[Y ] I have read intro post: About the Installation Issues category
[ Y] I have read the tutorials, help and searched for similar issues
[ Y] I provide relevant information about my server (component names and versions, etc.)
[ Y] I describe the steps I have taken to trouble shoot the problem
Hello All,
I just installed Passbolt on a fresh new install on Ubuntu 22.04. I setup the installation with the script and I asked no SSL for NGINX as I’m using external NGINX server.
I was able to finalize the full setup process and everything was ok until I enable the external access.
I’m facing with a blank screen. Off course I already tried a lot of things in the forum but nothing solved the issue.
Here are the behaviors :
- access with local ip in http → nginx welcome screen (message from the passbolt nginx itself)
- access with local ip in https → Unable to connect as SSL is disabled in Passbolt config
- access with external url in http or https → redirected to auth/login?redirect=%2F white page
I launched a healthcheck and no issue related to url
[PASS] PHP version 8.1.2-1ubuntu2.14.
[PASS] Full base url is set to http://xxx.yyy.be
[PASS] 32 tables found
[PASS] Using latest passbolt version (4.2.0).
[HELP] Check App.fullBaseUrl url scheme in /etc/passbolt/passbolt.php.
SMTP Settings
The fullbase url use my external domain in http.
Here is the NGINX config on my passbolt server
# Passbolt.conf - Nginx configuration file to run the Passbolt software.
server {
listen 80;
listen [::]:80;
# Managed by Passbolt
#server_name 10.10.31.50;
server_name xxx.yyy.be;
client_body_buffer_size 100K;
client_header_buffer_size 1K;
client_max_body_size 5M;
client_body_timeout 10;
client_header_timeout 10;
keepalive_timeout 5 5;
send_timeout 10;
index index.php;
# include __PASSBOLT_SSL__
location / {
location ~ \.php$ {
try_files $uri =404;
include fastcgi_params;
fastcgi_pass unix:/run/php/php8.1-fpm.sock;
fastcgi_index index.php;
fastcgi_intercept_errors on;
fastcgi_split_path_info ^(.+\.php)(.+)$;
fastcgi_param PHP_VALUE "upload_max_filesize=5M \n post_max_size=5M";
The external NGINX configuration should be ok.
Could you help me to solve that issue ?
Thanks
