Hi all,
After a clean install on a debian 12 VM on proxmox, following the guide from https://www.passbolt.com/docs/hosting/install/ce/debian/
I can add / edit / delete passwords, but can’t edit settings.
is-authenticated.json?api-version=v2 is okay,
settings.json?api-version=v2 returns me the CSRF Token error.
My healthcheck looks good :
[INFO] Linux passbolt 6.1.0-28-amd64 #1 SMP PREEMPT_DYNAMIC Debian 6.1.119-1 (2024-11-22) x86_64 GNU/Linux
[PASS] PHP version 8.2.26.
[PASS] System clock is synchronized and NTP service is active.
[PASS] Full base url is set to https://pass.mevng.net
SMTP settings
[PASS] Using latest passbolt version (4.10.1).
[PASS] 34 tables found.
[PASS] No error found. Nice one, sparky!
and the only place where it sends any csrf token to settings.json?api-version=v2 is in the cookies.
can anyone help me troubleshoot this ?
I’ve tested reinstalling on another vm (an ubuntu 24 one), same problem.
