, upstream: “fastcgi://unix:/run/php/php8.1-fpm.sock”, host: “172.16.0.24”
2022/08/03 23:51:56 [info] 12404#12404: *121 SSL_read() failed (SSL: error:0A00041A:SSL routines::tlsv1 alert decode error:SSL alert number 50) while sending to client, client: 172.16.0.26, server: passbolt.mydomain.com, request: “PUT /mobile/transfers/2cffa969-6ffc-426d-9bd9-c8165c01910f/41152f25-be21-406f-b6ff-fc8d5bdc4712.json HTTP/1.0”, upstream: “fastcgi://unix:/run/php/php8.1-fpm.sock”, host: “172.16.0.24”
2022/08/03 23:51:57 [info] 12404#12404: *125 SSL_read() failed (SSL: error:0A00041A:SSL routines::tlsv1 alert decode error:SSL alert number 50) while sending to client, client: 172.16.0.26, server: passbolt.mydomain.com, request: “PUT /mobile/transfers/2cffa969-6ffc-426d-9bd9-c8165c01910f/41152f25-be21-406f-b6ff-fc8d5bdc4712.json?contain%5Buser.profile%5D=1 HTTP/1.0”, upstream: “fastcgi://unix:/run/php/php8.1-fpm.sock”, host: “172.16.0.24”
2022/08/03 23:55:25 [info] 12404#12404: *132 SSL_read() failed (SSL: error:0A00041A:SSL routines::tlsv1 alert decode error:SSL alert number 50) while sending to client, client: 172.16.0.26, server: passbolt.mydomain.com, request: “POST /users/recover.json?api-version=v2 HTTP/1.0”, upstream: “fastcgi://unix:/run/php/php8.1-fpm.sock”, host: “172.16.0.24”, referrer: “https://passbolt.mydomain.com/auth/login?redirect=%2F&locale=en-UK
2022/08/03 23:57:01 [crit] 12404#12404: *136 SSL_read() failed (SSL: error:0A000126:SSL routines::unexpected eof while reading) while processing HTTP/2 connection, client: 172.16.0.20, server: 0.0.0.0:443
2022/08/03 23:58:51 [crit] 12404#12404: *135 SSL_read() failed (SSL: error:0A000126:SSL routines::unexpected eof while reading) while processing HTTP/2 connection, client: 172.16.0.20, server: 0.0.0.0:443
2022/08/04 00:02:31 [crit] 12404#12404: *143 SSL_read() failed (SSL: error:0A000126:SSL routines::unexpected eof while reading) while processing HTTP/2 connection, client: 172.16.0.20, server: 0.0.0.0:443
2022/08/04 00:02:31 [crit] 12404#12404: *144 SSL_read() failed (SSL: error:0A000126:SSL routines::unexpected eof while reading) while processing HTTP/2 connection, client: 172.16.0.20, server: 0.0.0.0:443
2022/08/04 00:16:28 [info] 12404#12404: *178 SSL_read() failed (SSL: error:0A00041A:SSL routines::tlsv1 alert decode error:SSL alert number 50) while sending to client, client: 172.16.0.26, server: passbolt.mydomain.com, request: “POST /auth/verify.json?api-version=v2 HTTP/1.0”, upstream: “fastcgi://unix:/run/php/php8.1-fpm.sock”, host: “172.16.0.24”
2022/08/04 00:17:57 [info] 12404#12404: *182 SSL_read() failed (SSL: error:0A00041A:SSL routines::tlsv1 alert decode error:SSL alert number 50) while sending to client, client: 172.16.0.26, server: passbolt.mydomain.com, request: “POST /setup/recover/complete/8c86a981-0313-4f5d-8cb1-8f028a9f81cd HTTP/1.0”, upstream: “fastcgi://unix:/run/php/php8.1-fpm.sock”, host: “172.16.0.24”
2022/08/04 01:56:46 [info] 12404#12404: *333 SSL_read() failed (SSL: error:0A00041A:SSL routines::tlsv1 alert decode error:SSL alert number 50) while sending to client, client: 172.16.0.26, server: passbolt.mydomain.com, request: “POST /users/recover.json?api-version=v2 HTTP/1.0”, upstream: “fastcgi://unix:/run/php/php8.1-fpm.sock”, host: “passbolt.mydomain.com”, referrer: “https://passbolt.mydomain.com/auth/login?redirect=%2F&locale=en-UK
2022/08/04 21:53:48 [info] 12404#12404: *582 SSL_read() failed (SSL: error:0A00041A:SSL routines::tlsv1 alert decode error:SSL alert number 50) while sending to client, client: 172.16.0.26, server: passbolt.mydomain.com, request: “POST /users/recover.json?api-version=v2 HTTP/1.0”, upstream: “fastcgi://unix:/run/php/php8.1-fpm.sock”, host: “passbolt.mydomain.com”, referrer: “https://passbolt.mydomain.com/auth/login?redirect=%2F&locale=en-UK
2022/08/04 22:05:38 [crit] 12404#12404: *602 SSL_read() failed (SSL: error:0A000126:SSL routines::unexpected eof while reading) while processing HTTP/2 connection, client: 172.16.0.20, server: 0.0.0.0:443
2022/08/04 22:05:38 [crit] 12404#12404: *601 SSL_read() failed (SSL: error:0A000126:SSL routines::unexpected eof while reading) while processing HTTP/2 connection, client: 172.16.0.20, server: 0.0.0.0:443
2022/08/04 22:08:00 [info] 12404#12404: *635 SSL_read() failed (SSL: error:0A00041A:SSL routines::tlsv1 alert decode error:SSL alert number 50) while sending to client, client: 172.16.0.26, server: passbolt.mydomain.com, request: “POST /auth/verify.json?api-version=v2 HTTP/1.0”, upstream: “fastcgi://unix:/run/php/php8.1-fpm.sock”, host: “passbolt.mydomain.com
2022/08/04 22:08:29 [info] 12404#12404: *637 SSL_read() failed (SSL: error:0A00041A:SSL routines::tlsv1 alert decode error:SSL alert number 50) while sending to client, client: 172.16.0.26, server: passbolt.mydomain.com, request: “POST /setup/recover/complete/8c86a981-0313-4f5d-8cb1-8f028a9f81cd HTTP/1.0”, upstream: “fastcgi://unix:/run/php/php8.1-fpm.sock”, host: “passbolt.mydomain.com
2022/08/04 22:30:22 [info] 12404#12404: *664 SSL_read() failed (SSL: error:0A00041A:SSL routines::tlsv1 alert decode error:SSL alert number 50) while sending to client, client: 172.16.0.26, server: passbolt.mydomain.com, request: “POST /users/recover.json?api-version=v2 HTTP/1.0”, upstream: “fastcgi://unix:/run/php/php8.1-fpm.sock”, host: “passbolt.mydomain.com”, referrer: “https://passbolt.mydomain.com/auth/login?redirect=%2F&locale=en-UK
2022/08/04 22:33:08 [crit] 12404#12404: *667 SSL_read() failed (SSL: error:0A000126:SSL routines::unexpected eof while reading) while processing HTTP/2 connection, client: 172.16.0.20, server: 0.0.0.0:443
2022/08/04 22:33:08 [crit] 12404#12404: *666 SSL_read() failed (SSL: error:0A000126:SSL routines::unexpected eof while reading) while processing HTTP/2 connection, client: 172.16.0.20, server: 0.0.0.0:443
2022/08/04 23:26:18 [crit] 12404#12404: *668 SSL_read() failed (SSL: error:0A000126:SSL routines::unexpected eof while reading) while processing HTTP/2 connection, client: 172.16.0.20, server: 0.0.0.0:443
2022/08/04 23:26:18 [crit] 12404#12404: *669 SSL_read() failed (SSL: error:0A000126:SSL routines::unexpected eof while reading) while processing HTTP/2 connection, client: 172.16.0.20, server: 0.0.0.0:443
2022/08/04 23:27:59 [info] 12404#12404: *699 SSL_read() failed (SSL: error:0A00041A:SSL routines::tlsv1 alert decode error:SSL alert number 50) while sending to client, client: 172.16.0.26, server: passbolt.mydomain.com, request: “POST /auth/verify.json?api-version=v2 HTTP/1.0”, upstream: “fastcgi://unix:/run/php/php8.1-fpm.sock”, host: “passbolt.mydomain.com
2022/08/04 23:28:36 [info] 12404#12404: *701 SSL_read() failed (SSL: error:0A00041A:SSL routines::tlsv1 alert decode error:SSL alert number 50) while sending to client, client: 172.16.0.26, server: passbolt.mydomain.com, request: “POST /setup/recover/complete/8c86a981-0313-4f5d-8cb1-8f028a9f81cd HTTP/1.0”, upstream: “fastcgi://unix:/run/php/php8.1-fpm.sock”, host: “passbolt.mydomain.com
2022/08/04 23:37:18 [crit] 12404#12404: *703 SSL_read() failed (SSL: error:0A000126:SSL routines::unexpected eof while reading) while processing HTTP/2 connection, client: 172.16.0.20, server: 0.0.0.0:443
2022/08/04 23:37:18 [crit] 12406#12406: *704 SSL_read() failed (SSL: error:0A000126:SSL routines::unexpected eof while reading) while processing HTTP/2 connection, client: 172.16.0.20, server: 0.0.0.0:443
Nginx Reverse Proxy Error Log
2022/08/04 00:16:28 [crit] 2466#2466: *71 SSL_read() failed (SSL: error:0A000126:SSL routines::unexpected eof while reading) while reading response header from upstream, client: 98.243.113.57, server: passbolt.mydomain.com, request: “POST /auth/verify.json?api-version=v2 HTTP/2.0”, upstream: “https://172.16.0.24:443/auth/verify.json?api-version=v2”, host: “passbolt.mydomain.com
2022/08/04 00:17:57 [crit] 2466#2466: *71 SSL_read() failed (SSL: error:0A000126:SSL routines::unexpected eof while reading) while reading response header from upstream, client: 98.243.113.57, server: passbolt.mydomain.com, request: “POST /setup/recover/complete/8c86a981-0313-4f5d-8cb1-8f028a9f81cd HTTP/2.0”, upstream: “https://172.16.0.24:443/setup/recover/complete/8c86a981-0313-4f5d-8cb1-8f028a9f81cd”, host: “passbolt.mydomain.com
2022/08/04 00:49:11 [error] 2699#2699: *1 open() “/usr/share/nginx/html/favicon.ico” failed (2: No such file or directory), client: 98.243.113.57, server: mydomain.com, request: “GET /favicon.ico HTTP/1.1”, host: “passbolt.mydomain.com”, referrer: “http://passbolt.mydomain.com/
2022/08/04 00:49:52 [alert] 2700#2700: *2 open socket #8 left in connection 3
2022/08/04 00:49:52 [alert] 2700#2700: aborting
2022/08/04 00:50:16 [crit] 2720#2720: *6 SSL_read() failed (SSL: error:0A000126:SSL routines::unexpected eof while reading) while processing HTTP/2 connection, client: 98.243.113.57, server: 0.0.0.0:443
2022/08/04 00:50:16 [crit] 2720#2720: *7 SSL_read() failed (SSL: error:0A000126:SSL routines::unexpected eof while reading) while processing HTTP/2 connection, client: 98.243.113.57, server: 0.0.0.0:443
2022/08/04 00:50:43 [alert] 2720#2720: *3 open socket #9 left in connection 4
2022/08/04 00:50:43 [alert] 2720#2720: aborting
2022/08/04 00:54:54 [crit] 2733#2733: *11 SSL_do_handshake() failed (SSL: error:0A00006C:SSL routines::bad key share) while SSL handshaking, client: 152.32.234.60, server: 0.0.0.0:443
2022/08/04 01:29:49 [crit] 2733#2733: *60 SSL_read() failed (SSL: error:0A000126:SSL routines::unexpected eof while reading) while processing HTTP/2 connection, client: 154.6.86.133, server: 0.0.0.0:443
2022/08/04 01:29:49 [crit] 2732#2732: *61 SSL_read() failed (SSL: error:0A000126:SSL routines::unexpected eof while reading) while processing HTTP/2 connection, client: 154.6.86.133, server: 0.0.0.0:443
2022/08/04 01:40:59 [crit] 2733#2733: *76 SSL_read() failed (SSL: error:0A000126:SSL routines::unexpected eof while reading) while processing HTTP/2 connection, client: 154.6.86.133, server: 0.0.0.0:443
2022/08/04 01:40:59 [error] 2732#2732: *77 open() “/usr/share/nginx/html/favicon.ico” failed (2: No such file or directory), client: 154.6.86.133, server: mydomain.com, request: “GET /favicon.ico HTTP/2.0”, host: “mydomain.com”, referrer: “https://mydomain.com/
2022/08/04 01:54:14 [crit] 2767#2767: *8 SSL_do_handshake() failed (SSL: error:0A000126:SSL routines::unexpected eof while reading) while SSL handshaking, client: 98.243.113.57, server: 0.0.0.0:443
2022/08/04 01:54:14 [crit] 2767#2767: *5 SSL_do_handshake() failed (SSL: error:0A000126:SSL routines::unexpected eof while reading) while SSL handshaking, client: 98.243.113.57, server: 0.0.0.0:443
2022/08/04 01:54:14 [crit] 2768#2768: *6 SSL_do_handshake() failed (SSL: error:0A000126:SSL routines::unexpected eof while reading) while SSL handshaking, client: 98.243.113.57, server: 0.0.0.0:443
2022/08/04 01:54:14 [crit] 2768#2768: *7 SSL_do_handshake() failed (SSL: error:0A000126:SSL routines::unexpected eof while reading) while SSL handshaking, client: 98.243.113.57, server: 0.0.0.0:443
2022/08/04 01:54:16 [crit] 2767#2767: *9 SSL_do_handshake() failed (SSL: error:0A000126:SSL routines::unexpected eof while reading) while SSL handshaking, client: 98.243.113.57, server: 0.0.0.0:443
2022/08/04 01:54:44 [crit] 2767#2767: *10 SSL_read() failed (SSL: error:0A000126:SSL routines::unexpected eof while reading) while processing HTTP/2 connection, client: 98.243.113.57, server: 0.0.0.0:443
2022/08/04 01:55:00 [crit] 2767#2767: *15 SSL_read() failed (SSL: error:0A000126:SSL routines::unexpected eof while reading) while processing HTTP/2 connection, client: 98.243.113.57, server: 0.0.0.0:443
2022/08/04 01:55:07 [crit] 2768#2768: *14 SSL_read() failed (SSL: error:0A000126:SSL routines::unexpected eof while reading) while processing HTTP/2 connection, client: 98.243.113.57, server: 0.0.0.0:443
2022/08/04 01:56:47 [crit] 2767#2767: *23 SSL_read() failed (SSL: error:0A000126:SSL routines::unexpected eof while reading) while reading response header from upstream, client: 98.243.113.57, server: passbolt.mydomain.com, request: “POST /users/recover.json?api-version=v2 HTTP/2.0”, upstream: “https://172.16.0.24:443/users/recover.json?api-version=v2”, host: “passbolt.mydomain.com”, referrer: “https://passbolt.mydomain.com/auth/login?redirect=%2F&locale=en-UK
2022/08/04 01:59:30 [crit] 2784#2784: 37 SSL_read() failed (SSL: error:0A000126:SSL routines::unexpected eof while reading) while processing HTTP/2 connection, client: 98.243.113.57, server: 0.0.0.0:443
2022/08/04 01:59:30 [crit] 2783#2783: 38 SSL_read() failed (SSL: error:0A000126:SSL routines::unexpected eof while reading) while processing HTTP/2 connection, client: 98.243.113.57, server: 0.0.0.0:443
2022/08/04 02:04:38 [crit] 2803#2803: 7 SSL_read() failed (SSL: error:0A000126:SSL routines::unexpected eof while reading) while processing HTTP/2 connection, client: 98.243.113.57, server: 0.0.0.0:443
2022/08/04 02:04:38 [crit] 2803#2803: 6 SSL_read() failed (SSL: error:0A000126:SSL routines::unexpected eof while reading) while processing HTTP/2 connection, client: 98.243.113.57, server: 0.0.0.0:443
2022/08/04 02:06:54 [emerg] 2815#2815: invalid server name or wildcard "
" on 0.0.0.0:80
2022/08/04 02:06:57 [emerg] 2820#2820: invalid server name or wildcard "
" on 0.0.0.0:80
2022/08/04 02:10:11 [crit] 2831#2831: *11 SSL_read() failed (SSL: error:0A000126:SSL routines::unexpected eof while reading) while processing HTTP/2 connection, client: 98.243.113.57, server: 0.0.0.0:443
2022/08/04 02:10:11 [crit] 2831#2831: *3 SSL_read() failed (SSL: error:0A000126:SSL routines::unexpected eof while reading) while processing HTTP/2 connection, client: 98.243.113.57, server: 0.0.0.0:443
2022/08/04 02:10:29 [error] 2831#2831: *26 open() “/usr/share/nginx/html/boaform/admin/formLogin” failed (2: No such file or directory), client: 122.194.11.101, server: mydomain.com, request: “GET /boaform/admin/formLogin?username=adminisp&psd=adminisp HTTP/1.0”
2022/08/04 02:16:37 [emerg] 2848#2848: unexpected end of file, expecting “}” in /etc/nginx/sites-enabled/reverse-proxy.conf:95
2022/08/04 02:16:39 [emerg] 2853#2853: unexpected end of file, expecting “}” in /etc/nginx/sites-enabled/reverse-proxy.conf:95
2022/08/04 02:17:14 [emerg] 2866#2866: no port in upstream “php-fpm” in /etc/nginx/sites-enabled/reverse-proxy.conf:85
2022/08/04 02:17:15 [emerg] 2871#2871: no port in upstream “php-fpm” in /etc/nginx/sites-enabled/reverse-proxy.conf:85
2022/08/04 02:19:26 [emerg] 2879#2879: unexpected “}” in /etc/nginx/sites-enabled/reverse-proxy.conf:68
2022/08/04 02:19:28 [emerg] 2882#2882: unexpected “}” in /etc/nginx/sites-enabled/reverse-proxy.conf:68
2022/08/04 02:20:17 [crit] 2894#2894: *3 SSL_read() failed (SSL: error:0A000126:SSL routines::unexpected eof while reading) while processing HTTP/2 connection, client: 98.243.113.57, server: 0.0.0.0:443
2022/08/04 02:23:43 [error] 2894#2894: *4 open() “/usr/share/nginx/html/owa/auth/logon.aspx” failed (2: No such file or directory), client: 192.241.222.197, server: mydomain.com, request: “GET /owa/auth/logon.aspx?url=https%3a%2f%2f1%2fecp%2f HTTP/1.1”, host: “mypublicIPAddress”
2022/08/04 02:23:51 [crit] 2894#2894: *4 SSL_read() failed (SSL: error:0A000126:SSL routines::unexpected eof while reading) while keepalive, client: 192.241.222.197, server: 0.0.0.0:443
2022/08/04 02:25:59 [crit] 2914#2914: *6 SSL_read() failed (SSL: error:0A000126:SSL routines::unexpected eof while reading) while processing HTTP/2 connection, client: 98.243.113.57, server: 0.0.0.0:443
2022/08/04 02:25:59 [crit] 2914#2914: *5 SSL_read() failed (SSL: error:0A000126:SSL routines::unexpected eof while reading) while processing HTTP/2 connection, client: 98.243.113.57, server: 0.0.0.0:443
2022/08/04 02:26:05 [crit] 2914#2914: *13 SSL_read() failed (SSL: error:0A000126:SSL routines::unexpected eof while reading) while processing HTTP/2 connection, client: 98.243.113.57, server: 0.0.0.0:443
2022/08/04 02:26:05 [crit] 2915#2915: *7 SSL_read() failed (SSL: error:0A000126:SSL routines::unexpected eof while reading) while processing HTTP/2 connection, client: 98.243.113.57, server: 0.0.0.0:443
2022/08/04 02:26:55 [crit] 2914#2914: *39 SSL_read() failed (SSL: error:0A000126:SSL routines::unexpected eof while reading) while processing HTTP/2 connection, client: 98.243.113.57, server: 0.0.0.0:443
2022/08/04 02:26:55 [crit] 2914#2914: *40 SSL_read() failed (SSL: error:0A000126:SSL routines::unexpected eof while reading) while processing HTTP/2 connection, client: 98.243.113.57, server: 0.0.0.0:443
2022/08/04 02:27:36 [alert] 2914#2914: *35 open socket #13 left in connection 5
2022/08/04 02:27:36 [alert] 2914#2914: aborting
2022/08/04 02:27:48 [crit] 2929#2929: *6 SSL_read() failed (SSL: error:0A000126:SSL routines::unexpected eof while reading) while processing HTTP/2 connection, client: 98.243.113.57, server: 0.0.0.0:443
2022/08/04 02:27:48 [crit] 2928#2928: *7 SSL_read() failed (SSL: error:0A000126:SSL routines::unexpected eof while reading) while processing HTTP/2 connection, client: 98.243.113.57, server: 0.0.0.0:443
2022/08/04 02:27:52 [crit] 2929#2929: *13 SSL_read() failed (SSL: error:0A000126:SSL routines::unexpected eof while reading) while processing HTTP/2 connection, client: 98.243.113.57, server: 0.0.0.0:443
2022/08/04 02:27:52 [crit] 2929#2929: *5 SSL_read() failed (SSL: error:0A000126:SSL routines::unexpected eof while reading) while processing HTTP/2 connection, client: 98.243.113.57, server: 0.0.0.0:443
2022/08/04 02:28:16 [error] 2945#2945: *1 open() “/usr/share/nginx/html/favicon.ico” failed (2: No such file or directory), client: 98.243.113.57, server: mydomain.com, request: “GET /favicon.ico HTTP/1.1”, host: “passbolt.mydomain.com”, referrer: “http://passbolt.mydomain.com/
2022/08/04 02:28:45 [crit] 2957#2957: *6 SSL_read() failed (SSL: error:0A000126:SSL routines::unexpected eof while reading) while processing HTTP/2 connection, client: 98.243.113.57, server: 0.0.0.0:443
2022/08/04 02:28:45 [crit] 2957#2957: *7 SSL_read() failed (SSL: error:0A000126:SSL routines::unexpected eof while reading) while processing HTTP/2 connection, client: 98.243.113.57, server: 0.0.0.0:443
2022/08/04 02:28:45 [error] 2957#2957: *5 open() “/usr/share/nginx/html/js/app/stylesheet.js” failed (2: No such file or directory), client: 98.243.113.57, server: mydomain.com, request: “GET /js/app/stylesheet.js?v=3.7.0 HTTP/2.0”, host: “passbolt.mydomain.com
2022/08/04 02:28:45 [error] 2957#2957: *5 open() “/usr/share/nginx/html/js/app/api-vendors.js” failed (2: No such file or directory), client: 98.243.113.57, server: mydomain.com, request: “GET /js/app/api-vendors.js?v=3.7.0 HTTP/2.0”, host: “passbolt.mydomain.com
2022/08/04 02:28:45 [error] 2957#2957: *5 open() “/usr/share/nginx/html/js/app/api-triage.js” failed (2: No such file or directory), client: 98.243.113.57, server: mydomain.com, request: “GET /js/app/api-triage.js?v=3.7.0 HTTP/2.0”, host: “passbolt.mydomain.com
2022/08/04 02:28:45 [error] 2957#2957: *5 open() “/usr/share/nginx/html/favicon.ico” failed (2: No such file or directory), client: 98.243.113.57, server: mydomain.com, request: “GET /favicon.ico HTTP/2.0”, host: “passbolt.mydomain.com
2022/08/04 02:28:45 [error] 2957#2957: *5 open() “/usr/share/nginx/html/favicon_32.png” failed (2: No such file or directory), client: 98.243.113.57, server: mydomain.com, request: “GET /favicon_32.png HTTP/2.0”, host: “passbolt.mydomain.com
2022/08/04 02:28:45 [error] 2957#2957: *5 open() “/usr/share/nginx/html/favicon_57.png” failed (2: No such file or directory), client: 98.243.113.57, server: mydomain.com, request: “GET /favicon_57.png HTTP/2.0”, host: “passbolt.mydomain.com
2022/08/04 02:28:45 [error] 2957#2957: *5 open() “/usr/share/nginx/html/favicon_76.png” failed (2: No such file or directory), client: 98.243.113.57, server: mydomain.com, request: “GET /favicon_76.png HTTP/2.0”, host: “passbolt.mydomain.com
2022/08/04 02:28:45 [error] 2957#2957: *5 open() “/usr/share/nginx/html/favicon_96.png” failed (2: No such file or directory), client: 98.243.113.57, server: mydomain.com, request: “GET /favicon_96.png HTTP/2.0”, host: “passbolt.mydomain.com
2022/08/04 02:28:45 [error] 2957#2957: *5 open() “/usr/share/nginx/html/favicon_128.png” failed (2: No such file or directory), client: 98.243.113.57, server: mydomain.com, request: “GET /favicon_128.png HTTP/2.0”, host: “passbolt.mydomain.com
2022/08/04 02:28:45 [error] 2957#2957: *5 open() “/usr/share/nginx/html/favicon_192.png” failed (2: No such file or directory), client: 98.243.113.57, server: mydomain.com, request: “GET /favicon_192.png HTTP/2.0”, host: “passbolt.mydomain.com
2022/08/04 02:28:45 [error] 2957#2957: *5 open() “/usr/share/nginx/html/favicon_228.png” failed (2: No such file or directory), client: 98.243.113.57, server: mydomain.com, request: “GET /favicon_228.png HTTP/2.0”, host: “passbolt.mydomain.com
2022/08/04 02:29:09 [alert] 2957#2957: *3 open socket #13 left in connection 5
2022/08/04 02:29:09 [alert] 2957#2957: aborting
2022/08/04 02:29:55 [error] 2987#2987: *6 open() “/usr/share/nginx/html/js/app/stylesheet.js” failed (2: No such file or directory), client: 98.243.113.57, server: mydomain.com, request: “GET /js/app/stylesheet.js?v=3.7.0 HTTP/2.0”, host: “passbolt.mydomain.com
2022/08/04 02:29:55 [crit] 2988#2988: *7 SSL_read() failed (SSL: error:0A000126:SSL routines::unexpected eof while reading) while processing HTTP/2 connection, client: 98.243.113.57, server: 0.0.0.0:443
2022/08/04 02:29:55 [error] 2987#2987: *6 open() “/usr/share/nginx/html/js/app/api-vendors.js” failed (2: No such file or directory), client: 98.243.113.57, server: mydomain.com, request: “GET /js/app/api-vendors.js?v=3.7.0 HTTP/2.0”, host: “passbolt.mydomain.com
2022/08/04 02:29:55 [error] 2987#2987: *6 open() “/usr/share/nginx/html/js/app/api-triage.js” failed (2: No such file or directory), client: 98.243.113.57, server: mydomain.com, request: “GET /js/app/api-triage.js?v=3.7.0 HTTP/2.0”, host: “passbolt.mydomain.com
2022/08/04 02:29:55 [crit] 2987#2987: *5 SSL_read() failed (SSL: error:0A000126:SSL routines::unexpected eof while reading) while processing HTTP/2 connection, client: 98.243.113.57, server: 0.0.0.0:443
2022/08/04 02:29:55 [error] 2987#2987: *6 open() “/usr/share/nginx/html/favicon.ico” failed (2: No such file or directory), client: 98.243.113.57, server: mydomain.com, request: “GET /favicon.ico HTTP/2.0”, host: “passbolt.mydomain.com
2022/08/04 02:29:55 [error] 2987#2987: *6 open() “/usr/share/nginx/html/favicon_32.png” failed (2: No such file or directory), client: 98.243.113.57, server: mydomain.com, request: “GET /favicon_32.png HTTP/2.0”, host: “passbolt.mydomain.com
2022/08/04 02:29:55 [error] 2987#2987: *6 open() “/usr/share/nginx/html/favicon_57.png” failed (2: No such file or directory), client: 98.243.113.57, server: mydomain.com, request: “GET /favicon_57.png HTTP/2.0”, host: “passbolt.mydomain.com
2022/08/04 02:29:55 [error] 2987#2987: *6 open() “/usr/share/nginx/html/favicon_76.png” failed (2: No such file or directory), client: 98.243.113.57, server: mydomain.com, request: “GET /favicon_76.png HTTP/2.0”, host: “passbolt.mydomain.com
2022/08/04 02:29:55 [error] 2987#2987: *6 open() “/usr/share/nginx/html/favicon_96.png” failed (2: No such file or directory), client: 98.243.113.57, server: mydomain.com, request: “GET /favicon_96.png HTTP/2.0”, host: “passbolt.mydomain.com
2022/08/04 02:29:55 [error] 2987#2987: *6 open() “/usr/share/nginx/html/favicon_128.png” failed (2: No such file or directory), client: 98.243.113.57, server: mydomain.com, request: “GET /favicon_128.png HTTP/2.0”, host: “passbolt.mydomain.com
2022/08/04 02:29:55 [error] 2987#2987: *6 open() “/usr/share/nginx/html/favicon_192.png” failed (2: No such file or directory), client: 98.243.113.57, server: mydomain.com, request: “GET /favicon_192.png HTTP/2.0”, host: “passbolt.mydomain.com
2022/08/04 02:29:55 [error] 2987#2987: *6 open() “/usr/share/nginx/html/favicon_228.png” failed (2: No such file or directory), client: 98.243.113.57, server: mydomain.com, request: “GET /favicon_228.png HTTP/2.0”, host: “passbolt.mydomain.com
2022/08/04 02:30:48 [crit] 2987#2987: *6 SSL_read() failed (SSL: error:0A000126:SSL routines::unexpected eof while reading) while processing HTTP/2 connection, client: 98.243.113.57, server: 0.0.0.0:443
2022/08/04 02:35:21 [error] 3007#3007: *6 open() “/usr/share/nginx/html/js/app/stylesheet.js” failed (2: No such file or directory), client: 98.243.113.57, server: mydomain.com, request: “GET /js/app/stylesheet.js?v=3.7.0 HTTP/2.0”, host: “passbolt.mydomain.com
2022/08/04 02:35:21 [crit] 3006#3006: *5 SSL_read() failed (SSL: error:0A000126:SSL routines::unexpected eof while reading) while processing HTTP/2 connection, client: 98.243.113.57, server: 0.0.0.0:443
2022/08/04 02:35:21 [error] 3007#3007: *6 open() “/usr/share/nginx/html/js/app/api-vendors.js” failed (2: No such file or directory), client: 98.243.113.57, server: mydomain.com, request: “GET /js/app/api-vendors.js?v=3.7.0 HTTP/2.0”, host: “passbolt.mydomain.com
2022/08/04 02:35:21 [crit] 3006#3006: *7 SSL_read() failed (SSL: error:0A000126:SSL routines::unexpected eof while reading) while processing HTTP/2 connection, client: 98.243.113.57, server: 0.0.0.0:443
2022/08/04 02:35:21 [error] 3007#3007: *6 open() “/usr/share/nginx/html/js/app/api-triage.js” failed (2: No such file or directory), client: 98.243.113.57, server: mydomain.com, request: “GET /js/app/api-triage.js?v=3.7.0 HTTP/2.0”, host: “passbolt.mydomain.com
2022/08/04 02:35:21 [error] 3007#3007: *6 open() “/usr/share/nginx/html/favicon.ico” failed (2: No such file or directory), client: 98.243.113.57, server: mydomain.com, request: “GET /favicon.ico HTTP/2.0”, host: “passbolt.mydomain.com
2022/08/04 02:35:21 [error] 3007#3007: *6 open() “/usr/share/nginx/html/favicon_32.png” failed (2: No such file or directory), client: 98.243.113.57, server: mydomain.com, request: “GET /favicon_32.png HTTP/2.0”, host: “passbolt.mydomain.com
2022/08/04 02:35:21 [error] 3007#3007: *6 open() “/usr/share/nginx/html/favicon_57.png” failed (2: No such file or directory), client: 98.243.113.57, server: mydomain.com, request: “GET /favicon_57.png HTTP/2.0”, host: “passbolt.mydomain.com
2022/08/04 02:35:21 [error] 3007#3007: *6 open() “/usr/share/nginx/html/favicon_76.png” failed (2: No such file or directory), client: 98.243.113.57, server: mydomain.com, request: “GET /favicon_76.png HTTP/2.0”, host: “passbolt.mydomain.com
2022/08/04 02:35:21 [error] 3007#3007: *6 open() “/usr/share/nginx/html/favicon_96.png” failed (2: No such file or directory), client: 98.243.113.57, server: mydomain.com, request: “GET /favicon_96.png HTTP/2.0”, host: “passbolt.mydomain.com
2022/08/04 02:35:21 [error] 3007#3007: *6 open() “/usr/share/nginx/html/favicon_128.png” failed (2: No such file or directory), client: 98.243.113.57, server: mydomain.com, request: “GET /favicon_128.png HTTP/2.0”, host: “passbolt.mydomain.com
2022/08/04 02:35:21 [error] 3007#3007: *6 open() “/usr/share/nginx/html/favicon_192.png” failed (2: No such file or directory), client: 98.243.113.57, server: mydomain.com, request: “GET /favicon_192.png HTTP/2.0”, host: “passbolt.mydomain.com
2022/08/04 02:35:21 [error] 3007#3007: *6 open() “/usr/share/nginx/html/favicon_228.png” failed (2: No such file or directory), client: 98.243.113.57, server: mydomain.com, request: “GET /favicon_228.png HTTP/2.0”, host: “passbolt.mydomain.com
2022/08/04 02:36:59 [crit] 3007#3007: *6 SSL_read() failed (SSL: error:0A000126:SSL routines::unexpected eof while reading) while processing HTTP/2 connection, client: 98.243.113.57, server: 0.0.0.0:443
2022/08/04 02:42:47 [error] 3006#3006: *8 open() “/usr/share/nginx/html/favicon.ico” failed (2: No such file or directory), client: 98.243.113.57, server: mydomain.com, request: “GET /favicon.ico HTTP/1.1”, host: “mydomain.com”, referrer: “http://mydomain.com/
2022/08/04 02:43:59 [crit] 3040#3040: *5 SSL_read() failed (SSL: error:0A000126:SSL routines::unexpected eof while reading) while processing HTTP/2 connection, client: 98.243.113.57, server: 0.0.0.0:443
2022/08/04 02:43:59 [error] 3041#3041: *6 open() “/usr/share/nginx/html/js/app/stylesheet.js” failed (2: No such file or directory), client: 98.243.113.57, server: mydomain.com, request: “GET /js/app/stylesheet.js?v=3.7.0 HTTP/2.0”, host: “passbolt.mydomain.com
2022/08/04 02:43:59 [crit] 3040#3040: *7 SSL_read() failed (SSL: error:0A000126:SSL routines::unexpected eof while reading) while processing HTTP/2 connection, client: 98.243.113.57, server: 0.0.0.0:443
2022/08/04 02:43:59 [error] 3041#3041: *6 open() “/usr/share/nginx/html/js/app/api-vendors.js” failed (2: No such file or directory), client: 98.243.113.57, server: mydomain.com, request: “GET /js/app/api-vendors.js?v=3.7.0 HTTP/2.0”, host: “passbolt.mydomain.com
2022/08/04 02:43:59 [error] 3041#3041: *6 open() “/usr/share/nginx/html/js/app/api-triage.js” failed (2: No such file or directory), client: 98.243.113.57, server: mydomain.com, request: “GET /js/app/api-triage.js?v=3.7.0 HTTP/2.0”, host: “passbolt.mydomain.com
2022/08/04 02:43:59 [error] 3041#3041: *6 open() “/usr/share/nginx/html/favicon.ico” failed (2: No such file or directory), client: 98.243.113.57, server: mydomain.com, request: “GET /favicon.ico HTTP/2.0”, host: “passbolt.mydomain.com
2022/08/04 02:43:59 [error] 3041#3041: *6 open() “/usr/share/nginx/html/favicon_32.png” failed (2: No such file or directory), client: 98.243.113.57, server: mydomain.com, request: “GET /favicon_32.png HTTP/2.0”, host: “passbolt.mydomain.com
2022/08/04 02:43:59 [error] 3041#3041: *6 open() “/usr/share/nginx/html/favicon_57.png” failed (2: No such file or directory), client: 98.243.113.57, server: mydomain.com, request: “GET /favicon_57.png HTTP/2.0”, host: “passbolt.mydomain.com
2022/08/04 02:44:00 [error] 3041#3041: *6 open() “/usr/share/nginx/html/favicon_76.png” failed (2: No such file or directory), client: 98.243.113.57, server: mydomain.com, request: “GET /favicon_76.png HTTP/2.0”, host: “passbolt.mydomain.com
2022/08/04 02:44:00 [error] 3041#3041: *6 open() “/usr/share/nginx/html/favicon_96.png” failed (2: No such file or directory), client: 98.243.113.57, server: mydomain.com, request: “GET /favicon_96.png HTTP/2.0”, host: “passbolt.mydomain.com
2022/08/04 02:44:00 [error] 3041#3041: *6 open() “/usr/share/nginx/html/favicon_128.png” failed (2: No such file or directory), client: 98.243.113.57, server: mydomain.com, request: “GET /favicon_128.png HTTP/2.0”, host: “passbolt.mydomain.com
2022/08/04 02:44:00 [error] 3041#3041: *6 open() “/usr/share/nginx/html/favicon_192.png” failed (2: No such file or directory), client: 98.243.113.57, server: mydomain.com, request: “GET /favicon_192.png HTTP/2.0”, host: “passbolt.mydomain.com
2022/08/04 02:44:00 [error] 3041#3041: *6 open() “/usr/share/nginx/html/favicon_228.png” failed (2: No such file or directory), client: 98.243.113.57, server: mydomain.com, request: “GET /favicon_228.png HTTP/2.0”, host: “passbolt.mydomain.com
2022/08/04 02:44:06 [error] 3041#3041: *8 open() “/usr/share/nginx/html/favicon.ico” failed (2: No such file or directory), client: 98.243.113.57, server: mydomain.com, request: “GET /favicon.ico HTTP/1.1”, host: “mydomain.com”, referrer: “http://mydomain.com/
2022/08/04 02:44:24 [error] 3041#3041: *10 open() “/usr/share/nginx/html/favicon.ico” failed (2: No such file or directory), client: 98.243.113.57, server: mydomain.com, request: “GET /favicon.ico HTTP/1.1”, host: “mypublicIPAddress”, referrer: “http://mypublicIPAddress/
2022/08/04 02:44:30 [crit] 3041#3041: *6 SSL_read() failed (SSL: error:0A000126:SSL routines::unexpected eof while reading) while processing HTTP/2 connection, client: 98.243.113.57, server: 0.0.0.0:443
2022/08/04 02:45:09 [error] 3040#3040: *13 open() “/usr/share/nginx/html/favicon.ico” failed (2: No such file or directory), client: 98.243.113.57, server: mydomain.com, request: “GET /favicon.ico HTTP/1.1”, host: “passbolt-test.mydomain.com”, referrer: “http://passbolt-test.mydomain.com/
2022/08/04 02:45:24 [error] 3041#3041: *14 open() “/usr/share/nginx/html/favicon.ico” failed (2: No such file or directory), client: 98.243.113.57, server: mydomain.com, request: “GET /favicon.ico HTTP/2.0”, host: “passbolt.mydomain.com”, referrer: “https://passbolt.mydomain.com/
2022/08/04 02:46:08 [error] 3054#3054: *1 open() “/usr/share/nginx/html/favicon.ico” failed (2: No such file or directory), client: 98.243.113.57, server: mydomain.com, request: “GET /favicon.ico HTTP/2.0”, host: “mydomain.com”, referrer: “https://mydomain.com/
2022/08/04 02:46:29 [crit] 3054#3054: *16 SSL_read() failed (SSL: error:0A000126:SSL routines::unexpected eof while reading) while processing HTTP/2 connection, client: 98.243.113.57, server: 0.0.0.0:443
2022/08/04 02:46:29 [crit] 3054#3054: *3 SSL_read() failed (SSL: error:0A000126:SSL routines::unexpected eof while reading) while processing HTTP/2 connection, client: 98.243.113.57, server: 0.0.0.0:443
2022/08/04 02:46:29 [crit] 3054#3054: *1 SSL_read() failed (SSL: error:0A000126:SSL routines::unexpected eof while reading) while processing HTTP/2 connection, client: 98.243.113.57, server: 0.0.0.0:443
2022/08/04 02:47:15 [crit] 3069#3069: *6 SSL_read() failed (SSL: error:0A000126:SSL routines::unexpected eof while reading) while processing HTTP/2 connection, client: 98.243.113.57, server: 0.0.0.0:443
2022/08/04 02:47:15 [crit] 3069#3069: *7 SSL_read() failed (SSL: error:0A000126:SSL routines::unexpected eof while reading) while processing HTTP/2 connection, client: 98.243.113.57, server: 0.0.0.0:443
2022/08/04 02:47:29 [crit] 3069#3069: *5 SSL_read() failed (SSL: error:0A000126:SSL routines::unexpected eof while reading) while processing HTTP/2 connection, client: 98.243.113.57, server: 0.0.0.0:443
2022/08/04 02:47:29 [crit] 3069#3069: *13 SSL_read() failed (SSL: error:0A000126:SSL routines::unexpected eof while reading) while processing HTTP/2 connection, client: 98.243.113.57, server: 0.0.0.0:443
2022/08/04 05:29:29 [crit] 3086#3086: *115 SSL_do_handshake() failed (SSL: error:0A00006C:SSL routines::bad key share) while SSL handshaking, client: 65.49.20.68, server: 0.0.0.0:443
2022/08/04 05:31:13 [crit] 3086#3086: *122 SSL_read() failed (SSL: error:0A000126:SSL routines::unexpected eof while reading) while keepalive, client: 65.49.20.68, server: 0.0.0.0:443
2022/08/04 08:15:35 [crit] 3086#3086: *146 SSL_read() failed (SSL: error:0A000126:SSL routines::unexpected eof while reading) while keepalive, client: 137.184.118.81, server: 0.0.0.0:443
2022/08/04 08:15:37 [crit] 3086#3086: *151 SSL_read() failed (SSL: error:0A000126:SSL routines::unexpected eof while reading) while keepalive, client: 137.184.118.81, server: 0.0.0.0:443
2022/08/04 08:15:39 [crit] 3086#3086: *156 SSL_read() failed (SSL: error:0A000126:SSL routines::unexpected eof while reading) while keepalive, client: 137.184.118.81, server: 0.0.0.0:443
2022/08/04 08:15:41 [crit] 3086#3086: *161 SSL_read() failed (SSL: error:0A000126:SSL routines::unexpected eof while reading) while keepalive, client: 137.184.118.81, server: 0.0.0.0:443
2022/08/04 08:15:43 [crit] 3086#3086: *166 SSL_read() failed (SSL: error:0A000126:SSL routines::unexpected eof while reading) while keepalive, client: 137.184.118.81, server: 0.0.0.0:443
2022/08/04 08:15:45 [crit] 3086#3086: *171 SSL_read() failed (SSL: error:0A000126:SSL routines::unexpected eof while reading) while keepalive, client: 137.184.118.81, server: 0.0.0.0:443
2022/08/04 08:15:47 [crit] 3086#3086: *176 SSL_read() failed (SSL: error:0A000126:SSL routines::unexpected eof while reading) while keepalive, client: 137.184.118.81, server: 0.0.0.0:443
2022/08/04 09:36:12 [crit] 3086#3086: *211 SSL_read() failed (SSL: error:0A000126:SSL routines::unexpected eof while reading) while keepalive, client: 161.35.131.255, server: 0.0.0.0:443
2022/08/04 09:36:32 [crit] 3086#3086: *213 SSL_read() failed (SSL: error:0A000126:SSL routines::unexpected eof while reading) while keepalive, client: 161.35.131.255, server: 0.0.0.0:443
2022/08/04 09:36:32 [crit] 3086#3086: *215 SSL_read() failed (SSL: error:0A000126:SSL routines::unexpected eof while reading) while keepalive, client: 161.35.131.255, server: 0.0.0.0:443
2022/08/04 11:36:00 [crit] 3086#3086: *222 SSL_read() failed (SSL: error:0A000126:SSL routines::unexpected eof while reading) while keepalive, client: 162.142.125.210, server: 0.0.0.0:443
2022/08/04 13:49:05 [crit] 3086#3086: *378 SSL_read() failed (SSL: error:0A000126:SSL routines::unexpected eof while reading) while keepalive, client: 192.241.206.36, server: 0.0.0.0:443
2022/08/04 13:56:56 [crit] 3086#3086: *380 SSL_read() failed (SSL: error:0A000126:SSL routines::unexpected eof while reading) while processing HTTP/2 connection, client: 157.55.39.54, server: 0.0.0.0:443
2022/08/04 13:57:06 [crit] 3086#3086: *382 SSL_read() failed (SSL: error:0A000126:SSL routines::unexpected eof while reading) while processing HTTP/2 connection, client: 157.55.39.123, server: 0.0.0.0:443
2022/08/04 13:57:14 [crit] 3086#3086: *384 SSL_read() failed (SSL: error:0A000126:SSL routines::unexpected eof while reading) while processing HTTP/2 connection, client: 207.46.13.176, server: 0.0.0.0:443
2022/08/04 13:57:18 [crit] 3086#3086: *386 SSL_read() failed (SSL: error:0A000126:SSL routines::unexpected eof while reading) while processing HTTP/2 connection, client: 40.77.167.83, server: 0.0.0.0:443
2022/08/04 13:57:23 [crit] 3086#3086: *388 SSL_read() failed (SSL: error:0A000126:SSL routines::unexpected eof while reading) while processing HTTP/2 connection, client: 40.77.167.30, server: 0.0.0.0:443
2022/08/04 13:57:32 [crit] 3086#3086: *390 SSL_read() failed (SSL: error:0A000126:SSL routines::unexpected eof while reading) while processing HTTP/2 connection, client: 40.77.167.30, server: 0.0.0.0:443
2022/08/04 13:57:41 [crit] 3086#3086: *392 SSL_read() failed (SSL: error:0A000126:SSL routines::unexpected eof while reading) while processing HTTP/2 connection, client: 40.77.167.30, server: 0.0.0.0:443
2022/08/04 14:13:15 [crit] 3086#3086: *394 SSL_read() failed (SSL: error:0A000126:SSL routines::unexpected eof while reading) while processing HTTP/2 connection, client: 40.77.189.232, server: 0.0.0.0:443
2022/08/04 14:13:15 [crit] 3086#3086: *395 SSL_read() failed (SSL: error:0A000126:SSL routines::unexpected eof while reading) while processing HTTP/2 connection, client: 40.77.189.232, server: 0.0.0.0:443
2022/08/04 14:13:16 [crit] 3086#3086: *396 SSL_read() failed (SSL: error:0A000126:SSL routines::unexpected eof while reading) while processing HTTP/2 connection, client: 40.77.189.232, server: 0.0.0.0:443
2022/08/04 14:13:17 [crit] 3086#3086: *400 SSL_read() failed (SSL: error:0A000126:SSL routines::unexpected eof while reading) while processing HTTP/2 connection, client: 40.77.189.232, server: 0.0.0.0:443
2022/08/04 14:13:17 [crit] 3086#3086: *402 SSL_read() failed (SSL: error:0A000126:SSL routines::unexpected eof while reading) while processing HTTP/2 connection, client: 40.77.189.232, server: 0.0.0.0:443
2022/08/04 14:13:17 [crit] 3086#3086: *401 SSL_read() failed (SSL: error:0A000126:SSL routines::unexpected eof while reading) while processing HTTP/2 connection, client: 40.77.189.232, server: 0.0.0.0:443
2022/08/04 14:13:17 [crit] 3086#3086: *408 SSL_read() failed (SSL: error:0A000126:SSL routines::unexpected eof while reading) while processing HTTP/2 connection, client: 40.77.189.232, server: 0.0.0.0:443
2022/08/04 14:13:17 [crit] 3086#3086: *406 SSL_read() failed (SSL: error:0A000126:SSL routines::unexpected eof while reading) while processing HTTP/2 connection, client: 40.77.189.232, server: 0.0.0.0:443
2022/08/04 15:04:38 [crit] 3086#3086: *428 SSL_read() failed (SSL: error:0A000126:SSL routines::unexpected eof while reading) while keepalive, client: 192.241.236.122, server: 0.0.0.0:443
2022/08/04 17:25:14 [crit] 3086#3086: *443 SSL_read() failed (SSL: error:0A000126:SSL routines::unexpected eof while reading) while keepalive, client: 94.102.61.8, server: 0.0.0.0:443
2022/08/04 18:08:51 [crit] 3086#3086: *470 SSL_read() failed (SSL: error:0A000126:SSL routines::unexpected eof while reading) while keepalive, client: 45.227.255.58, server: 0.0.0.0:443
2022/08/04 18:08:58 [crit] 3086#3086: *472 SSL_read() failed (SSL: error:0A000126:SSL routines::unexpected eof while reading) while keepalive, client: 45.227.255.58, server: 0.0.0.0:443
Did you noticed this ?
Yes, I masked my real domain and public IP.
@pattonjo jc is pointing out that you have an error in the configuration. Run nginx -t to test the configuration. If there is an error it will point you to the line in the configuration file…like it does in the log file. It’s saying line 68. I’ve edited your first post’s config for clarity. If you put three backticks before and after it will offset that section as code.
It will be helpful to post your separate NGINX config files if you are needing help. Especially the one located /etc/nginx/sites-enabled/reverse-proxy.conf.
this would be /etc/nginx/sites-enabled/reverse-proxy.conf
I transposed it wrong when editing out domain names,etc, but it is passing nginx -t
server {
    server_name _;
server {
	server_name mydomain.com;
	location / {
server {
        server_name *.esmc.mydomain.com esmc.mydomain.com;
        location / {
                 proxy_pass https://172.16.0.7;
server {
        location / {
Most recent Passbolt and Reverse Proxy Server Error Logs
2022/08/06 20:22:45 [crit] 8149#8149: *3 SSL_read() failed (SSL: error:0A000126:SSL routines::unexpected eof while reading) while keepalive, client: 34.76.96.55, server: 0.0.0.0:443
2022/08/06 20:24:06 [crit] 8277#8277: *3 SSL_read() failed (SSL: error:0A000126:SSL routines::unexpected eof while reading) while reading response header from upstream, client: 98.243.113.57, server: *.passbolt.mydomain.com, request: "POST /users/recover.json?api-version=v2 HTTP/2.0", upstream: "https://172.16.0.24:443/users/recover.json?api-version=v2", host: "passbolt.mydomain.com", referrer: "https://passbolt.mydomain.com/auth/login?redirect=%2F&locale=en-UK"
2022/08/06 20:25:39 [crit] 8277#8277: *23 SSL_read() failed (SSL: error:0A000126:SSL routines::unexpected eof while reading) while reading response header from upstream, client: 98.243.113.57, server: *.passbolt.mydomain.com, request: "POST /auth/verify.json?api-version=v2 HTTP/2.0", upstream: "https://172.16.0.24:443/auth/verify.json?api-version=v2", host: "passbolt.mydomain.com"
2022/08/06 20:26:10 [crit] 8277#8277: *23 SSL_read() failed (SSL: error:0A000126:SSL routines::unexpected eof while reading) while reading response header from upstream, client: 98.243.113.57, server: *.passbolt.mydomain.com, request: "POST /setup/recover/abort/69049aff-d562-4d95-a22c-7a2e1ab8d109.json?api-version=v2 HTTP/2.0", upstream: "https://172.16.0.24:443/setup/recover/abort/69049aff-d562-4d95-a22c-7a2e1ab8d109.json?api-version=v2", host: "passbolt.mydomain.com"
2022/08/06 20:31:07 [crit] 8277#8277: *74 SSL_read() failed (SSL: error:0A000126:SSL routines::unexpected eof while reading) while reading response header from upstream, client: 98.243.113.57, server: *.passbolt.mydomain.com, request: "POST /setup/complete/2d9ac55d-4a60-46bc-9765-eddc9bc30922 HTTP/2.0", upstream: "https://172.16.0.24:443/setup/complete/2d9ac55d-4a60-46bc-9765-eddc9bc30922", host: "passbolt.mydomain.com"
2022/08/06 20:24:06 [info] 46897#46897: *234 SSL_read() failed (SSL: error:0A00041A:SSL routines::tlsv1 alert decode error:SSL alert number 50) while sending to client, client: 172.16.0.26, server: passbolt.mydomain.com, request: "POST /users/recover.json?api-version=v2 HTTP/1.0", upstream: "fastcgi://unix:/run/php/php8.1-fpm.sock", host: "172.16.0.24", referrer: "https://passbolt.mydomain.com/auth/login?redirect=%2F&locale=en-UK"
2022/08/06 20:25:39 [info] 46897#46897: *252 SSL_read() failed (SSL: error:0A00041A:SSL routines::tlsv1 alert decode error:SSL alert number 50) while sending to client, client: 172.16.0.26, server: passbolt.mydomain.com, request: "POST /auth/verify.json?api-version=v2 HTTP/1.0", upstream: "fastcgi://unix:/run/php/php8.1-fpm.sock", host: "172.16.0.24"
2022/08/06 20:26:10 [info] 46897#46897: *254 SSL_read() failed (SSL: error:0A00041A:SSL routines::tlsv1 alert decode error:SSL alert number 50) while sending to client, client: 172.16.0.26, server: passbolt.mydomain.com, request: "POST /setup/recover/abort/69049aff-d562-4d95-a22c-7a2e1ab8d109.json?api-version=v2 HTTP/1.0", upstream: "fastcgi://unix:/run/php/php8.1-fpm.sock", host: "172.16.0.24"
2022/08/06 20:31:07 [info] 46897#46897: *359 SSL_read() failed (SSL: error:0A00041A:SSL routines::tlsv1 alert decode error:SSL alert number 50) while sending to client, client: 172.16.0.26, server: passbolt.mydomain.com, request: "POST /setup/complete/2d9ac55d-4a60-46bc-9765-eddc9bc30922 HTTP/1.0", upstream: "fastcgi://unix:/run/php/php8.1-fpm.sock", host: "172.16.0.24"
@yash Passbolt Help | Troubleshoot SSL has a link to check your ssl certs. The decode error suggests maybe one of the passbolt server NGINX ssl keys is not right. The error with that cert/key is probably causing the unexpected eof while reading error in the reverse proxy.
Also run nginx -t on the passbolt server to check the NGINX config there.
nginx -t passes on the passbolt server.
All links that are provided for SSL Troubleshoot pass, and the correct chain is provided. Cert does match with the key.
I did notice that my private key starts with
-----BEGIN RSA PRIVATE KEY-----
instead of
-----BEGIN PRIVATE KEY-----
I’ll start there.
It seems that NGINX/OpenSSL is also identifying the use of TLSv1.
For example, in the default Passbolt setup, this line indicates NGINX settings for ssl versions https://github.com/passbolt/passbolt_api/blob/634880afd62a792ddd22c15805b07b7f14af1d2d/debian/conf/nginx-passbolt-ssl.conf#L22
I believe the error SSL_read() failed (SSL: error:0A00041A:SSL routines::tlsv1 alert decode error:SSL alert number 50) is from OpenSSL, as a result of NGINX ssl parameters. Make sure you are setting NGINX to TLSv1.2 and TLSv1.3 in both reverse proxy and backend.
Cleaned up the TLS mismatch, but was still unable to resolve this via the Nginx Reverse Proxy http block.
Didn’t change cert key at all.
-----BEGIN RSA PRIVATE KEY----- (this is acceptable)
I did resolve the issue by pushing this through via the stream module, and just terminated SSL on the back end server.
