Healthcheck:
// _,///./_//__/
[PASS] PHP version 8.3.1.
[PASS] Full base url is set to https://192.168.188.34
[HELP] cURL Error (60) SSL certificate problem: self signed certificate
[PASS] 31 tables found
[PASS] Using latest passbolt version (4.4.2).
[WARN] The deprecated self registration public setting was found in /etc/passbolt/passbolt.php.
[HELP] You may remove the “passbolt.registration.public” setting.
SMTP Settings
