I initially set up passbolt through AWS AMI and it was working perfectly in the unsecured mode (no SSL installed). I tried adding the SSL certificate today through the let’s encrypt method but it failed to complete as I said that I have to mention the server URL in NGINX Setup which I am not familiar with. I tried googling but was not able to find a proper solution.
Then I moved onto the manual installation and gave the path to SSL Certificates which were created by let’s encrypt. It showed a blank screen - https://ims.tresformics.com
I thought it may be an issue with my assistant certificate so I created another one from Zero SSL and install data using the manual method. I am still getting a blank page. No Error in logs.
Please suggest, what should I do
